wiring kill switch to coil
Old Mar 4, 2003 | 07:27 PM
joshp14's Avatar
i have been reading up on how to put a kill switch on the coil of your car so someone can not start it. I was wondering if anyone has any detailed instructions on how to do this. I know you may need a relay, and a switch somewhere in your car. But how exactly is it wired? what kind of relay do you need? and where can i get one? any help would be appreciated.
-Josh
Old Mar 5, 2003 | 03:18 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
Wire a switch to a relay (well you don't REALLY NEED to use a relay).. heres a schematic...
Old Mar 5, 2003 | 07:52 PM
joshp14's Avatar
ok, im pretty dumb founded when it comes to electronics like this. So is that box the relay, and the bottom pic the switch? If that is the relay, what kind of relay is it? amps? do u have any more detailed info? all help is appreciated.
Old Mar 6, 2003 | 06:29 AM
dans82bird's Avatar
Engine: 302
i'm not actually sure on how much current the ignition pulls, but I'm sure under 10amps. go to pepboys or something and see what they have... look for a spdt relay, preferablly bosch
Old Mar 6, 2003 | 10:58 AM
Jza's Avatar
Jza
I'm a bigger fan of the starter interrupt method.
Interrupting the coil will keep the car from starting, sure, but it's still gonna crank and spray fuel, so they end up flooding your engine. Great. Gas all over the cylinders.
I suppose anything's better than coming up 1 car short of a ride home, though.
On the other hand, they'll make a lot of noise which just might attract your (or someone's) attention. A starter interrupt would be a silent deterrent.
Old Mar 6, 2003 | 11:43 AM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I'll tell you this, both may be just the ticket. I just had my truck stolen from a Park-n-Ride on Monday. All I know, is that this weekend the GTA is getting as much theft resistance as possible. An alarm is pointless, when I worked in the junkyard, I could get around an alarm in like 5 minutes, but something that is hidden and incognito like a starter interrupt/ignition killer, noe that is something that would be tougher to locate.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
DIY PROM
25
Jun 20, 2017 04:04 AM
355sbcTPI
Aug 19, 2015 04:38 PM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
