where to put subs
Old Jul 12, 2002 | 07:45 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
where to put subs
hey i'm going to buy some subs soon. where should i put the box, becasue i can't put it in the canyon thing. any idea's. i'm probley going to be running one 12". so please give me sugestions thanx
Old Jul 12, 2002 | 08:22 PM
mudaholic's Avatar
you can take out your spare tire and put it there..
Old Jul 12, 2002 | 09:18 PM
blaznbrd's Avatar
Car: 90 T/A GTA
Engine: 350 tpi
where is the spare tire???
Old Jul 12, 2002 | 09:50 PM
mudaholic's Avatar
well in camaros at least, its in the back, passenger side, behind some trim pieces.. not positive on birds...
Old Jul 13, 2002 | 12:20 AM
91L98Z28's Avatar
Car: Z28
I hope lots of people reply to this one...I too have no interest in giving up the only useful storage in my camaro with a big sub box.... would be awesome to find a place to stuff a single 10" or 12" for some decent sound....
Old Jul 13, 2002 | 01:37 AM
mudaholic's Avatar
you pretty much have the two compartments on either side of the well.. theres nowhere else to put it...
Old Jul 13, 2002 | 09:59 AM
CD MaroMan 91's Avatar
you could place it on the shelf and mount your amp under the seat.... that's what me and my friend did in his Camaro...
Old Jul 13, 2002 | 11:58 AM
BrokenAngel's Avatar
Or you could always take out the back seat
That could be interesting... I'm thinking of it... I don't really drive any more than 1 other person around...
:lala:
Old Jul 13, 2002 | 09:56 PM
camarochic's Avatar
Car: 86 Camaro Iroc-z, 86 Corvette
Engine: 350 TPI Camaro, 350 tpi Corvette
just put it in a standard hatch box where the t-tops would go
Old Jul 13, 2002 | 11:11 PM
MG86TA's Avatar
I dont need the hatch space anyways but for you guys who want it.. First off take off the side panel on the left, and take out the spare tire on the right.. build 2 custom boxes for each side, and put 1 sub in the side panels.. you wont be able to see the subs too.. on the left side u have to take out the box for the storage compartment though.. u should be able to fit 1 12" on each side
Old Jul 15, 2002 | 10:11 AM
ATOMonkey's Avatar
I measured it out and 1 12 on each side is a tight fit especially on the drivers side, becasue the two compartments aren't the same size. I'd go for two 10's or even two 8's if you don't want a ton of sound and just some good low end.
Old Jul 16, 2002 | 02:16 AM
Guest
Guest
Posts: n/a
i had a coustom box made for my firebird that will fit 3 12" memphis Audio HP's in the back where you would put the T-tops if you had them. and i'm telling you it looks bad ***. i have a pic of the box but the pic was to big to upload to the board is if anyone would like to see you can e-mail me for a pic. Also Q-logic makes coustom boes for 2 10" or 2 12" they will fit where the t-top bag goes and they look like the box was made with the car. they are sweet looking the only bad side to them are that the sub fire to the front of the car. but they do also have a tilt to them so they fire kind to the front top of the car. if you see the box i'm talking about you will understand. Also R/T makes a box for the back of F-body's i took a R/T box and mad some mods to it to get my 3 12"s in it. but if anyone wants to see my box e-mail me MGS8509@attbi.com
Old Jul 16, 2002 | 01:40 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Single 12W6 and 2.25 cu. ft. right here:
Old Jul 19, 2002 | 03:23 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
I built a small box for the sparetire compartment. here are some pics.
Brian
Old Jul 19, 2002 | 03:24 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
the other
Old Jul 19, 2002 | 03:26 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
REZN8R, that is a pretty sweet setup. Does it just take up the part above the gas tank, or does it extend into the trunk space?
Brian
Old Jul 19, 2002 | 03:31 PM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Thanks! The box was just above the gas tank. The amp rack had to come out and extend into the well. I ended up selling that system so I could reconfigure and work on something in fiberglass. I'm still in the process of building the fiberglass well box.
Old Jul 19, 2002 | 11:05 PM
87350IROC's Avatar
Car: 87' IROC
89blackgta,
Doesn't the sub hit the carpet right in front of the sub?
Old Jul 22, 2002 | 05:04 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
87350IROC,
I was in there pretty snug and then i let my wife drive it. now I have a grill on it so that it doesnt crap out. I have to keep this crap setup until she gets a tahoe or a yukon, then I can take up all the space I want. I hope to have two type R 12's in it when she lets me
Brian
Old Jul 22, 2002 | 05:30 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Its back there but what happens when you get a flat? Pop on the old radio? :sillylol:
Old Jul 22, 2002 | 05:32 PM
89blackGTA's Avatar
Car: 89 Black GTA
Engine: 5.7 TPI
That is why I have AAA
Brian
Old Jul 29, 2002 | 01:17 PM
MG86TA's Avatar
all AAA can do is change your tire for you or tow it home.. if your already down 2 free tows, you only have 1 left.. Also, 3 words.. FIX A FLAT .. in the can
Old Jul 29, 2002 | 04:16 PM
deadtrend1's Avatar
FIX A FLAT is baddddddd. Buddy works at Sears Auto and showed me the inside of a rim after fix a flat was used. It left all kinds of stuff on it.
~Tim
Old Jul 29, 2002 | 05:18 PM
mudaholic's Avatar
you cant just scrape it off the rim?
Old Jul 30, 2002 | 12:15 AM
deadtrend1's Avatar
it gets really hard and will actually make little cracks in the rim. They are small but still not a good thing.
Old Jul 30, 2002 | 01:03 AM
mudaholic's Avatar
i seeeeeeeeeeeeeee.. thats no good
Old Jul 30, 2002 | 01:08 AM
caleb's Avatar
Car: 89' Iroc
I am a tire tech at american car care, Fix a flat is just fine to use, BUT it must be removed from the tire within 48hrs or it starts to build up on the rim, and starts to eat into the inside of the tire, often making it impossible to patch. Fix a Flat is meant to get you to a station where the tire can be fixed, its not to be put into the tire and just run the tire till it really pops!
Frozer!!!
Jan 19, 2024 04:55 PM
Jake_92RS
Jan 28, 2020 10:37 PM
michealleger
Aug 26, 2015 03:29 PM
Fronzizzle
Aug 9, 2015 01:15 PM
