Transmission Cooler Observations
Old Sep 9, 2002 | 10:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
This weekend I replaced the cooling lines on my 700R4 and decided to do an experiment. I connected the stock in-rad cooler alone and went for a drive around town. The fluid temperature in the pan reached about 210 F pretty quickly and stayed there. I returned home and connected the auxiliary cooler inline after the factory cooler. It's some kind of small, cheap 4-pass copper and aluminum thing in front of the rad, nothing fancy. I went for the same drive but this time the fluid only got up to about 160 F, and cooled back down to around 150 F when I got back on the highway.
Old Sep 10, 2002 | 10:20 AM
esams's Avatar
That's sweet. It brings up an urgent question: I just bought a Griffon radiator without the tranny cooler by mistake, and it should be here today. Do you think I can keep the radiator and run an external one only, or should I send it back?
Old Sep 10, 2002 | 11:19 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
I would just run the largest external cooler you can fit.
Old Sep 10, 2002 | 12:09 PM
esams's Avatar
Will do. Thanks.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Denricci22
Sep 18, 2015 09:02 AM
Saxondale
Sep 15, 2015 06:42 PM
scottmoyer
Sep 7, 2015 07:06 PM
apie2546
Sep 5, 2015 07:40 PM
