RUN TIME ERROR 8002 Port type mismatch
Old Jun 1, 2002 | 02:54 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
I am currently trying to get winbin to run on my computer and I keep getting Run time error 8002 port type mismatch. I have a 89 version ecu and a 89 version bin file and I keep getting thismessage. i did a search and as of nowthe problem still exists no solution has been found yet.
Old Jun 1, 2002 | 09:41 PM
goneracin's Avatar
I had this problem when i first put winbin on my computer. If you get the error, close winbin and start over. I have to open winbin, put the files in where they go, and then click view. after the view comes up, I have to close that window,(not minimize, but close) then I can click edit and the error message will go away. I also cannot be on the internet while winbin is up, or I get an error also. hope this helps.
Bob
Old Jun 2, 2002 | 11:49 AM
AaronIROCZ's Avatar
After all of that I still get the message. This is so frustrating!!!!!
Old Jun 2, 2002 | 07:53 PM
goneracin's Avatar
Try to down load it again. If you get the same message again, close winbin, and also close anything else you have running. restart winbin, then load the correct ecu and bin files and click view. Don't click edit first. After the graph thing cones up, close view, and then click edit. The second download may do it, This is what I had to do. I had the same prob for a week till I figured it out. Still cant do it when on the net, which sucks cuz id like to view available bin files.
Old Jun 3, 2002 | 09:47 PM
AaronIROCZ's Avatar
Still won't work, It now says runtime error 8002 invalid port number????? Please help this is the only thing preventing me from getting my car running. heres the thing, my harddrive crashed and i lost everything, it worked fine before the harddrive crashed, so this is really confusing me.
Old Jun 4, 2002 | 03:21 PM
goneracin's Avatar
Man, I dont know. If youve tried uninstalling, and reinstalling, maybe you lost something when it crashes, or its trying to use a driver/port thats not configured correctly. Good luck, I hope you find something. If you do, let us know.
Sorry you are having suck ****ty luck with it. The only other suggestion would be to purchase tunercat.
Old Jun 4, 2002 | 04:06 PM
AlexJH's Avatar
Engine: 5.7L V8
What version of Windows are you using? Can you try it on any other computers? I think WinBin tries to access serial ports on the computer for some reason, and gets into trouble if it can't find any.
I've looked around for the source code for this program, but no luck.
Old Jun 4, 2002 | 06:05 PM
AaronIROCZ's Avatar
I am using windows 98. I have tried it on my parents computer i think they have windows 2000?? or something newer than 98, and it works fine. The only problem is they are 200 miles away or i would just use theres.
Old Jun 4, 2002 | 06:26 PM
tpi_roc's Avatar
I've worked around type mismatch problems with fuel injector constants by changing the constant, saving, closing, and going to the double fire, changing, saving, closing, it changes and holds, and you dont get the error.
Old Jun 4, 2002 | 07:16 PM
AaronIROCZ's Avatar
But I can't even get the program to load, when I pick the bin file, and ecu file i then click the edit button and wait for 4-5 sec then comes up run time error 8002 invalid port number, it then goes into the program but then sits there wont let me click on anything but the X button to close. If I wait a while the computer automaticly restarts.
Old Jun 4, 2002 | 10:37 PM
tpi_roc's Avatar
Ouch
yea thats quite different
I take it you've tried numerous bins/def files?
Old Jun 5, 2002 | 10:57 AM
Morley's Avatar
Make sure your serial ports aren't disabled in the BIOS.
~M~
Old Jun 5, 2002 | 11:15 PM
AaronIROCZ's Avatar
Well looks like I have to trash the program. I have tried everything to my knowledge and still won't work. i have already sent the money to tunercat and I will be eagerly waiting for the files. I have just got my car running tonight and it runs VERY rich at idle. it puts out a small haze and when you goo to the exhaust my eyes start to burn because of the raw fuel. Other than that it sounds sweet.
Old Jul 22, 2002 | 07:55 AM
JPiroc87's Avatar
Selecting different port addresses solved this problem in my case. Open \My computer\control panel\ports\settings\advanced\IO port address\ and select a different HEX address.
I also received an error message saying 'ECU file error'. I found this to be caused by the selected type of decimal symbol. It must be a dot, not a comma. Open \My computer\control panel\regional settings\number\decimal symbol\ and select dot.
More details https://www.thirdgen.org/techbb2/sho...&postid=778179
Old Aug 26, 2002 | 11:01 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Same prob with winbin on my 2000 box, and my 98 laptop.. Why does it wish to open the serial ports???
Weird..
I noticed the last update to winbin was 11/2000.. Is it still being developed? if not, is source available?
-- Joe
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
Jake_92RS
Aug 11, 2015 10:39 AM
mx127
Aug 10, 2015 08:13 AM
