flowtech headers
Old Dec 15, 2002 | 06:24 PM
bubbakutz's Avatar
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
flowtech headers
hey, im deciding now that i want to get some headers.....i really dont have much money now that i bought all christmas presents and was thinking about flowtechs from jeg's......anyone have them? plus do the come with the y pipe from jeg's?
thanks
Old Dec 15, 2002 | 06:27 PM
Killogy's Avatar
Car: 87 Firebird Formula
I put the flowtech shorties on my car about a month ago. They went on real easy and so far are holding up very well. Jegs carries the y-pipe, but I don't remember the part number. For $200 for the whole package it can't be beat.
Old Dec 15, 2002 | 07:03 PM
bubbakutz's Avatar
Engine: LG4
200? well the headers are 90....how much is the y pipe?
Old Dec 15, 2002 | 07:06 PM
Killogy's Avatar
the y-pipe is around $100, but I did COD so it was a little more. But its about $200, give or take, for the headers and y-pipe.
Old Dec 15, 2002 | 09:30 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, I would save up another $150 and get Hooker headers or even Edelbrocks.
The flowtechs are 1.5 primaries which will be fine for a near stock 305, but if you ever upgrade in the future, it might start to choke the engine.
Old Dec 15, 2002 | 10:15 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I have the coated flowtechs (about $370 for headers and y pipe) and I am not satisfied. The fit was ok but the flange was bent and I had to torque the crap out of them to lay flat on the heads. I had the 6 layer or so percy's aluminum gaskets and the thikness alone of those stopped any leaks. The only problem really is that the collector flange leaks like a mother. I even bought the really expensive copper gaskets for this. I only hear the leak under hard throttle but it sounds annoying. It makes a wierd mettalic hissing sound. I got so mad that I ended up over torqing the collector bolts and bent the collector flange so I think I made matters worse. However, They look great (especially with the coating) and perform rather well. I really don't like the sound at high RPM's but I blame that on the stock LO3 cam and not the headers. I am putting in the LT4 cam in a month or so, so I will really tell you then how these headers are. I plan on getting SLP's down the road for quality and performance reasons. I think a gasket-less ball flange is the way to go to prevent leaks.
darbleinad's Avatar
Car: 84 Trans Am
my 355 runs high 13s with flowtechs and with traction and some actual tuning it will be faster. traction is a major problem.
Old Dec 15, 2002 | 10:19 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Here is the bent collector flange.
Old Dec 15, 2002 | 10:24 PM
darbleinad's Avatar
Car: 84 Trans Am
a little copper RTV silicone will seal that leak right up
Old Dec 15, 2002 | 10:32 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Does that stuff really work? I thought about putting some of that "exhaust mender putty" in there but that sounds so make-shift. The thought of jerry rigging something on my car makes me sick, but if it works...................
Old Dec 15, 2002 | 10:37 PM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
My last set of headers on a 3rd gen was Hedmans and they leaked at the collectors. No matter what I did I could not get rid of that leak. Finally I stuffed and O-ring between the two pieces at the collector and the leak went away.
Might want to check into it.
RP.
Old Dec 15, 2002 | 10:42 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Hmmmm.................
Well I already have TWO dead soft copper gaskets + ONE dead soft aluminum spacer/gasket per side. I thought this would be enough of a snadwich to squeeze the leak out. Geuss not. It is not your typical exhaust leak sound, which is wierd. but there is some unidentifiable noise comming from down there. The gaskets even have a commpressable bead around them incase the flange is warped, which mine is. So So So frustrating.
Old Dec 15, 2002 | 11:28 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
1.5" primaries aren't bad for a 350HP or less motor.
I'd say get the 1.625" from Hedman. If you look in the Jeg's catalog, you'll see they're ~$100 for 1.625" and another $100 for the Y-pipe.
Here's the description.
http://www.jegs.com/cgi-bin/ncommerc...rnbr=500-68470
Look for that part number on this page.
http://www.jegs.com/cgi-bin/ncommerc...17&prmenbr=361
And here's the Y-pipe
http://www.jegs.com/cgi-bin/ncommerc...53&prmenbr=361
Old Dec 16, 2002 | 01:47 PM
bubbakutz's Avatar
Engine: LG4
ok one more thing with those hedman ones.....it says must modify ac braket......what does that mean......i still wanna use my ac.........
Old Dec 16, 2002 | 02:53 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Those hedmans sound right...anyone have a picture of them? and do they have the O2 bung? or will I need to have one installed...
I am debating between those and the flowtechs
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
