Door lock likes to fight me!
Old Jan 14, 2003 | 01:35 PM
PopaPork's Avatar
Hey guys having a problem with my door locksl lately. The driver door IF (big IF) I can get my key in I cant turn the lock at all, cant turn it to unlock it and cant turn it to lock. Now just to get the key in is a struggle but to get it out is just as bad. The passenger side do is giving me some problems too. I cant get the key in..with some force..the lock turns fine...but pulling it out I really have to pull and wiggle it. Any one got any ideas? I had it so bad one day..I had to go through the trunk.!!!!!
Pork
Old Jan 14, 2003 | 03:52 PM
Jza's Avatar
Jza
Not to perhaps state the obvious, but have you tried spraying a little silicone into the cylinder then working it?
Otherwise, you might just have worn bars or springs in the lock. Gotta get new locks. That's a pita because you usually want all of them to match so you have to buy them in a set (even the storage compartment(s) if you have that option).
Old Jan 14, 2003 | 06:13 PM
Hulk0202's Avatar
Buy graphite. Its a powder that comes in a tube. Squirt some in there, that may loosen it up a bit. that stuff usually works pretty well.
Old Jan 14, 2003 | 06:27 PM
19WS6T/A91's Avatar
actually to save yourself the mess try to find a product called lock ease, it contains graphite and its alot cleaner and easier to work with.
Old Jan 14, 2003 | 07:01 PM
MdFormula350's Avatar
yeah good thing about graphite is that it doesnt attract dirt, i use it in my radio controlled car transmissions...
Old Jan 14, 2003 | 07:36 PM
2vmodular's Avatar
Install a keyless entry system and you won't have to fight with the door lock cylinders anymore.
A thirdgen car alarm, remotestart, and remote keyless entry install guide is avaliable here:
http://www.p71interceptor.com/thirdgen/alarminfo
Old Jan 14, 2003 | 10:44 PM
Camarokid01's Avatar
silicone spray worked for me when my locks did that
Old Jan 15, 2003 | 06:34 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The lock on my pass side was frozen. Replacement was necessary. Since, I've used Lock-Ease.
JamesC
Old Jan 15, 2003 | 05:12 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
I have a small bottle of graphite if you need it Pork, but it's home and you're not .... U lose!
But now that I think about it, maybe I will put some in my door locks.
Z
Old Jan 16, 2003 | 09:30 AM
Jza's Avatar
Jza
I second the keyless entry. Didn't realize just how great it is!
My old alarm didn't actuate the locks, so I still had to use the key. It always messed with passengers when I'd disable the alarm and they try to open the door. I'm like, I still gotta use a key..
Old Jan 16, 2003 | 01:02 PM
PopaPork's Avatar
Yeah I think the keyless entery is gonna be the way to go on it. I am having Jim86bird look for a good one for me. KZad...bring up that junk when you come up to good ol Rochchacha. Thanks for the help fellas
Old Jan 16, 2003 | 07:58 PM
bladz's Avatar
Car: 86 firebird
Engine: 3.8 turbocharged GN motor
i have gotten a keyless alarm to lock and unlock the door but the automatic lock motor wont unlock it or lock it all the way. if i press the button several times it eventualy unocks it. im sure a little lubrication will fix this, but incase it doesnt does anyone have some suggestions.
Old Jan 17, 2003 | 04:00 PM
JamesC's Avatar
baldz,
What you describe is a common problem with our cars. Cleaning then lubing with white grease will cure the problem. Do the window tracks as well. Also, you might check the following thread:
https://www.thirdgen.org/techbb2/sho...hreadid=124084
JamesC
Old Jan 18, 2003 | 10:39 PM
reborn92rs's Avatar
Car: 92 RS
Transmission: auto
I have the same problem, I could not turn the locks with both hands on the key. I bought a whole new set of locks ($160) for the car to put in which I spent some of today doing. Its not the locks themselves I think that goes bad, at least mine when I took them out worked just as fine as the new locks did in my hand.
I think its actually the lock part in the latch that goes bad. On mine theres about 2" of total travel, but only maybe 1/4" at most on each end actually locks and unlocks the door. I caked as much grease as I could into the latch assembly today and it definately made a difference. I can at least lock/unlock the door with 1 hand now, but its still harder than Id like.
Old Jan 20, 2003 | 04:42 AM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
lock ease werkt fer mee!
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlackTopKing
Aug 19, 2015 12:13 PM
