Question about PE fueling vs temp.
Hi all,
I have been trying to dial in my PE a/f ratio but notive that when coolnt temp is about 125-130 that my a/f ratio is about 12.2-12.5
But when coolant temp is higher like 140-160 then a/f ratio is about 13.0-13.3 .
Here is my F/A adder in Pe settings.
% added temp c
54.7 -40
48.8 -16
43.8 8
33.6 32
22.7 56
22.7 80
22.7 104
22.7 128
22.7 156
Hmmm wait-I Think I see the problem,The 32 celcious table must have control all the way untill 55 celcious which is 131 degrees.
Sorry bout that.
But I do have another Q.
Is there anyway to disable BLM influence on PE without disabling
closed loop corrections?
% added temp c
54.7 -40
48.8 -16
43.8 8
33.6 32
22.7 56
22.7 80
22.7 104
22.7 128
22.7 156
Sorry bout that.
Car: check
Engine: check
Transmission: check
Re: Question about PE fueling vs temp.
Originally posted by 87_TA
Hi all,
Hi all,
RBob.
I believe that it already does. Maskid $8D? Check the code between $C9AD & $C9B7. If in PE mode the BLM is set to 128.
But I had always thought the ecm made correction,if noy\t thats great.
Now Im back with the same problem as earlier,I changed all the values in the F/A adder vs. coolant temp to the same value (22.7) and still the same.
First pass at wot coolant temp 127 and inj. pulsewidth 9.8-10.1
shortly after that coolant temp 135 and inj pulse width 8.9-9.1
WTH! how can I tune wot when this is happening?
have you checked the
open loop chnage to a/f ratio vs collatn temp table to see if something is defeating you there ?
85.7
50.9
20.8
10.7
6.0
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
stock table
or what about
open loop change to a/f ratio vs map ??
0.0
0.0
0.0
0.0
0.0
3.1
3.9
5.1
7.0
7.0
9.0
10.2
12.1
14.1
14.1
14.1
14.1
stock table
just some thougths. maybe youive got a few bad byte in your bin. import all your tables into a fresh binary see what happens.
85.7
50.9
20.8
10.7
6.0
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
0.9
stock table
or what about
0.0
0.0
0.0
0.0
0.0
3.1
3.9
5.1
7.0
7.0
9.0
10.2
12.1
14.1
14.1
14.1
14.1
stock table
Well Rob,I think it must have influence because I just took it out and blm's were 140 just before and stayed there during WOT
and added about 9% to my PW.
Thanks funstick,yes I checked the open loop FA adder vs.temp
and all there past 8 degrees house the value.
Moving all tables to another bin is a good idea,I just noticed on this last bin that my speedo is jumping around like 50 mph...
Car: check
Engine: check
Transmission: check
If you would like to patch that out, go to $C9AB (virtual address) and overlay two bytes with a NOP ($01). The physical address (BIN) would be $C9AB - $8000 = $49AB. So at $49AB change the $2B to $01 and at $49AC change the $02 to $01. See the following (you are patching out the BMI at line 11402):
Code:
C9A7 11396 ;------------------------------- C9A7 11397 ; SAVE UPDATED CURRENT BLM VAL C9A7 11398 ;------------------------------- C9A7 11399 C9A7 D7 DF 11400 LC9A7: STAB L00DF ; BLM CELL NUMS 0 - 7 C9A9 97 E0 11401 STAA L00E0 ; SAVE BLM C9AB 2B 02 11402 BMI LC9AF ; BRA IF BLM > 127 (adding fuel) C9AD 11403 C9AD 11404 ;------------------------------- C9AD 11405 ; C9AD 11406 ; SET BLM = 128 IF IN PWR ENR C9AD 11407 ; C9AD 11408 ;------------------------------- C9AD 11409 C9AD 86 80 11410 LDAA #128 ; MID VALUE C9AF 11411 ; C9AF D6 46 11412 LC9AF: LDAB L0046 ; AFR MD WD C9B1 C5 20 11413 BITB #$20 ; B5 1 = IN PWR ENRICH C9B3 27 02 11414 BEQ LC9B7 ; BR IF not IN PWR ENRICH C9B5 11415 ; .... else C9B5 97 E0 11416 STAA L00E0 ; IF YES, SET BLM = 128
If yours does not match you should be able to find the proper location to patch via the information above.
RBob.
Car: Death Mobile
Engine: 666 c.i.
Originally posted by RBob
You are correct, it does the traditional if BLM < 128 ignore it or if BLM > 128 use it.
Most people with our vintage of cars almost always notice that their calibration is too rich when they start tuning. GM apparently took the "conservative approach" and tended to make the calibration overly rich.
So when people start pulling out the excess fuel, they often will notice an increase in performance because they are now getting closer to an optimal AF Ratio. Better, GM put "safety code" in the calibration to ensure that if you are running lean.
Of course, one should properly tune the PE Tables with a WB O2 sensor after they have gotten all of their Part Throttle Tables optimized. But it again illustrates why a person is likely to experience an increase in performance when they start to optimize their eprom.
Thanks alot Rob,BUt I have one problem..
I have never disasembled code,Nor would I know the first thing to do. I just use generic tunercat and winbin tables.
If you were to point me in the right direction I would love to start
and think its about time I do.
Thanks again.
Thanks again.
Car: Death Mobile
Engine: 666 c.i.
Check the "sticky" on Source Code. There are links in there to get ALL the info you need to start getting into Assembly Language. From there, just start posting specific questions - especially if you need to how an instruction works.
Trust me, there are a dozen other guys wanting to learn Assembly but afraid to ask. If you ever programmed a computer, you have big start.
Ok guys I am still having problem with Temp influence on PE .
I just took a scan and made two back to back runs at wot.
with BLM's locked down.
One at 130 coolant temp and avg BPW was (8.30)
And another at 170 temp,avg. BPW was (7.65)
Heeeelp,where am I losing my 8%?
I have all the values in the PE F/A adder vs. coolant temp @ 22.7.
Please help, I will be glad to send somebody a scan file and a bin to see if they can see why..
Here is the open loop vs. coolant temp.
85.7
51.0
20.9
10.7 -4
6.0 8
1.0 20 = 68 degrees
1.0 32
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Now in the constants there is a minimum temp for open loop fueling I have set to 45 or 113 degrees (f),maybe thats to close to 130 or something...
85.7
51.0
20.9
10.7 -4
6.0 8
1.0 20 = 68 degrees
1.0 32
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
I've found that I havn't had to change the vs coolant...maybe I'm just lucky-but I've tuned with a wide band and the vs rpm, after warm up; anywhere from 160 to 220 deg it's so close (f/a ratio) as to not bother with the vs coolant. For lower temps I havn't logged a wide band run, always figured I wanted to let it warm up before wot. I'll have to go back thru the datalogs to check inj. pulse widths at diff temps....
84z96L31vortec
Aug 20, 2017 12:16 AM
