MIN Temp for tcc lockup? 8D
Old Jan 15, 2003 | 01:11 AM
87_TA's Avatar
Hey all last night I was driving my car in 12 degree weather and coolant temp dropped below 130 degrees,(my sensor is located on the upper rad hose because my my heads are not drilled for so temp is actually higher)
and converter stopped locking,Is there a table that I can lower the min temp? If so I can't find it.
Old Jan 15, 2003 | 03:43 PM
funstick's Avatar
look thru the constant it may or may not be there. if not email tc and ask for the hex location and conversion. the set it yourself. and move the temp sensor. there a hole somwhere.
Old Jan 16, 2003 | 05:16 AM
87_TA's Avatar
No its not in constanst,thats why I made this post.
I can't move the sensor anywhere else Both holes in the intake are being used there are no holes tapped in my canfield heads
only freeze plugs.
Thats why I made a T in my upper rad hose and mounted the sensor in there the only downfall is that usually reads bout 15 degrees cooler than the head.
I will mail TC im sure they will help.
Thanks.
Old Jan 16, 2003 | 10:02 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
In the 8D I believe that is is here ...
Tim
Old Jan 16, 2003 | 02:04 PM
87_TA's Avatar
Thanks Trax,
I had contacted earlier TC and I just checked my mail and there it was,He had added it to the constants table for me And last week added the 02 Toggle R/L limits for me.
That is the best customer support ive ever seen.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
DIY PROM
Oct 2, 2015 01:25 PM
ramicio
Sep 28, 2015 01:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
