STB for '92 bird 3.1
Old Nov 19, 2002 | 02:12 PM
Topless92's Avatar
Does anyone know of a Strut Tower Brace that will fit my '92 bird with the 3.1 V6?
Old Nov 19, 2002 | 02:23 PM
LT1guy's Avatar
Car: 1987 Trans Am
Just don't buy the Edelbrock, its crap and will hit your hood. Jamex will probably work, if you can find one.
Old Nov 19, 2002 | 02:35 PM
Topless92's Avatar
Thanks I don't realy care for the look of the Jamex. Too simple. Thanks for the heads up on the Edelbrock though.
Unless someone can tell of one that fits, I'm leaning toward getting one custom made by...... probably a roll cage builder. Seems like it doesn't need to be incredably strong. It's reinforcing sheet metal FGS.
Dean
Old Nov 19, 2002 | 02:40 PM
AFreaknGoodTme's Avatar
My Edlebrock 3-point fits perfectly and has never hit the hood. Must be the installer.
Or perhaps I notice from your pics that you have an aftermarket hood. Maybe that could be your difficultly.
Old Nov 19, 2002 | 02:46 PM
LT1guy's Avatar
Car: 1987 Trans Am
It has nothing to do with the installer...it hit the stock hood as well, and a friend with a GTA had the same problem. Maybe they changed the design, who knows, but regardless the Edelbrock strut tower brace that I have does not fit the car. Its not like you could install it wrong and get the crossbar and the two rear pieces to line up.
Old Nov 19, 2002 | 02:50 PM
I someone installed the 3-point support rod from the firewall onto the top side of the crossbar and the bolts upsidedown you could certainly have a problem.
I've purchased mine about 3 years ago.
Old Nov 19, 2002 | 03:00 PM
LT1guy's Avatar
Car: 1987 Trans Am
It doesn't hit in the rear...the brackets are too tall, and even with the front bar dropped the bolt heads occasionally hit the hood. Got any pics of your install? I'd love to see if there are any differences in the bar, or if possibly Edelbrock sent the wrong mounts.
Old Nov 19, 2002 | 03:19 PM
Another hillbilly picture compliments of AFrikinGoodTime. I'm waiting for digital cameras to be perfected and the price comes down. 10 years ago I purchased a top of the line Sony Hi8 camcorder for $1800.00. Today you can buy a better unit for $300.00. I refuse to make that mistake again.
Old Nov 19, 2002 | 03:20 PM
SAEspinz80's Avatar
i have heard that BMR makes a bar that fits....BUT, needs a small shim underneath the bar on each strut tower to clear the TB. but they come in a variety of colors. here's a pic from someone's car that i had saved when i had intended to do it. but i never have, so just take that as a warning. but this person had it work.
I apologize, i don't know who's car this is
Old Nov 19, 2002 | 03:21 PM
SAEspinz80's Avatar
close up of shim
Old Nov 20, 2002 | 07:37 AM
LT1guy's Avatar
Car: 1987 Trans Am
Thats exactly how hers is...and it hits, at the tops of the brackets and occasionally on the tops of the bolt heads.
Old Nov 20, 2002 | 09:24 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
heres the one pictured above. Decent price too!!
http://www.bmrfabrication.com/F3-chassis.htm
Old Nov 26, 2002 | 05:50 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Originally posted by SAEspinz80
iI apologize, i don't know who's car this is
That's my car!
Old Nov 27, 2002 | 12:46 PM
SAEspinz80's Avatar
AH yes....it rings a bell...haha. Kept the pictuers way back when I was thinking of adding one myelf.
Elephantismo
Feb 13, 2019 12:51 AM
87v6Bird
Jul 1, 2018 04:12 PM
87v6Bird
Brakes
Oct 4, 2015 07:37 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
