Custom made a ram air setup for camaro....anybody ever tried this?
Old Aug 1, 2002 | 06:30 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
ok this is like circa 1965 Thunderbolt styling........but I figured what the ****, might as well. I removed the high beams on the camaro, got a used L69 dual snorkel air cleaner (don't ask me how I got it ) and bought some 4inch AC flexible ducting and some AC vent screens. Removed all the crap behind the high beams so there was a nice 3-4inch hole exposed, and had to move the battery over a few inches, then I bent the ac lines down as far as I could and routed the ducting from the snorkels to the holes. Then I just installed the vent screens in place of the high beams to simulate the shape of the high beams. Looks ****ing AWESOME. U guys gotta see it. I'll post pics tommorow. Car feels stronger on the top end as well.
Old Aug 1, 2002 | 11:03 AM
Jester's Avatar
Yeah I've seen that done. I personally don't believe it's worth much if anything over just running the ducts to under the car to cold air. Certainly not worth giving up high beams for.
Old Aug 1, 2002 | 12:11 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Definitely post pics
Old Aug 1, 2002 | 07:15 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
yea i did the same thing myself. i used expandable metal from work to keep the bugs out. i've got a cowl induction hood on now tho. when time permits i'm going to do some temperature tests to see which works the best. i came across abattery powered thermocouple setup and i'm going to copy the carcraft test they did with a rustang a while back.
Old Aug 2, 2002 | 05:57 AM
Car: Junk
I didnt' say it was worth anything over running the ducts under the car, I just don't see how its possible to run the ducts under the car, unless you somehow loop it over the serpentine at a 90* angle, which would look plain stupid, you still have high beams with the center lights disconnected Try disconnecting your center lights, then flick on your high beams........the outer ones get super bright. I swear I did not notice ANY difference in night time driving light with the high beams, the center lights musta been adjusted wrong anyways. Stupid digital camera needs battery's, so I'll buy some and post the pics tommorow of the track stuff. And I'll also run the car with an open element and then with the ram air to see what kinda #'s it makes. I'm sure it'll run faster with the ram air though, it just feels stronger on the top end. Car craft did this test on a 60ish falcon of one the members, and the ram air over the open element was worth 3 tenths and 2 mph. Well worth the $10 I put into it
Old Aug 2, 2002 | 04:48 PM
Car: Junk
pictures:
Old Aug 2, 2002 | 04:59 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
can't see 'em...
Old Aug 3, 2002 | 07:35 PM
Doomsday Danny's Avatar
to see it, click properties over the image and paste the link in the address bar.
I think it looks pretty slick from far away and you almost can't tell
Too bad it's not possible on a T/A
Old Aug 3, 2002 | 08:47 PM
Mark305TBI's Avatar
Let's make this easy on anyone else who wants to read this...cutting and pasting is a bee-atch.
Attached Thumbnails Custom made a ram air setup for camaro....anybody ever tried this?-camweb2.jpg
Old Aug 3, 2002 | 08:48 PM
Mark305TBI's Avatar
I'm only doing two of 'em.
Attached Thumbnails Custom made a ram air setup for camaro....anybody ever tried this?-camweb3.jpg
Old Aug 4, 2002 | 01:23 AM
Car: Junk
Thanx Marc. I'm a total retard when it comes to web stuff Well good news is car ran a solid 14.0 @98mph at the track with a 2.0 ft. Bad news is I switched the edlebrock to a 750DP holley just to be 100% sure I would run the optimum times, and the dual snorkel cleaner wouldn't clear the float bowls without a little 3/8inch plastic ring spacer........which I of course forgot to bring! However I'd still say the car feels stronger with the snorkel setup, but I guess I'll have to wait till the next track meet when I have the little ring spacer installed till we can be sure.
Terrell351
Jun 13, 2021 01:13 PM
kah992
Aug 19, 2015 02:55 PM
L98GTA87
Aug 11, 2015 06:55 PM
bryan623
Aug 10, 2015 11:33 AM
