boost valve install????????
Car: '88 GTA
Engine: L-98
ok i need to know where the hell the boost valve is and is there any special instructions to in stall it........ i have the pan dropped and the filter out so if you know your reply would be greatly appreciated thanks
So where is it located?
So where was it located and was it hard to install. Am thinking about this modification as i need to change the filter in my tranny. Might as well kill 2 birds with one stone...
Car: Camaro IROC-Z '89
Engine: 350 TPI /w Procharger P1SC
Transmission: TH700R4 with Transgo shiftkit
Axle/Gears: 2.77 Borg Warner
Re: So where is it located?
Remove snapring, and remove old boost valve and reverse boost valve and spring.
Install new parts, make sure to install them in the right order, reinstall snapring, done.
toronto formula
Nov 10, 2015 06:17 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
