Points and dwell
Old Jun 29, 2002 | 09:31 AM
Brent's Avatar
Points and dwell
Is it better to set the point gap to spec or set the gap to whatever is required to get the dwell correct within spec?
Why would the dwell be off if the gap is set to spec?
Old Jun 29, 2002 | 10:10 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Back to the past!
Get the dwell correct. The gap shouldn't be too far out at this setting.
The cam in the dizzy controls the dwell period. If the dizzy shaft/bearings are worn and there is side to side movement in it, this can cause the dwell to vary and cause "spark scatter". Put a timing light on it with vacuum to dizzy disconnected and watch where the timing mark is. It shouldn't vary much at all. If it is jumping around, you have wear somewhere, or even a bent shaft.
You haven't got a 3rd gen with points in it have you?
Andy.
Old Jun 29, 2002 | 11:05 AM
ede's Avatar
ede
yep set the dwell to spec the gap doesn't matter near as much as the dwell does. damn i'd hate to guess at the last time i put points in a car engine, mid 80s i bet.
Old Jun 29, 2002 | 02:07 PM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
could someone explain how point work (to give me a refresher and some of the younger members an explenation)
Old Jun 29, 2002 | 03:54 PM
ede's Avatar
ede
they're just a contact set the run along a cam (8 sided for v8, 6 sided for 6s etc) when they're on the high point of the cam they open making and breaking the eletric circuit.
Old Jun 29, 2002 | 09:27 PM
Brent's Avatar
Thanks for the replys. I thought dwell might trump gap.
Getting the points to the highest position on the cam proved to be a real PITA.
The points aren't in a thirdgen. They are in a '71 Landcruiser.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
gixxer92
May 18, 2017 11:20 AM
tmellott89
DIY PROM
Oct 14, 2015 02:06 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
