I need help with my WinALDL cable ASAP!!! Please!!!
Old Jul 21, 2002 | 02:26 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
I'm really at my ropes end with my car since I rebuilt it. It has a nasty loss of power above 1500 and I need to get my WinALDL to work on it so I can see the data.
I already did the cable 3 times. The first two times I did it just like the schematic and the written instructions in another post said and it didn't work. The third time I decided to change what pins the various connections went to because mine didn't look like the one in the picture in the article. Before I got my hands on a laptop I made the cable and I accidently used a male DB9 connector. The laptop is setup to receive a female connector so I had to use a male to male adapter inbetween the laptop and cable. This is why I thought switching my connections would help.
I also have tried each time with the 10K resistor in the ALDL connector and without it in the ALDL connector.
Somebody please give me a suggestion. I need to get this data tonight so I can get my car running right this week.
Old Jul 21, 2002 | 04:15 PM
funstick's Avatar
not sure how a 160 buad cable is gonna talk to a 8192 buad ecm.
the 8192 is asyncronous i believe. it requires a much more sophisticated cicut than the 160 buad ecms.
Old Jul 21, 2002 | 05:14 PM
Car: 89 IROC-Z
Engine: 383
Here comes my computer ignorance......what in the world does that last reply mean??
I figured that making the cable would be a snap. I mean come on 2 resistors and a transistor for ***'s sake!!
Someone help me figure out what the hell is going on here. I want my car running right!!!
Old Jul 21, 2002 | 05:48 PM
funstick's Avatar
make sure you dont have the trnsistor upside down.the 165 ecm is 8192 buad i dont think itll work with the single transistor circut. youll need the 2 transistor circut. and that works sometimes.
Old Jul 21, 2002 | 06:08 PM
Car: 89 IROC-Z
Engine: 383
Woah.......what two transistor circuit?? The only cable diagram I saw had 1 transistor.
I'm fairly certain I have it in the correct way....the diagram on the package looked like this:
ll ll
ll ll
l l l
l l l
l l l
l l l
E B C
I assumed that the diagram meant that with the rounded side of the transistor up the wires were in the emitter, base, collector order. Was I mistaken??
Old Jul 21, 2002 | 08:29 PM
funstick's Avatar
ok heres the correct 160 buad schematic.
heres the other schematic for the max232 cable for 8192 ecms.
Old Jul 21, 2002 | 08:32 PM
funstick's Avatar
for the 8192 buad ecms youll need the moates software. heres the link.
http://members.***.net/craig.moates/zips/ECM851.ZIP
Old Jul 21, 2002 | 08:46 PM
Car: 89 IROC-Z
Engine: 383
Hmmm...I think it's safe to say that I'm thoroughly confused. I guess I should have paid better attention in high school electronics class. How do I know what baud ECM I have and if it's not the 160, howcome WinALDL says it supports 86-90 TPI cars??
Also the scematic for the 8192 baud connector shows the wires from the transistor in the opposite order than I perceived them on the packaging diagram I had. Maybe I should try reversing my transistor tomorrow night???
Otherwise I may have to just take it to a dyno shop next weekend. (Not that it would be all that bad to have my car dyno tuned anyway )
Old Jul 21, 2002 | 09:28 PM
funstick's Avatar
im not really sure why it supports the 7165 ecm youhave. i wondered that to as i have winaldl. i know yr ecm has different communications needs than a 160 buad becuase its 8192.so you need to get the right cable. they can be purchased here.
http://www.akmcables.com/ic.htm
Old Jul 21, 2002 | 11:45 PM
Morley's Avatar
Yes the "simple" Winaldl cable will work with the 165 ECM, mine does just fine. the 165 will communicate at 160 or 8192.
Old Jul 22, 2002 | 01:30 PM
funstick's Avatar
i did not know that morely thanx for the heads up. ive just been using the max232 cable.
Old Jul 22, 2002 | 04:38 PM
Car: 89 IROC-Z
Engine: 383
So hold on......do I need a different cable or not??? All of these numbers are confusing the hell out of me!! I'm a damned finance major.....we deal with different kinds of numbers.
Old Jul 22, 2002 | 06:02 PM
funstick's Avatar
go over yr cable schematic agian. somthing is wrong. did you miss position the pins on the db9 connetor.
Old Jul 23, 2002 | 07:50 AM
JohnnyIROC-Z's Avatar
Car: 1991 T-Top RS
Just so you all know, the 2 transistor circuit works fine. So does the 1 Transistor. That's what I use with Moates software on my 87 IROC and it works beautifully. It's an EASY circuit to make.
Old Jul 23, 2002 | 09:02 PM
Car: 89 IROC-Z
Engine: 383
I Got It!!!!!
Thank you guys. I got the cable to work last night!! The transistor was in backwards!! I still think the package was labeled wrong. I even think I found my major problem tonight using the WinALDL software. Now I think I'll send my chip back with the BLM tables for some fine tuning!!
Old Jul 28, 2002 | 11:24 PM
b92z28's Avatar
730 ecm??
So which one of those diagrams would I use to make a cable to use the Moates software on a 730 ecm? Could you list the parts required to make that cable also?
Old Jul 29, 2002 | 12:11 AM
Morley's Avatar
Either of these should work, and the parts are listed in the schematics
Attached Thumbnails I need help with my WinALDL cable ASAP!!!  Please!!!-twotran.jpg
Old Jul 29, 2002 | 12:13 AM
Morley's Avatar
or
Attached Thumbnails I need help with my WinALDL cable ASAP!!!  Please!!!-akm232.jpg
Old Aug 2, 2002 | 02:59 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
The TPI ECM (1227165) transmit data both at 160 and 8192 baud. WinALDL reads the 160 baud data and Craig Moates software reads the 8192 baud data.
The 8192 baud will read more variables from the ECM, and it will read it a higher rate.
Old Sep 12, 2002 | 05:51 PM
Black88GTA's Avatar
Car: 88 GTA, 94 BMW 840, SVX, Prelude
Engine: 383 w/ Super Ram
Transmission: built 700R4 auto
edit: started new thread w/information in post
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
