305 Casting Number that flows the best
Old Feb 13, 2003 | 12:32 AM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
What is the best flowing 305 head's casting number?
Maybe even some flow charts? :O)
Old Feb 13, 2003 | 12:18 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The best 305 heads to start with are the 416 and 081 castings
stock head
Flow chart for stock #14101081 305 head 87 91
Intake lift (in) Flow (cfm) Exhaust lift (in) Flow (cfm) Ratio E/I flow (%)
0.050 31 0.050 15 49
0.100 63 0.100 37 58
0.150 92 0.150 61 67
0.200 116 0.200 78 68
0.250 134 0.250 92 69
0.300 157 0.300 101 64
0.350 170 0.350 105 62
0.400 182 0.400 107 59
0.450 189 0.450 109 58
0.500 195 0.500 110 56
This is the stock head with 1.84 and 1.50" valves
Below is what can be achieved with porting and larger 1.94x 1.60 valves
This is actually a 350 head but you can get this out of the 305 heads too. I have.
Ported big valve 350L-98 head
Lift Intake Exhaust
.1 63.8 41.4
.2 120.6 88.2
.3 178.9 124.1
.4 215.2 154.3
.5 240.1 171.8
.6 241 180
@28" H2O intake ex
lift
.100 70.1
.150 105.2
.200 135.27
.250 158.6
.300 187.0
.350 205.41
.400 222.11
.450 225.45
.500 225.45
.550 218.77 140.84cfm
This was my first effort at porting 305 heads.
You can expect this with an honest effort.
Old Feb 13, 2003 | 12:24 PM
F-BIRD'88's Avatar
Ported 305 head....
Old Feb 13, 2003 | 04:06 PM
After porting.. do you need to perform a valve grind?
And also.. stage I ported (blended off seat into valve bowl) if that is already done, am I a step ahead?
Is there REALLY a huge different in 2.02/1.60 Valves VS 1.94/1.50? I can get a set of heads in either. It's going under a TPI with headers/ slp runners/ etc.
Old Feb 13, 2003 | 09:04 PM
F-BIRD'88's Avatar
Yes you're going to do a valve job after porting them.
Ahead of what? Don't expect to achieve these numbers with just a bowl blend. Don't be a wuss... Fully port the heads.
I do not recommend useing 2.02's in these heads.
No apreciatable gain over 1.94's.
The 1.94's will flow plenty and the head will be stronger.
I recommend the 1.60 exhaust valves.
All these 305 heads have 1.84x 1.50" valves.
So you'll be buying new larger valves.
About $150/175 (can) for a set of budget street valves.
www.competitionproducts.com
Old Feb 14, 2003 | 01:18 AM
EvilCartman's Avatar
Car: '82 Z28
Hummm stock flow numbers for a 305 head woohoo hehe Entered in all my info into desktop dyno and came up with 247 hp 326 tq. Seems a bit high but whatever One of these days I'll get to the dyno, 90 bucks though for 3 runs.
Old Feb 14, 2003 | 12:28 PM
Marshall89ws6's Avatar
how would the heads flow with all the porting and bowl blending with the 1.84 valves still in there as opposed to the 1.94
Old Feb 14, 2003 | 12:40 PM
F-BIRD'88's Avatar
Don't know, but a lot less. Why bother.
You're going to need a valve job anyways, and your stock 1.84 valves are going to be pouched too.
You're not going to save anything.
The cost is the same. If a machine shop wants to charge more to cut in new larger 1.94 seats than to remachine the stock 1.84 seat, find a different machine shop. the work is the same.
New budget replacement valves are not expensive.
By the time you regrind your old GM valves the margins
will be too thin too. (run too hot). Get new 1.94" x1.60" or 1.50" valves.
Old Feb 14, 2003 | 12:50 PM
i have 1.94x1.5 but i was just wondering how much difference a tenth of an inch would make.
Old Aug 9, 2004 | 09:00 PM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
New valve job on 416's
I just ordered new valves, springs and cam from summit. :lala:
I ordered 1.94 intake and 1.50 exhaust. I thought that was what was stock for my heads
As I read this thread I am gathering that is not correct. If I am right you are saying that the 416 heads have 1.84 and 1.50 is this correct?.
If so can I use 1.94 and 1.50 combination. I have been very slow on ordering parts and this is why. I learn or something changes all the time. so if any one can help.
p.s. I am in the middle of porting the heads now. (which is alot of fun)
Old Aug 9, 2004 | 11:41 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Re: New valve job on 416's
Oh yeah, the machine shop won't have any trouble fitting the head for new 1.94" intake valves. Routine work for them.
Old Aug 10, 2004 | 09:50 AM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
I have a stock 1990 GTA with a TPI 305/5 speed. Which heads came on this motor?
Thanks,
Don
Old Aug 10, 2004 | 11:23 AM
Engine: 305-4v
Thanks,
Don
081s.
Old Aug 10, 2004 | 01:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Axle/Gears: 3.54 Dana 44
Hey Todd, you got a use for any more boat-anchors?
Old Aug 10, 2004 | 10:32 PM
Engine: 305-4v
Not really. What have you got in mind?
Old Aug 11, 2004 | 12:50 AM
Apeiron's Avatar
Engine: 383 Carb
Got some 642s and 185s to unload on someone.
Old Aug 11, 2004 | 05:20 PM
Engine: 305-4v
Better keep lookin' then
Grant2k
Jul 10, 2018 04:01 PM
gta90
Sep 15, 2015 04:00 PM
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
