car missing, help please...
Old May 8, 2003 | 11:14 PM
19WS6T/A91's Avatar
my car is missing REALLY bad. i am going to look at the cap and rotor and change the fuel filter saturday. i dont think that any of those are the problem though. its weird, it seems to miss the worst after i have 100 miles on a new tank of gas. in other words, every time the odometer is near 100 miles the missing seems to get worse. any ideas?
thanks
Old May 9, 2003 | 03:39 AM
Morley's Avatar
Bad gas/water in the tank. Try a bottle or 2 of STP gas treatment.
Old May 9, 2003 | 06:25 AM
19WS6T/A91's Avatar
actually a couple of weeks ago it was doing this same thing, i ran 4 bottles of stp through it and it eventually went away. it ran fine for 3 or 4 tanks of gas, then all of the sudden, i was sitting at a stop light and it began again.
Old May 9, 2003 | 11:57 AM
Morley's Avatar
If you use the same gas station for each fill up...stop. If you use several different stations, look at the filler neck at the top of the tank, it may be cracked and letting water in when it rains.
Old May 10, 2003 | 09:41 AM
19WS6T/A91's Avatar
i thought about the filler neck problem, it hasnt rained in several weeks though. it just started missing again two days ago.
Old May 10, 2003 | 11:55 AM
Odyssey's Avatar
I'd say you could use some new injectors! Oh and that's a beautiful car by the way !!!
Old May 10, 2003 | 12:15 PM
19WS6T/A91's Avatar
thanks for the compliment, does anyone know how to check the injectors to see which one(s) is bad?
Old May 10, 2003 | 06:17 PM
Morley's Avatar
Look in a fuel injection manual for the "Injector Balance Check" This is how you pinpoint which injectors, but honestly, if a few are bad you'd do better to replace the whole set.
Old May 10, 2003 | 07:02 PM
19WS6T/A91's Avatar
does anybody tell me how to test the ohms of the inectors? i read on a search that the injectors are supposed to ohm around 10 but i have no idea how to check them.
Old May 10, 2003 | 07:26 PM
Morley's Avatar
Disconnect the harness from them and put an ohm meter across the pins on the injector.
Old May 10, 2003 | 07:53 PM
19WS6T/A91's Avatar
i tried that a while back, i onlly tried it on two, neither of those read over .001 so i figured that wasnt the correct way to check them. the key does not need to be turned on correct? thank you for you time morley
Old May 10, 2003 | 10:11 PM
Morley's Avatar
Nope, key off, pull all the connectors and put the ohm meter across each of the injector's terminals. If you are reading .001 ohms, then its time for a new set of injectors.
Old May 11, 2003 | 05:12 PM
19WS6T/A91's Avatar
ok i just checked the injecters, they were all between 17.2 and 17.6 ohms. i have no clue what to try next
Old May 11, 2003 | 06:32 PM
Morley's Avatar
I would look at the gas in the tank, if it gets worse as you approach 1/2 tank it really sounds like bad gas. I had the same thing once, took 2 bottles of STP and a top off of premium gas to get it running right again. Also the coupler/pulsator between the pump and fuel tube in the tank might be split and as you get lower on fuel more of the pump's discharge is spit back into the tank instead of going to the engine.
Old May 11, 2003 | 06:38 PM
19WS6T/A91's Avatar
i had this same problem about a month or so ago, it took 4 tanks of premium with stp in each one to fix it, all of the sudden the other day i was driving and it started again. if it was the pulsator thing, wouldnt it lower the fuel pressure? the fuel pressure is at 44 psi which is where it was before the problem began
Old May 11, 2003 | 07:04 PM
Morley's Avatar
The pressure of the surrounding fuel in the tank helps to keep the split in the hose closed, as the level in the tank drops there is less pressure acting on the outside of the hose and more fuel from the pump can escape.
Old May 11, 2003 | 08:59 PM
19WS6T/A91's Avatar
i also realised just a little while ago that it deffinatly only happens once the engine warms up. which then reminded me that my air lines(where they come off the header) are just sitting there open because i broke the check valve. do you think this could be the problem? regardless im going to plug them tom. thanks again for the help.
david
Old May 12, 2003 | 10:24 AM
19WS6T/A91's Avatar
anyone?
hectre13
Dec 11, 2023 08:14 AM
The_Phoenix
Feb 4, 2016 07:10 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
MY87LT
Aug 17, 2015 08:43 AM
Exxon Limited
Aug 9, 2015 08:13 PM
