85 TA RPO codes, Canadian dash?
My first post to thridgen! I have a 1985 TA I bought in 1989. Here are some questions I have about the car.
1. The fuel gauge does NOT have "unleaded fuel only" on it.
The temp reads "40 105 125" which I think is C and converts to "104 221 257" F. The oil pressure reads "0 200 400" which I think is kilopascals and converts to "0 29 58" psi. RPO code Z49 reads canadian export. I think this car either was supposed to go to Canada and didn't make it or came back. The speedometer is normal with MPH outer ring and KPH inner ring. I'm thinking the speedometer might have been replaced. Anyone else see anything like this?
Z49 : EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
2. Any idea what a "spring, computer selected" is?
6ZW : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
It had 13K when I bought it. It now has 98K. Its been a great car. Decoding the RPOs and reading some posts really gave me alot of insight into the car. I'll try to post some pictures.
Here are all the RPO codes:
AAA : 4-WAY MANUAL SEAT ADJUSTER
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
B20 : ORNAMENTATION, INTR, LUXURY
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B67 : CONTAINER, RADI0 CASSETTE TAPES
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C49 : DEFOGGER, RR WINDOW, ELECTRIC
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DK6 : CONSOLE ROOF, INTERIOR
D02 : PAINT, ENAMEL MASTER
D35 : MIRROR, OUTSIDE REAR VIEW
D42 : SHADE, RR COMPT SECURITY
Unable to locate code D6F in our database!
Unable to locate code D60 in our database!
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
E5Z : SPEEDOMETER ADAPTER (DELETE)
Unable to locate code E7Z in our database!
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
GW6 : AXLE REAR, 3.27 RATIO
J50 : BRAKE SYSTEM, POWER
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K90 : GENERATOR,108 AMP
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
Unable to locate code MX0 in our database!
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
Unable to locate code N0D in our database!
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N33 : STEERING COLUMN, TILT TYPE
Unable to locate code QAC in our database!
TR9 : LAMP, GROUP
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UT1 : TONE GENERATOR, WARNING
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U23 : CLUSTER, INST, TRIM ODOM
U25 : LAMP, INTR, RR COMPT, COURTESY
U27 : LAMP, INTR, I/P COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
U73 : ANTENNA, FIXED, RADIO
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : ANTENNA, FIXED
WS4 : MODEL CONVERSION, TRANS AM
Unable to locate code WU5 in our database!
WW4 : APPEARANCE PACKAGE, AERO #4
W62 : ORNAMENTATION, AERO PACKAGE
Unable to locate code W82 in our database!
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Y99 : SALES, HANDLING PKG
Unable to locate code Z31 in our database!
Unable to locate code 190 in our database!
19Q : MOLDING COLOR (BLACK)
19U : PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
70B : TRIM COMBINATION, CLOTH, DK MAPLE RED (B) (91)
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
80A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I : INTERIOR TRIM, MED DK GRAY (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
84P : WHEEL COLOR GRAY (91)
9NM : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
Unable to locate code D6O in our database!
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NOD : ASSEMBLY PLANT, NORWOOD, OHIO
Unable to locate code 19O in our database!
TR9 : LAMP, GROUP
T96 : LAMP, FOG
YS1 : SEAT,RR CUST
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
1. Sounds Canadian to me. The water temp is in Celcius and the oil pressure is in kilopascals.
2. All thirdgens had "computer selected" springs. The computer would look at the options being installed on the car and decide which springs should be used to get the correct right height and handling for the weight of the car.
I have an 84 Recaro that was sold in Canada. It has the Z49 also. As for your speedo--maybe a change of plans was made in the final assembly. If the speedo was changed at a later date you should be able to tell if you look carefully at the attaching hardware. Tools do leave marks!
As for the mystery RPOs, here's the scoop:
D6F -- Never heard of this. Are you sure it's not D68 which is Outside Remote Sport Mirrors? (D codes deal mostly with things like mirrors, decals, stripes, sunshades, consoles, spoilers, etc.)
D60 -- Trim Incompatability Override (Don't know exactly what this applies to. I have it also.)
E7Z -- Speedo Gear (Depends on tranny, axles ratios, etc. Mine is E5Z.)
MX0 -- Merchandising Option (A code that the factory used to identify certain option groups I think.)
NOD -- Never heard of this one and can't find any info in all my TA stuff. Are you sure it isn't NO9 which is Locking Fuel Filler Door?
QAC -- This will be the tire size. My Recaro is QYZ (215/65R15) and my 15th Ann. is QDZ (245/50R16)
WU5 -- Credit in lieu of Fuel
W82 -- Canada Billing - Extra Fuel
Z31 -- Advance Price Sheet (Cost a total of $.50!!)
190 -- This is a color code. 19 is GM black and the 3rd digit/letter refers to the specific body part. I'm not sure is yours is "O" or "Zero", as it does make a difference.
I just checked my Firebird ID Numbers catalog again and found the following:
MXO -- Transmission, Automatic, 4-Speed w/Torque Converter Clutch. Does this sound right for your car?
QAC -- Should be 235/60VR15 Steel-Belted Blackwalls. (I found this under 1986 codes)
Here is an update on the RPOs:
D6F - I double checked. This is on the sticker.
Correct on both. I have an auto 4-speed and the car came with 235/60/VR15 Blackwalls (Goodyear Eagles).
190 - I was wrong. This is really 19Q:
N (letter O) D: Correct for Norwood.
N (zero) D: Not on sticker. I put both in since I didn't know the middle character.
All of the other codes filled in on the replies are correct for the car.
Thanks for all the information!
Does having a Canadian car mean any added/deleted emmisions equipment? Any other added/deleted features?
Hey there, TransAm1985 -- sweet looking wheels you have.
NOR makes sense for Norwood. Silly me for not thinking of it.
The RPO sheets had either NOR or VAN (Van Nuys plant). Your VIN will confirm this if it really is the case -- 11th digit should be N.
As for Canadian differences, I can only speak for the two 84s that I have. My Recaro was sold in Canada and my 15th was sold in the US. Both have identical powertrains and equipment and the same emissions sticker on the rad shroud (XJS). I do see in my GM parts books, however, that in certain sections such as carbs and emissions there are a few parts such as fuel evaporation canisters listed as "Export/Canada" for certain engines such as the 305H. (Both of my cars have the H.O. 305G L69 which seem to not be differentiated between countries.) What engine do you have? I can check and see what specific things an '85 powerplant might have if it were Canadian.
The RPO sheets had either NOR or VAN (Van Nuys plant). Your VIN will confirm this if it really is the case -- 11th digit should be N. As for Canadian differences, I can only speak for the two 84s that I have. My Recaro was sold in Canada and my 15th was sold in the US. Both have identical powertrains and equipment and the same emissions sticker on the rad shroud (XJS). I do see in my GM parts books, however, that in certain sections such as carbs and emissions there are a few parts such as fuel evaporation canisters listed as "Export/Canada" for certain engines such as the 305H. (Both of my cars have the H.O. 305G L69 which seem to not be differentiated between countries.) What engine do you have? I can check and see what specific things an '85 powerplant might have if it were Canadian.
Car: 1982 Recaro T/A
Engine: LU5 CFI 305 V8
Transmission: TH-200C
Axle/Gears: 3.23 F-body Fanatic: Yes
D6F - SPEEDOMETER DRIVEN GEAR
great looking car you have. post more photos if you have them
Thanks. The engine is a 5.0L TPI V8. I decided I wanted the TPI engine at the expense of getting a manual transmission. The manual only came with the carburated engine. The TPI auto was also easier to find since I was buying used.
