what are these 2 electrical connections on the side a my T5 (pic inside)
its a 86 model T5 if that helps
whats is #1 and #2 for?
im going to swap the T5 in place of my 700R4, will the 700R4 connectors plug in to these?
<img src=http://groups.msn.com/_Secure/0NAAAAIARmbknALb6ZfHZ6xLZzpPdF0i5ixRMKQFd*mibuQw7ALBwohOIBWRnCFLW0ZRYTWJ93RhIbKFkuxnAgg/Image0014.jpg>
Car: 4
Engine: 6
Transmission: 5
Those are your backup light switch. I don't think the 700 harness plugs in directly, but it may have the right wires; they'll be blue and dark green. If it has those, just cut them off from the 700 plug, and put the right kind of Weatherpak connector to mate to the T-5 BU light switch on those 2 wires.
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
The number 2 connector is for the VSS (it provides the signal for your speedometer.) If you have a mechanical unit there is a product available to convert the signal to a machanical drive. I do not remember the link. If you e-mail me I will try to find it.
BILL
BILL
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Originally posted by 87 B4Z
being that the tranny is a 86 model it should be cable driven speedo gear, wright?
If you have an 86 camaro you have a mechanical setup. You will need to get the conversion I mentioned earlier. I will try to dig up the link. Otherwise go to skutle.com and look for the T56 swap page.
BILL
BILL
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Who said anything about a T56? Just pull the VSS out and replace it with a cable driven speedo housing and gear.
Car: 4
Engine: 6
Transmission: 5
Sorry, I didn't scroll to the side and notice #2...
For the mechanical there's no "conversion" necessary; just get a speedo gear housing out of any older GM car with one that size, which has been used basically forever up until the T-56. Doesn't have to be a Camaro or Firebird, could be a truck or whatever, doesn't have to be a T-5, could be a 3- or 4-speed, doesn't matter, they're all the same.
You'll probably need to go to the dealer and buy the right speedo gear for your rear end gear and tire size.
Hotrodboba400
Dec 10, 2019 07:07 PM
connection, connections, connector, electrical, gm, img, pictures, plug, side, t5, t56, tranny, transmission, transmissions, weatherpak, whats
