Serpentine Belt Change
Old Nov 16, 2002 | 03:52 PM
iroczrockz's Avatar
Car: 91 RS Camaro
I have heard that taking out the air pump will not effect the "check engine soon" light. With that said I plan to do an experiment on the belt sys. If I could figure out how to add an image to this text from a drawing I would show a pic, but anyhow I am planning on bypassing the a/c and air pump pulley all together and routing the new belt around the idler pulley and running it back to the alt. pulley. Has anyone tried this? Do you think it will work? To see a bad drawing of this go to my webpage and select serpentine belt experiment.
Old Nov 17, 2002 | 12:37 AM
MdFormula350's Avatar
heres a pic of the smog pump delete..
https://www.thirdgen.org/newdesign/t...rpentine.shtml
Old Nov 17, 2002 | 02:57 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Thanks for that info! I am thinking of taking it a step further though. I already have the a/c disconnected, so I think I will use the tensioner as a 180* reverser for the belt. If that makes sense. I am going to take a measurement tomorrow and get a belt and try it if time allows.
Old Nov 17, 2002 | 01:38 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I see what you're saying. I thought about that too but didn't see a feasible way without major changes. Remember that the flat side of the serp belt rides on the tensioner. Short of welding rails on both sides of the tensioner to keep the belt on the pulley I don't see how it would work.
That'd be one heck of a short belt to keep the proper tension.
I think it is possible though.
Old Nov 17, 2002 | 08:20 PM
iroczrockz's Avatar
Car: 91 RS Camaro
I wondered about that with the tensioner too but, it has a lip around the tensioner. I was worried about the belt slipping off. After seeing that lip though is when I thought it should work. I haven't had a chance today to work on the car so as soon as I do I am gonna try it out.
Old Nov 18, 2002 | 06:56 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Well so far success, success, success. I bought a 65" belt (cheap one) pt#650k6-5060650DR, from Advance Auto. It cost me $11.99, and I routed it around the idler and back to the alt. and it ran fine. No check engine soon light or anything. I haven't taken it out on the road yet, but it seems like it is gonna do just fine. It actually seemed like it ran smoother. This could be a experiment to take to the track someday and see what kind of difference it makes to eliminate the air pump and a/c. Let me know if anyone else tries this please.
Old Nov 19, 2002 | 12:46 AM
rezinn's Avatar
Interesting. Do you have a picture? I was worried about putting that much belt on the tensioner.
Old Nov 19, 2002 | 01:12 AM
iroczrockz's Avatar
Car: 91 RS Camaro
I am at work now but tomorrow I will try to post a picture. I have never posted a picture and as soon as I figure it out I promise I will get it on here.
Old Nov 20, 2002 | 12:20 AM
jizzyz28's Avatar
hey man i finally found the right size belt for my 350 after removing the smog pump. the dayco part number is 5060960
Old Nov 20, 2002 | 12:44 AM
iroczrockz's Avatar
Car: 91 RS Camaro
You still have your a/c don't you? Reason I say that is because I think your belt is a 96" belt according to your part number. I still haven't had a chance to get a photo of my belt sys. due to a messed up dig. camera but my belt was 65" long and it eliminated both the a/c and the air pump. Still working on getting a photo.
Old Nov 20, 2002 | 03:35 PM
camaroracer1's Avatar
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
I just rerouted my belt so that it bypass the a/c and air pump. I used a 70inch belt. I just went to the track this past weekend. I gained about .10 in the 1/4 and lost about .08 on my 60ft. time. The idea of rerouting the belt works just fine.
1988 Iroc-Z
5.7 tpi, 700r-4 with b&m shift kit
Hooker Super Comp shorties
Flowmaster 80 series muffler
Holley AFPR
MSD 6 AL with 8mm Heli-core wires
NGK spark plugs
K&N with homemade ram-air induction
Ported Plenum
Best e.t. 14.20 @97mph
60ft. 2.14s
Old Nov 20, 2002 | 04:20 PM
iroczrockz's Avatar
Car: 91 RS Camaro
belt pic is not working still trying.
Old Nov 20, 2002 | 04:53 PM
iroczrockz's Avatar
Car: 91 RS Camaro
new routing.
Old Nov 20, 2002 | 05:09 PM
rezinn's Avatar
Cool. May be worth buying a cheap belt to test that at the track.
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
