Finally found the right combo...hopefully
Old Aug 18, 2002 | 12:30 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Alright, please let me know what you think about this. It has taken me all summer to find P#s and prices from different competators, but I have done it.
Here it goes.
*327 Chevy SB -$200
*Assembled Vortec Heads -$250ea.
Pace advertises .480" lift , but Scoggins-Dicky sells the same
heads for $220ea. with only .440" lift.....what is up with this?
*Self-Aligning Rocker Arms -$60
*Vortec Performer intake -$158
*Comp Cams SBC hydraulic flat tappet cam Specs: -$100
Adv. Dur. 256/268
Lift: .447/.454
LSA: 110
RPM Range: 1000-5200
*Bored out/modded TBI, maybe 350 injectors-$who knows
*3" exhaust w/ cat delete +headers and custom Y pipe-$???
*Home-made TBI/Carb adaptor plate -$???
*Complete rebuild of 327 -$???
Seeing the look on my face when I start it up and go from a 170hp 305 to a 350hp 327.....well, lets just say I will probably wet my pants.
So in other words, it will be priceless for you.
If you have any suggestions, please let me know. Hopfully I am not forgetting anything.
Old Aug 18, 2002 | 01:13 AM
evil t/a's Avatar
Re: Finally found the right combo...hopefully
Here it goes.
*327 Chevy SB -$200
Adv. Dur. 256/268
Lift: .447/.454
LSA: 110
If you want to even come close to 300 horsepower you are going to need a better manifold and more cam .
Old Aug 18, 2002 | 03:46 PM
gettaway305's Avatar
Car: 1989 Camaro RS
hey you may be able to save money and gain power by buying a regular manifold used...on GMs website, it says you can drill and tap new holes in regular manifolds to fit vortec heads.
http://www.gm.com/cgi-bin/pr_display.pl?367
Old Aug 18, 2002 | 08:50 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
The 327 will make about the same HP as a 350, just less torque. That said the setup you listed would make about 310 hp, unless your high compression were maybe you'd get 330hp, Anyway I love my vortec heads, get em' ported too, screw people who say the're good enough stock. But as far as intake go with the edelbrock air-gap performer rpm vortec, I have this one and I love it, It stays cool, so now for the first time ever I don't lose power when my engine gets hot. I you wanna make power though (350hp) your gonna have to go way bigger cam, I would put something like a 292 with 510 lift, now thats sounds big but you drive a car (its lite) . My 270/280 comp gets my truck up and moving right from the line to the topend.
P.S. Just get the heads valve bossed cut down at a head shop, so you can take huge lift.
It would be to bad if you made nice 327 and just put in a peanut cam like you listed.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
middian
Sep 5, 2015 01:42 AM
rudolphschenker
Sep 4, 2015 02:41 AM
Formula_88AE
Sep 3, 2015 01:47 PM
