4th gen console
Old Jun 13, 2002 | 04:43 PM
LT1maro's Avatar
4th gen console
I have a 4th gen trans am console that i am getting ready to install in my camaro. I have a question, will the auto consoloe work with my auto because it looks like the gear area isnt big enough? anyone run into this problem? what did u do to fix it? thanks
Old Jun 13, 2002 | 06:46 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
camaro 22 put an auto 4th gen console on his auto 3rd gen camaro. i know he got it to work, but i don't know what he had to do. i'm not sure if he's even still around, do a search for him.
Old Jun 14, 2002 | 07:38 AM
LT1maro's Avatar
also, to anyone who has done this console swap in a camaro. Did u use a 3rd gen radio pod? i bought one of them and was wondering if it will make he swap alot easier? thanks
Old Jun 14, 2002 | 06:53 PM
pontiac90's Avatar
I've seen one guy do this swap and it turnes out extremely well. I believe it was Stuart69427, ot something like that. He used a thirdgen radio pod out of a firebird. It looked like it took a lot of time and effort. But that's what this hobby is all about. Good luck!!
Old Jun 14, 2002 | 08:36 PM
TransAm87's Avatar
You can keep the thirdgen radio pod and i would recommend it, as for the console, both auto and manual are the same, just the shifter plate is different, just go to gm and get a difference shifter console
Aj
my 4th gen console is in the mail!! YAHOOO
Aj
Old Jun 15, 2002 | 12:08 AM
nosaint's Avatar
Car: 1986 Trans Am
here's a pic of mine, bolted right in with little trouble
Old Jun 17, 2002 | 04:56 PM
Tonyrodz's Avatar
Transmission: auto
Here's mine too.
Attached Thumbnails 4th gen console-4th-gen-console-2
Old Jun 17, 2002 | 05:26 PM
TransAm87's Avatar
Hey do you guys have a site to get parts for the console, b/c i just got a 4th gen console and i need the shifter plate and another part
thanks
Aj
Old Jun 18, 2002 | 12:57 PM
LT1maro's Avatar
www.speedautomotive.com has all the parts
Old Jun 19, 2002 | 06:48 PM
gpierce's Avatar
I am in the process of putting a 4th gen automatic console in my 86 Firebird. While not a Camaro, a couple of my issues should be the same. I used a 01 automatic console off ebay.
I had to do two things. I had to move the shifter assembly back about 4 inches. This is because the later model consoles are a little higher in front, and thus need to move back a little to clear the radio housing.
The other thing, was no matter how hard I tried the part on the console plate that fits over the shifter would not fit and let the console sit all the way on the floor. The reverse lockout switch in the side of the shifter interferes with the bottom of the plate. I had to cut off the section of it that goes over the shift handle, and the two pedastals the screws that hold it on that side mount to. Now it's just an open hole over the handle, and I need to find soemthing to cover it.
I think it would fit better with an actual 4th gen shifter assembly, but not sure. I'll have to take a closer look at my 94's shifter and see the differences.
Anyway, I'm pretty happy with the way it turned out. I'll get some pics when I have time, but I'm rebuilding the tranny in the 94 and that's taking up all my time at the moment
BTW here is the part # list and pricing from Team Chevrolet The # is the # in the picture on the dealers part sheet I attached. Bsically if you ordered all that you would get a complete console. Not bad considering used ones go for 200 on ebay.
#1-88892218, Cover is included with #15
#2-10291612, Spring is included with #15
#3-17997865, Bumper is included with #15
#4-10421435, Ashtray $4.18
#6-15305919, Connector $14.82
#7-12450043, Housing is included with #15
#13-10411278, Compartment $6.46
#14-Housing is included with #15
#15-10413134,Plate $47.96
#17-9421330, Bulb $.36
#18-12125055, Socket $21.64
#21-10271241, Hinge $8.18
#22-11508561, Screw $2.30
#23-17997865, Bumper $2.39
#24-11509051, Bolt $.48
#25-10245028, Coin Holder $14.01
#26-11509374, Screw $2.30
#27-10421365, Cover $2.39
#28-12532456, Holder $8.32
#30-10411272, Console $79.35
GP
Hawk312
Aug 22, 2017 08:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
cam-mike
Aug 24, 2015 07:23 AM
