434ci SBC TPI Stroker
Old Jun 27, 2002 | 12:46 PM
92GTA's Avatar
This is what I have so far for my 434 SBC Stroker Project based on this block which I already have:
'74 400ci SBC, 2-Bolt, 2-Freeze Plug, High Nickel Block
Bore/Stroke 4.155 X 4.000 (433.9ci)
Splayed Caps
Now looking through old posts on the subject, these some of the exact parts that I'm going to need:
1) Eagle H-Beam 6.0 w/L.19 Bolts (+.300 Long) Rods
2) Eagle 4340 4.000 Crankshaft
3) Comp Cams XR282HR Camshaft (CARB Legal)
4) Clevite H Series Bearings
5) Trickflow 23* 72cc CNC-Profiled Chamber Heads PN# TFS-30400013-CNC (CARB Legal)
6) JE 400 SB Brodix-12 PN# 194945 Forged Pistons
7) JE Molly Rings PN# J100081455-5
I plan on running a ProCharger D-1SC so the modded TPI will be able to give the engine a fair amount of airflow, keep in mind this is a street car. I will have an extensively modded TPI system that will include such things as very well worked SLP runners, a 58mm throttle body, a siamiessed TPI intake base (most likely aftermarket based), etc.
Now, exactly what Pistons and comp. ratio should I go with? I have access to 100 octane pump gas and I'd like to optmize my boost/comp. ratio for not the most power but the most efficient power persay, I don't want to push the engine TOO hard. Also, do you guys agree on the type of heads I plan on using? What about the camshaft? How about injectors? I'd like to get it down to EXACTLY what parts including part #'s and $$ so I can do a Desktop Dyno file that is 100% accurate as far as the parts being used.
Since this is a 2-freeze plug 400 SBC "Cheater Block", I want to try my best to keep the engine CA smog legal. I know what you guys are going to say about that but I figure if I smog it naturally aspirated and tuned just right with CARB headers etc. I have a chance.
Thanks!
Old Jun 27, 2002 | 02:43 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
whats the big deal with a high nickel content block?
Old Jun 27, 2002 | 04:44 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Stronger..
Old Jun 27, 2002 | 05:01 PM
92GTA's Avatar
Yeah, they are stronger than just plain cast iron.
Now that I am doing more and more reseach, I think maybe it's best not to go with the 4 inch stroke so it will last longer since I want it to be a street car (not a daily driver of course). So I think it's better to just go with a 406.8ci stroker...
Old Jun 27, 2002 | 05:08 PM
camarokev400's Avatar
yeah a 406 is just a 400 block bored .30 over... im currently building one right now
Old Jun 27, 2002 | 06:34 PM
johndo1707's Avatar
hell yeah, you'll be looking at 12's with a 400 easily!
Old Jun 27, 2002 | 08:18 PM
bbunting's Avatar
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Actually, you can buy the complete rotating assembly direct from Eagle. I will input the Trick Flow R series 2.08/1.60.
As far as compression, it will be hard to find less than 9:1 with 434 pistons. The cam in question with a Vortech V2-S with a 2:1 belt ratio pumps put 651 HP @ 5500, & 682 TQ @ 4500. That has to do with the cam.
If I only change the cam to Comp Solid Roller Blower grind-12-704-8 that has more duration and .575 I & E, the numbers make a significant change.
747 HP @ 6000
739 TQ @ 5500
A bigger cam moves more air and takes advantage of the good flow numbers of the Trick Flow Race heads. 55 lb. per hr injectors will support 850 HP.
Old Jun 27, 2002 | 09:08 PM
rich88gta's Avatar
Looks like a sweet build up.
Mickeyruder
Sep 2, 2015 02:45 PM
masonta
Aug 31, 2015 10:14 PM
bdads
DIY PROM
Aug 24, 2015 06:01 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
