Want advice for engine
Old Sep 6, 2002 | 11:49 PM
86TATpi's Avatar
I want to get a 5.7 tpi for my 86 TA. I was just wondering what I would need to get so that it would run mid upper 300 horse. And would the tpi unit from a 305 fit the 350? thanks
Old Sep 6, 2002 | 11:57 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
this one is pretty popular. youll have to burn a prom and upgrade your injectors and a few other things at teh very least to get any sort of return on your invesment. Yopur present tpi unit will not fit because of the older intake face, good time to upgrade it to a better flowing unit.
Oh, forgot to metion this newer engine has the one piece rear main seal, i think '86 was the intoduction of the one piece so you may or may not have to get a different flywheel/flexplate.
Old Sep 7, 2002 | 12:09 AM
flyway190's Avatar
That looks like the same one I've got, with a different cam.
Old Sep 7, 2002 | 12:17 AM
Car: 88 Camaro SC
Engine: SFI'd 350
it has the cast iron tpi heads in addition tot he cam. No swirl ports like the lo5. Short block is the same.
Old Sep 7, 2002 | 12:36 AM
flyway190's Avatar
Oh ok, I was wondering if they wanted $350 more for a different cam. That cam has the same specs as the Crane CompuCam 2032 by the way.
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
dutch930
Sep 11, 2015 06:58 AM
E Rod
Aug 28, 2015 05:17 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
