First nitrous run tonight
Old Jun 7, 2002 | 12:37 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Well I bought a new NOS 5151 kit off of one of my cascade crew brothers and installed it. I ran it for the first time tonight jetted for the 100 horse shot. Man was that a kick in the pants. Had a big old grin. She is in the garage cooling down. I am going to put in the jets for the 150 shot.
Everything ran great. No problems. I wanted to say thank you to all that have posted good and bad experiences with nitrous in the past. The search function is your friend and I took a lot of the advice to heart.
I will try to get to the track within the next month and post the actual results but the butt dyno says
There have been a lot of posts about the main nitrous feed line length being too short in the 5151 kit. FWIW, I mounted my bottle in the spare tire compartment and ran the nitrous line inside the car and then into the engine compartment through the fender. It worked out great.
-Schultzy
Old Jun 7, 2002 | 12:47 AM
dreeew's Avatar
Sounds fun, man. How fast did you get to?
Old Jun 7, 2002 | 10:41 AM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
Good idea on the mounting spot, but what if you get hit in the side?
SB
Old Jun 8, 2002 | 06:08 PM
Car: 1989 GTA
Dreeew,
I wasn't really going for a top speed but if you care I did go over the century mark a few times. It was the first time that I had tried the system out and wanted to make sure the everything worked correctly. I put in the jets for a 150 shot now but it has been raining and I haven't tried it out yet.
Bob,
I'll let you know if I get hit in the side. Thanks for your concern.
-Schultzy
Old Jun 10, 2002 | 10:01 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
My guess to what happens is as follows: If the bottle is open, the feed line could rupture and he will lose a perfectly good bottle of nitrous. And other situation is that the bottle gets a puncture and again he loses a perfectly good bottle of nitrous.
Old Jun 10, 2002 | 02:15 PM
Car: 1989 GTA
Thanks Omega. The question was interesting. What happens if you get hit in <insert location of bottle here>?
Anyway, fwiw, tested out the 150 shot this last weekend with no problems and an even bigger grin factor.
Later,
-Schultzy
CarGuyDennis
137
Dec 6, 2016 11:02 PM
gwade12
Aug 8, 2015 08:17 AM
