4th gen guages wiring guide inside!
Old Jan 1, 2003 | 06:46 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Ok this is for the 98z28 guage cluster...courtesy of gm's tech website (goota love having access to the good stuff to solve our problems)
Pin
Wire Color
Circuit No.
Function
A1
PNK
39
Power feed from gages Fuse 9
A2
DK BLU
1936
Fuel gage signal
A3
GRY
728
SECURITY indicator lamp control
A4
BRN/WHT
419
SERVICE ENGINE SOON indicator lamp control
A5
PNK
39
A6
YEL/BLK
68
Low coolant level indicator control
A7
BRN
358
AIR BAG indicator control
A8
PPL/WHT
1572
TCS OFF indicator control (with NW9)
A10
TAN/WHT
33
BRAKE warning indicator lamp control
A11
LT GRN
High beam headlights on
A12
PPL/WHT
237
FASTEN SEATBELT indicator lamp control
A13
ORN
640
Power feed from PWR ACCY Fuse 7
A14
RED
225
Generator output indicator control
A15
BRN/WHT
1173
Oil level lamp signal
A16
DK BLU
1537
LOW TRAC indicator lamp control
A17
DK GRN
135
Coolant temperature sensor signal
B1
BRN
Odometer illumination
B2
GRY
IP illumination lamps feed
B3
BLK
650
Ground
B4
WHT
375
SKIP SHIFT indicator lamp control (V8 only)
B5
DK BLU/WHT
1415
Right turn signal switch output
B12
DK GRN/WHT
817
Vehicle speed signal-4000 pulses per mile
B13
WHT
121
Tachometer signal
B14
LT BLU/WHT
1414
Left turn signal switch output
B15
BLK/WHT
451
Ground
B16
TAN
31
Oil pressure indicator control
B17
LT GRN
867
ABS fail signal
WOOT RACK ONE UP FOR NICK!!
Old Jan 2, 2003 | 04:46 AM
CrazyHawaiian's Avatar
Car: too many ...
Ah very usefull!! Thanks!! Disregard that post in the other thread about getting the manaual for the 98 z28. Thank you very much!! Will definately have to save this link for when I get bored and finish up the 4th gen interior swap Sticky/FAQ I've been messing with.
Old Feb 19, 2003 | 08:22 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
hey can you get that same list for an lt1 cluster? specifically, '95 formula. thanks!
Old Feb 19, 2003 | 08:49 PM
Camar92's Avatar
Car: 1986 IROC-Z
Engine: Vortec 350 with mild cam
Transmission: 700r4 Mild build
Axle/Gears: Stock
As a matter of fact, I just finished my 1995 V6 dash swap. The LT1 and the V6 are the same, so you should be fine. Im gonna post all my connections soon.
Old Feb 19, 2003 | 09:01 PM
Car: '87 Camaro LT
Engine: 355 L98
thanks. were you able to hook up the fourth gen hvac controls? or are you using the thirdgen ones?
Old Nov 7, 2003 | 11:23 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Re: 4th gen guages wiring guide inside!
Pin
Wire Color
Circuit No.
Function
A1
PNK
39
A5
PNK
39
A13
ORN
640
A14
RED
225
B1
BRN
B2
GRY
B3
BLK
650
Ground
B15
BLK/WHT
451
Ground
Nick (or anyone else that has done this)
I know U did this along time ago, but if U remember any of it please help me out. Iv'e never done any kind of wiring before.
Right now Im trying to match up the wiring. Ive got a 3rdgen shop manual but can't match up some of the wires on the guages.
What I quoted above are the wires from the 4thgen guage that I can't figure out what to do with.
SO what did you do with these wires?????????
#1) A1 and A5(4thgen) is power feed for the guages. I have 5 wires on my 3rdgen harness (pnk/blk) that say power feed for guages. Did you just hook two of the 3rdgen wires up and leave the the other 3 unhooked?
#2) A13 on 4thgen "Power feed from PWR ACCY Fuse 7" Did U use this wire? I can't seem to find a match on my 3rdgen harness?
#3) A14 on 4thgen "Generator output indicator control" Same thing, can't find a matching wire on the 3rdgen harness. What did U do with it?
#4) B1 "Odometer illumination" can't find a 3rdgen wire to match it?
#5) B2 "IP illumination lamps feed" I have 3 thirdgen wires that match this function, did you just connect all three together or use one and leave the other two unused?
#6) B3 circuit 650 "gound"
#7) B15 circuit 451 "Ground"
what did you do with these two grounds, cause they are differnt circuits on the 4thgen harness. But I have two grounds on my thirdgen harness but they are the same circuit. So do the circuits matter? Or can I connect either ground on the 4thgen side to either ground on the 3rdgen side?
The wires I have left over on the 3rdgen harness to play with are,
lt blue- Choke
5x pink/blk- battery voltage from guage fuse, hot in run
2x black- Ground
3x gray - cluster illum, variable voltage with lights on
Old Nov 22, 2003 | 07:04 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
Anyone? ABout my Question above????????
Old Nov 28, 2003 | 10:02 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
the gray illumination wire is usally hooked to dash lights, so when you turn your light switch ****, they will go dimmer and brighter accordinly
Old Nov 28, 2003 | 10:24 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
I have 3 of these gray wires on the 3rdgen harness. The 4thgen cluster calls for 1 IP illumination wire and 1 Odometer illumination wire. So would I just hook a gray wire to each and tape the 3rd gray (from the 3rdgen harness)wire off to the side and not use it? Again, I don't know much about wireing. just trying to make sure I do it right so I don't end up ruining anything. ThanX
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Casey Meyers
Mar 2, 2016 10:46 AM
Reddeath210
Oct 6, 2015 08:20 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
