Heads up on Stealth Ram with LPE 58mm TB
Old Mar 8, 2003 | 08:51 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Just a quick note on using an LPE 58mm TB on a Stealth Ram...the TB cable arm hits the 90* fuel fitting. As a result the throttle blades don't rest on the throttle stop screw.
Anyone run this particular setup and ran into this problem? What did you do to fix it? It seems the easiest way would be to gring the inner cable guide for clearance.
Also I'm pretty sure this only applies to the LPE 89-92 TBs as the 85-88 TBs use a different method to attach the throttle cable but I'm not positive it'll clear.
Old Mar 8, 2003 | 08:54 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Oh yeah, some pics might help. You can see where it's not resting on the throttle stop because of the arm hitting the fuel fitting.
Old Mar 8, 2003 | 08:56 PM
IROCZZ3's Avatar
Car: 87 Buick GN
another
Old Mar 8, 2003 | 08:58 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Here's where I'll clearance it...should be okay (I think)
Old Mar 8, 2003 | 09:05 PM
leirch's Avatar
That throttle bracket doesn't look like the one on my 58MM TB, maybe thats a universal one for LT1 and such? If you aren't using that part of the throttle cable bracket, sure grind it, may want to check to see if they make a replacement bracket that you can swap out.
Old Mar 8, 2003 | 10:09 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Seems like a safe enough idea to try... I would grind in stages and my attempts would be extremely (EXTREMELY) conservative... however if you are careful I think you have the right idea to fix this annoyance.
Old Mar 8, 2003 | 11:52 PM
DannyT's Avatar
Car: 89 Iroc
Engine: 383
Axle/Gears: 3.45
What year is your car?
Old Mar 9, 2003 | 12:47 AM
leirch's Avatar
I have an 87.
Old Mar 9, 2003 | 02:43 AM
rezinn's Avatar
That's what I would do. It doesn't look like you'll need to grind much, it's pretty close.
Old Mar 9, 2003 | 07:01 AM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
It appears that you have the late style throttle linkage with the "arc" I had no problems with my lingenfelter 58mm tb clearing the fitting, but it is the old-style tpi linkage.
Attached Thumbnails Heads up on Stealth Ram with LPE 58mm TB-eng_0024small.jpg
Old Mar 9, 2003 | 08:51 AM
IROCZZ3's Avatar
Car: 87 Buick GN
Cool then, I'll go ahead and carefully grind it there. I think it'll be okay as long as I don't go overboard. Thanks...
Old Mar 9, 2003 | 09:05 PM
Bort62's Avatar
Just grind the **** out of it... Nothing to really worry about.
Old Mar 10, 2003 | 02:04 PM
Jza's Avatar
Jza
My Holley 58mm TB (late style) has the same problem. You'd have the same problem with even a Holley 58mm TB (as I did). Just an out of the blue guess, but Holley did design this whole system around a pre-87 setup, and added the 87-up stuff as an afterthought. I'm sure the throttle cable cam interference issue is just another artifact of that.
I was able to get it to clear by loosening the plenum bolts and tweaking the plenum slightly to bring the TB away from the fuel fittings, then retightening them, and doing the same with the TB bolts.
Old Mar 10, 2003 | 06:20 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
Same problem with a BBK 58 mm TB, i guess ill have to gring the damn thing too......
Old Mar 10, 2003 | 06:40 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Transmission: gear jammer
Axle/Gears: 4.11
Exactly. Just make sure there aren't any rough edges to wear on the cable. Mine was rubbed and cut by a sharp edge I left.
I had to grind/cut my bracket too.
Brad's Avatar
That is seriously odd, my Holley 58 mm throttle body fit just fine on the Stealthram and mine is an 89. I wonder what the deal is?
Old Mar 11, 2003 | 08:24 AM
Jza's Avatar
Jza
Hm. Did you have to shorten the TPS tang any to get it to fit to the Holley TB?
I actually never had (or noticed a) the clearance problem until the third or so time I mocked it up. Maybe you just "got lucky" like I did the first couple times?
Old Mar 11, 2003 | 09:03 AM
Brad's Avatar
I did have to add some washers underneath the TPS to move it away from the TB a little. The tang on the TPS was scraping against the side of the throttle body. Other than that, no clearance problems of the throttle linkage with the fuel rails. I looked at some pictures that I have and it appears that somehow my throttle linkage is located farther towards the driver's side of the car than the fuel rail, thus it could not ever contact the fuel rail. I only have pictures to go by however, and they're at home on a CD so I can't post them at the moment. I will have my car back next weekend (I moved in January and it's taken a while to get the car back from out-of-state) and can verify better then.
Old Mar 11, 2003 | 11:24 AM
Scott C's Avatar
I had the same probloem with my Edelbrock/BBK 52mm TB. All I did was go to Napa and find a narrower 90* fuel fitting. The fitting Holley supplies is pretty fat, so a smaller one was all it needed to clear the linkage...
Old Mar 11, 2003 | 11:28 AM
91Z28's Avatar
Car: 91' Z28
If you buy a fitting like the one that goes on the backside of the FPR, (bevelled edges) it will clear the TB arm.....
Old May 12, 2004 | 05:36 PM
Scales's Avatar
Car: 1991 Z28
Engine: 5.7L TPI
I've heard that some people have had to use a pre 87 bracket. Anyone have any experance with that if it works or not?
(mine is a stock 91 throttle body that definitly won't clear the fitting on the fuel rail)
Old May 12, 2004 | 09:00 PM
JMatlock88's Avatar
Car: 1991 Formula
I am using the pre 87 linkage which works just fine.
Old May 13, 2004 | 11:54 PM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
I clearanced mine quite a bit just like you planned. I have never had the throttle stuck open on me either due to a cable that jumped the track....
Old May 15, 2004 | 03:27 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
you can post this over at www.stealthram.com also
Old May 17, 2004 | 09:20 PM
BOTTLEDZ28's Avatar
Transmission: A4
My fix...... NOS nitrous plate
9192camaro
16
Feb 3, 2019 12:21 AM
Mutillator
Sep 17, 2015 04:38 PM
mddaniel
Sep 8, 2015 05:16 PM
z28guy134
Sep 1, 2015 11:50 PM
L98GTA87
Aug 11, 2015 06:55 PM
