Urgent, I need HELP!!
Old Aug 30, 2002 | 08:38 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Ok, well took the car to the track tonite.
On a G-Tech before cam/intake/gears/and cat-back ran a 15.41 @ 92mph
"" after gears/cat-back ran a 15.32 @ 95 mph all on G-Tech with a badly shifting tranny.
Took the car to the track finally. Hopin for low 14s.
First run with babyin the throttle off the line and engine temp at 225* (yikes) I ran the following
also the tranny shifts perfect now
60' 2.309
1/8 10.460
1/4 16.277
mph 84.91
2nd run, WOT off the line and engine temp at 180* ran the following
60' 2.247
1/8 9.958
1/4 15.491
mph 89.37
The weather out was like 65* or so with relatively low humidity.
WTF is wrong with my car, I just added a Comp 268XE cam .477/.480 lift and Stealth intake.
Think the carb could be that out of tune now, I know I need to check the timing (I think I might be runnin a bit lean, since the car is heatin up so much).
I'm runnin a 160* stat with an aluminum radiator, and it got up to 225* on my first run.
Also, 2 of my plug wires might need to be changed ( i threw them on since 2 of the old ones were burnt, and the 2 I put on are kind of old).
So, please help me, my brother is ready to buy me a new carb, he thinks I should be runnin high 13s at least.
Oh, yeah, and when the car got up to around 220* it was hard to start.
Old Aug 30, 2002 | 10:14 PM
Car: 99 Formula
Axle/Gears: 342
One other thing, I have spray paint on almost all my plugs like where the wire hooks too. Think this is hurtin, I've heard since there is no lead in paint anymore, it shouldn't.
Old Aug 30, 2002 | 10:37 PM
Jester's Avatar
Get a Holley
sorry...I had too.
Old Aug 30, 2002 | 10:51 PM
Jester's Avatar
Plus, besides needing to get a Holley..you just listed about 5 things that are hurting you. You're running too hot, your plugs have paint on the terminals....your wires are old/possibly bad, you think it might be lean, and you don't know what your timing is. Start fixing all the things you do know before you start begging for URGENT answers about WTF is wrong.
BTW...lead is a conductor. if the paint was lead...that would be better...not worse.
Old Aug 31, 2002 | 01:04 AM
Kevin Johnson's Avatar
"BTW...lead is a conductor. if the paint was lead...that would be better...not worse."
Only if the terminals were the only things painted. Otherwise it would short them out by creating a path over the porcelain insulator to the block.
Just put new ones in or strip the old ones if they are some high dollar plugs.
Old Aug 31, 2002 | 04:40 AM
Car: 99 Formula
Axle/Gears: 342
Yeah, I actually started realizin some things that were wrong when I was typing it up. I'm goin to check some things when I get off work today and see what's up. But I leave for college tomorrow mornin, so I doubt I'll have time to figure it out.
Old Aug 31, 2002 | 04:57 AM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Mark, You just installed a new cam and you dont know if the timing is set right? What is up with that? Start fixing all the possible problems like jester said. You should be running 13's. Hell your motor is clean enough to run 13's without fuel!
Old Aug 31, 2002 | 04:58 AM
Engine: 406
you lose 2000 posts for this one.......
Old Aug 31, 2002 | 06:35 AM
Car: 99 Formula
Axle/Gears: 342
LOL. Yeah, we fired the car up after the install and it ran fine, I guess it just got lost in all the excitement and 100* weather out.
Old Aug 31, 2002 | 07:45 AM
kevinc's Avatar
Car: 1982 Z28
Timing has a huuuuge impact on engine performance. When I swapped on my Stealth Ram last month I bumped the dist while tightening it down or something, knocked the timing back to 4deg BTDC instead of the 10deg BTDC my PROM is set for.
I took it for a test drive and the gas pedal was like a wet sponge...mash the gas and blah. Re-checked the timing after some troubleshooting, saw the error, corrected it, and bingo it's like a whole new engine.
Whip out your timing light and get to work.
CALIROCZ28
Sep 26, 2004 05:47 PM
CALIROCZ28
Northern California
Feb 29, 2004 07:32 PM
CALIROCZ28
Southern California Area
Feb 27, 2004 12:43 AM
