Rolling fenders.........????
Old Sep 16, 2002 | 09:06 PM
Doogie92Z28's Avatar
I just bougt a 1992 Z28 ragtop. I put the 17x9.5 chrome Zr1 wheels wit 275x40 tires from my other thirdgen on it. Right now the springs on the passenger side have sagged almost 1 inch. I am going to put an Eibach prokit on it with new kyb shocks and struts. I do not want to have a problem with rubbing saying that i have a custom sub box back there making it bottom out. I am trying to find someone who knows where i can get my hands on a fender rollr or if you kow what i can use to do it. Down the line i am going to put the 18x9.5 C5 weels on it and i dont want to have a rubbing problem. I would say 18's all the way.
thanks
doug
Old Sep 16, 2002 | 11:28 PM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
The old method of rolling a fenderlip involved a Louisville Slugger and a two friends. One friend to weigh down the corner of the car and the other to work the bat. You (the third person) are responsible for slowly driving the car back and forth in the driveway.
Old Sep 17, 2002 | 06:09 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
"...springs ... have sagged..."
There's the clue to the real answer right there.
How about a new set of rear springs? THey're about $75 and take a good solid 20 minutes to install in your driveway. A much superior solution to a problem, rather than a destructive work-around for the symptom.
Old Sep 17, 2002 | 06:57 PM
Grey Goose's Avatar
Car: 1990 RS
Engine: LO3 TPI
Transmission: W/C T5
To roll the quarters correctly you will have to cut the inside of the panels every 2-3 inches. Then tap them with a mallet forcing them against the inner panel. If you don’t you will find the lip will only wrinkle and not roll. Be extremely careful the paint will chip but it works
Old Sep 17, 2002 | 11:48 PM
wavslav's Avatar
I think that is really good advice,
On my '84 Hillbilly Hell on Wheels road race car, I just took a 3 lb sledge and started whacking away, but I think it would look much better of you made cuts so it rolls easy.. You could also use a 2 by four against the lip to shield the fender from the hammer.
Redd, Thats a great looking sig pic
Evan
Old Sep 18, 2002 | 01:28 AM
TTA155's Avatar
Anybody got a link to a tech article on this subject?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
shanelique22
Oct 3, 2015 07:23 PM
FormulaEngland
Sep 30, 2015 01:50 PM
