Project Stealth Ram is underway!!
Old Jun 22, 2002 | 08:35 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Well I finally got to start on the Stealth Ram Swap, Here are some of the pics, I would have got more done, but I lost one of my Torque Bits, so that slow me down today, but I should be done tomorrow, well here are some pics and here is another one heres the edelbrock high flow, almost ready to go out this is when I found out my bit was gone! and here is the last shot for today, the intake yanked off alright I ll take some more torrow when I do the install, and preping.
Old Jun 22, 2002 | 08:37 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
well my pics aren't working heres the links sorry guys,http://community.webshots.com/photo/...41458211DQzOeL
http://community.webshots.com/photo/...41458516tJpOLF
and the last one
http://community.webshots.com/photo/...41458763HrAMfG
Old Jun 22, 2002 | 11:04 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
You've got a PM!
Old Jun 26, 2002 | 09:19 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Well I m finally done, what a pain, there were a few little catches here and there but I finally finished and I routed the fuel lines different. I like this way cause I didn't have to cut the steel lines and just reused them. I think it looks alittle cleaner, but anyway here they are http://community.webshots.com/photo/...41862004toXfwU
and http://community.webshots.com/photo/...41861647kByQcT
Yeah I know the bay is dirty, I plan to clean it this weekend or next.
Old Jun 26, 2002 | 11:22 PM
89ProchargedROC's Avatar
its hard to tell, but where did you route the crossover lines from one rail to the next....
i'm going to be installing my friends stealth ram and am debating on ways to do it
Old Jun 27, 2002 | 02:04 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
yeah, I put the inlet fitting (well my buddy did) on the front of passagerside rail, and put the plug fitting on the driver's front rail. That way your throttle body clears, with no prob. Well my buddy routed the cross over to the rear, in front of the distb. you have to leave a little slack in the fittings to get it started, but it will fit, on make sure you put some teflon tape are that little fuel pressurer testing val, you know the one that looks like a tire val. cause that little savage was the only thing that linked. Basically a easy way to hook up your fuel lines, is to take off the rubber part of the fuel lines. Theres a long one and a short one take them with you, take your inlet and outlet fittings with you to a hose shop. Their hydril. fittings, that connect to fuel rails, well the shop I went to didn't have the ends to connect to my fuel lines, so that just cut off my old fittings and connected them to a set of new hoses with new fittings that will connect to your inlet and outlet fittings. So that way it will bolt back on with out a prob. You could route it like I have mine, I just got the inlet hose the same size as the longer hose, with a 45 degree fitting on the end. (you could do 90 if you want) and then get the outlet hose 6 inches longer than that one with a strait fitting and you can route that one like I did beside the intake along the valve cover, I think its looks pretty clean that way. Hope that helps.
Old Jun 28, 2002 | 10:33 AM
tpi_roc's Avatar
Enough with all that noise
HOW DOES IT RUN??!!
Old Jun 28, 2002 | 10:53 AM
DFIance's Avatar
Webshots sucks!!! I cant even see anything.
Old Jun 28, 2002 | 01:12 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Oh sorry about that tpi_roc, well it pulles harder than my SLP runners/edelbrock base. And it shifts alot later, but pulls really smooth at 70 and up, Yesterday was really the only day I could take it out and get on it. I think I still have some bugs to workout though, But I hope to get to the track sometime in the next few weeks. It's just been raining here like everyday.
Old Jun 28, 2002 | 01:14 PM
tpi_roc's Avatar
w00t
Sounds good, Do you do any prom burning?
Old Jun 28, 2002 | 01:21 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
no , I still got my stock chip,right now I only got free flowing exhausts, and some other little mods, my heads and cam are stock. . yeah on the site I took a pic of the mismatch of the heads with the intake, you can see the port of the head. But thats another project I just had to get it running for now.
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
mattcanty
Oct 12, 2015 11:08 AM
LT1Formula
Oct 8, 2015 08:34 PM
mfp189
Sep 27, 2015 09:25 AM
