82 S/E with Custom Taillight BASE/TA MIX
Old Jul 7, 2002 | 05:05 PM
Calderone's Avatar
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Hi everyone ...i got new pics from my car ..remember not long ago
i said i changed my horrible wheels for this 15inch base ??
This is how it looks now ...and take a look yeah ,,it looks like that cause my old rear wheel went out while cruising hohoho
My tail ????
How do it looks ??? The cool thing about this is that i hated Orange tail sidemarkers...it remainded me of a japanese or normal car ...my car originally came with the smoked 82 T/A and S/E tail ..so i have no separated sidemarker..so what i did
I have to add an extra bulb and relocate the bulbs ..why ?? cause 3bulbs are used perside in the 82-84 tails ..the one that goes on the outside is brighter and the two on the middle are dim ..so when you hit the brakes ..the two on the middle Lights up ..but Holy ****ĦĦthe new 85-92 tail has four bulbs ĦĦĦ No problem...so i relocated the "Braking"bulbs and sockets to the outside....so when i hit the brakes the two outside bulbs Lighten up...and cause i have a 82 the same outside bulbs works as sidemarkers also ..so i dont have to use the separate Orange one so i deleted it...and what about the other two ??Well i relocated the originally on the outside bulb to the middle and wired another one ...but ,,the 85-92 tail came with little holes for little bulbs ...Oh ,.,yeah,,no problem..i widened it ...Hey Stop....You put the "Brighter bulbs on the inside" Yeah but i installed 2 contact bulbs..so the dim one is lighten and the Brighter contact is not in use ...Results :
When im cruising at night all the lights looks the same ...as a Formula Tail ..when i stop...the two outer lights light up (as a Formula or base Tail) but when i turn ..this same outer lights blinks ĦĦso i decided to delete the Reverse and sidemarkers with Limotint paper and the Reverse light looks anyway thru the tint
But the tail looks only the red ..and about two weeks ago i was thinking to get the grilled look so i bought a Black Stripe tape and i added to the tail making my own Grill design so here is how it looks ...the main and funny thing about this Tint and stripe stuff is if i get bored i simply push all the stuff out and no marks will be on the taillights ĦĦĦ
What you think bout this ??? Rate the pics please
Comments ....Do my car look like an 82 ???
How do my car look ??
Thank you all ...Thirdgen nut forever ĦĦĦĦ
Attached Thumbnails 82 S/E with Custom Taillight  BASE/TA MIX-sammynewtail2.jpg.jpg
Calderone's Avatar
Car: 87 Vette
ANOTHER ONE
OTHER ONE
Attached Thumbnails 82 S/E with Custom Taillight  BASE/TA MIX-sammynewtail.jpg.jpg
Old Jul 7, 2002 | 05:06 PM
Calderone's Avatar
Car: 87 Vette
SIDE PIC
COOL OR NOT ??
Attached Thumbnails 82 S/E with Custom Taillight  BASE/TA MIX-sammynew.jpg.jpg
Old Jul 7, 2002 | 05:21 PM
Calderone's Avatar
Car: 87 Vette
wheel
wheel
Attached Thumbnails 82 S/E with Custom Taillight  BASE/TA MIX-sammywheel.jpg.jpg
Old Jul 7, 2002 | 05:22 PM
no_car_yet's Avatar
cool
Old Jul 7, 2002 | 05:23 PM
Calderone's Avatar
Car: 87 Vette
Attached Thumbnails 82 S/E with Custom Taillight  BASE/TA MIX-sammyengine.jpg.jpg
Old Oct 13, 2002 | 08:38 PM
Calderone's Avatar
Car: 87 Vette
what you think
comments guys
Old Oct 13, 2002 | 08:54 PM
devianb's Avatar
I was working with the same idea for my taillights, but without the grid. I had one problem, what to do with my reversing light. Do you get pulled over for not having one? If you don't, then I will just black out the entire bottom section like you did. Since I have an 87, I would move the turn signal bulb to the outer stop bulb, move the inner stop bulb to one of the smaller light sockets and move the reversing light to the inner most taillight section so that the reversing light is still functional.
I like your taillights, I even liked them before. I wish I had a simplier taillight setup though. That's a huge chunk take out of your rear side.
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
i think it looks good , im not the biggest fan of those type of wings but you did a nice job on the taillights
Old Oct 13, 2002 | 09:01 PM
devianb's Avatar
Wow, someone who actually doesn't like the stock wrap around wing. That's rare. It looks pretty good on an 84 body.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
MrPackstin
Oct 25, 2017 08:09 PM
HoosierinWA
Oct 7, 2015 10:15 AM
bjpotter
Oct 4, 2015 07:48 PM
92firebirdchris
Exterior Parts Wanted
Oct 1, 2015 01:38 PM
