91-92 dash cluster in 84??
Old Nov 27, 2001 | 11:54 PM
cy Z28's Avatar
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
It's either swithcing to the electronic speedo, or replacing all the stockers w/ Autometers. Doing T-56 swap in car that could do 200mph with some tweaks. I really do want a speedo, so has anyone done the swap?
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Old Nov 28, 2001 | 01:05 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I might be wrong about this but, I believe the rest of the dash would need to go w/the cluster due to redisign. I've never had the opportunity to see a complete 90-92 dash at the junkyard yet but, from the small here & there's, the clusters don't seem to look anything the same except for maybe the white plastic part the gauges sit in. I'd bet with a little time & hack work it could be done to fit almost right. The other question would be do the clusters plug in the same way as the old style ? (I certainly don't know)
------------------[*]my Formula Homepage [*]Collision P/Ns & Diagrams
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
[This message has been edited by deadbird (edited November 28, 2001).]
Old Nov 28, 2001 | 12:38 PM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I'm doing it right now, actually. Here's a picture of it partially completed:
What do you want to know?
Is it a Major PITA? Yes.
Would swapping the entire dash be easier? Yes.
Will it work with a big enough hammer, a soldering iron, and enough dremel bits? Yes.
[This message has been edited by 99Hawk120 (edited November 28, 2001).]
Old Nov 28, 2001 | 12:56 PM
99Hawk120's Avatar
Few more pictures:
You need to grind out ALL four of these supports (one in each corner, and two along the top):
Here's the right corner one done. Don't grind it down this far, you can use part of it to help locate the new cluster depth-wise:
The cluster has to have all the extra tabs and crap ground off it, and the holes along the sides filled with JB Weld or Putty of some sort:
Full assembled Cluster. Notice there is nothing holding the top of the black bezel to the cluster. The spot where it bolted to had to be removed to fit it in the dash. I'd suggest glue or silicone:
Here's how I'm bolting the cluster in to the dash (The screws actually go in from outside to inside--the hole in the dash hadn't been drilled yet in the bottom picture):
Be careful with the screw lengths. I think the length I'm showing at the top is ok, I know the bottom ones are too long...
(That should fix the images problems for good this time...)
I'll be taking more pictures later tonight.
Old Nov 28, 2001 | 10:41 PM
99Hawk120's Avatar
Here's the rest of the pictures:
These show how I put the top screw holes in. I used the stock u-nuts, ground away the front, slid it in, then replaced the plastic I ground away with filler:
Nice white paint inside for good reflectivity. Notice the orange bulbs and the u-nuts for the mounting screws:
Some grinding was needed on the four-gauge unit to clear the u-nuts:
Two problems still to fix--the visibile "non-visible area below line" wording, and the slight gap in the LL and LR hand corners that will let light get through:
The strange gray color is just on the surface... wonder what it is? I plan on painting the front plate semi-flat black so it fits with my 84 interior better... AFTER I sand down the visible words and line:
Old Dec 23, 2001 | 02:52 AM
loomdog32's Avatar
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
how i the gauge swap comming along? im planning on doin this in a '83. did u have to change from a cable driven cluster? and if u did/are how did u do it? im goin to have my car parked for a while cuz im also doin an engine swap at the same time. i also plan on changing the tranny later in the future (t56 or t5 depending on my funds when i do it). thanx.
loomdog
Old Dec 26, 2001 | 10:28 PM
un4givin89's Avatar
screw that, I just put 4th gen dash in, much easier.
Old Dec 27, 2001 | 03:32 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
un4givin - do you have pics of the 4th gen dash swap?
Elephantismo
Feb 13, 2019 12:51 AM
Kylej68
Exterior Parts Wanted
Sep 28, 2015 10:00 AM
codeysabatini
Sep 20, 2015 11:36 AM
ChristinaMarie
Sep 11, 2015 06:28 PM
andy74
Sep 3, 2015 08:41 AM
