some pics of new mods and some problems
Old Apr 21, 2003 | 04:56 PM
Xceleratemaro's Avatar
i have just installed all new a arm polyurithan bushings. also new ball joints, struts , 34mm (with "wonder bar") sway bar. and polyurithan end links. the car runs like its on tracks.. THANK YOU NO4NJUNK for the help!!
now the work i did by my self kinda screwed up!! i put the shocks and sway bar in myself. sway bar is fine but the shocks kinda have a problem
i installed them with no problems and they worked fine for a day untill, i was installing my shifter cable and jacked the car up on one side and lefted it there for 10 min...then i let it back down and whent down the road and i heard alot of sweeking. did i install them right?? the directions were lost so i gussed at it... i will post some pics of the rear shocks..maby someone could help me figure out the problem!!
take a look thanks, chris
Old Apr 21, 2003 | 04:59 PM
here are the rear shocks (the problem sweeking)
Old Apr 21, 2003 | 05:00 PM
kyb shoks and struts kick ***!!
Attached Thumbnails some pics of new mods and some problems-parts-shocks.jpg
Old Apr 21, 2003 | 05:01 PM
the front c arms
Old Apr 21, 2003 | 05:02 PM
sponh kicks *** too....here are there strut mounts
Old Apr 21, 2003 | 05:03 PM
92blue's Avatar
Former Sponsor
Car: 1992 Camaro RS
Engine: Yet another 350 TPI
I seriously doubt its your shocks. Poly bushings do squeak if you don't grease them enough. Try to take a look at those.
Old Apr 21, 2003 | 05:07 PM
front strut and sway bar end links
Old Apr 21, 2003 | 05:08 PM
and the power plant(opps did i say power ;yea right )
Old Apr 21, 2003 | 05:09 PM
please post your thoughts !!
Old Apr 21, 2003 | 05:10 PM
from what i could tell the noise is comming from the rear of the car where there are no poly bushings...!
Old Apr 21, 2003 | 05:13 PM
scott's85T/A's Avatar
Yes you have them on wrong.
Let me look for a pic for you.
Old Apr 21, 2003 | 05:20 PM
damm i feel like a dumb *** thanks for the pic...if you get it
Old Apr 21, 2003 | 05:24 PM
Here is what mine looks like ,, I'm trying to scan the instructions now..
Old Apr 21, 2003 | 05:35 PM
yea the instructions would help what did i do wrong???? i tried to put the "coller" part in the other side but it wouldnot fit!!
Old Apr 21, 2003 | 05:42 PM
Old Apr 21, 2003 | 05:52 PM
Old Apr 21, 2003 | 05:55 PM
I beleve " F " is the way they go.
Hope that helps..
Old Apr 21, 2003 | 05:56 PM
thanks man i see the problem now....damm im an idiot
Old Apr 21, 2003 | 06:03 PM
You should have had alot of extra parts,,
you just need to unbolt yours, turn the entire thing around and run the short stud you have going to nothing,,through the mount, then use a lock washer and the other nut you didn't use, then you should have a "saucer shaped" washer against the shock held on with a lock washer and the nut your using now.
Old Apr 21, 2003 | 06:07 PM
yea i have some ex parts....was afraid to throw them away!!
Old Apr 21, 2003 | 06:46 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
how much where those strut mounts? and where did u get them? i need new ones and i also have some other stuff to do to the strut towers but for now i need new ones of the strut mounts and i want good ones.
Old Apr 21, 2003 | 06:58 PM
i got them from spohn...for 173 with shiping... they kick *** when i took the old one out i spun both the barring and there was no comparison...also they have grate customer service ...on one of the new nut that comes with the mounts one was not threaded. so i had to use an old one which looks like crap. so i called them and asked where i could get one that looked the same and they said that as soon as they get some in they will ship me one for free..spohn kicks ***:hail:
Old Apr 21, 2003 | 06:59 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
nice, i think ill give them a call soon. and was that nut the nut for the strut or the cover? and was that 173 for both or per mount?
Old Apr 21, 2003 | 07:07 PM
nut was for the mount and they come with no cover you have to use your old one...173 is for 2 of them with shiping!!
jhawkeye
May 25, 2022 06:33 PM
customblackbird
Aug 15, 2021 10:16 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
matthew911
Aug 12, 2015 09:38 AM
