electric fp guage?
Old May 9, 2003 | 07:59 PM
Kandied91z's Avatar
electric fp guage?
anyone running an electric fuel pressure guage?
i'd like to see how you have it the sending unit plumed if possible.
Old May 9, 2003 | 08:07 PM
maniacc's Avatar
Jeff,
I removed the schader valve out of the test port on the fuel rail, hooked a 90degree -4an line to it, ran that to the sender, which i mounted on the firewall, then ran the wire inside the car. (in the pic you can see the braided line and fitting.
Old May 9, 2003 | 08:16 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes
Old May 9, 2003 | 08:18 PM
Kandied91z's Avatar
you guys have a pic of the sender?
i have all the stock pieces that are inside the car still together, however after the swap i lost track of where the actual mechanic parts where and they were never labeled. trying to pick them out of a huge box of parts is rather difficult since i forgot what it looks like.
thanks for the pics guys!!
Old May 9, 2003 | 08:34 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
damn I went out took it apart took pictures downloaded, deleted those I didnt need and saved the one that hides it. anyhow what I used was:
  • 1/8 NPT female to 1/8 NPT female union (brass)
  • aeroquip 90 degree male 1/8 npt to male -4 (steel)
  • earls -4 female to -4 female straight union (aluminum)
  • removed the schrader's core
I went outside and took off my map and bracket took pictures and downloaded it and deleted the rest and did the wrong one (above) But I drew this awsome picture of it:
Old May 9, 2003 | 09:01 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
This what ya need?
Old May 10, 2003 | 04:05 AM
Kandied91z's Avatar
thank you very much for taking the time!!
Old Feb 22, 2004 | 07:42 PM
metalhead212121's Avatar
Car: 91 Firebird Formula
Engine: For me to know.....
Transmission: and you to find out....
Got a few questions....
1~ How hard was the install? Because Im interested in doing a electric fuel pressure guage in my car. But if its really tough..I'll opt for the mechanical one (and yes get the isolator as well)
2~ Do any of you guys have the part #'s handy for this?
Thanks...
Dan
Old Feb 23, 2004 | 12:27 AM
Kandied91z's Avatar
well if you can understand basic electrical setups you shouldn't have a problem. it's much nicer having it in the car so that it's easy to read however sometimes i wonder it's accuracy.
Old Feb 23, 2004 | 06:51 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
My autometer setup is PN#. 5763
http://store.summitracing.com/partde...art=ATM%2D5763
Old Feb 23, 2004 | 06:36 PM
thanks for the TPl383 but I was looking for part #'s for what B4Ctom1 listed... Im assuming you need teflon tape when you "plum" this stuff together right?? Also when you buy the fuel pressure guage do you get the sender with it or is that seperate?
Dan
Old Feb 29, 2004 | 07:16 PM
TTT...Hate to be a pain but Im having trouble finding part#'s for the stuff I mentioned before.... Can anyone help me?
TIA
Dan
Old Mar 3, 2004 | 06:01 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
best bet is to pick up a summit catalog and just see what you want. Everyone may have something diff that you might not like the way it was done.
But heres a run down from the list above
http://store.summitracing.com/partde...t=EAR%2D916104
http://store.summitracing.com/partde...=AER%2DFCM2031
http://store.summitracing.com/partde...t=EAR%2D981504
Old Mar 3, 2004 | 06:15 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
This is how I ran mine. with a 90* swivel end off the shrader
Old Mar 10, 2004 | 05:31 PM
thanks for the part numbers TPl383. Do you have to put teflon tape on the threads (for the fittings)??
Dan
Old Mar 13, 2004 | 09:20 PM
ttt..
Old Mar 14, 2004 | 01:42 PM
nightrider87's Avatar
don't use teflon tape for anything. all those fittings will go together perfectly without it and the particles on it can clog things.
Old Mar 14, 2004 | 02:52 PM
ok thanks for the info nightrider87....
Dan
Old Mar 15, 2004 | 10:54 AM
jim91z's Avatar
Car: 1991 Z28
Transmission: auto (4L60)
I thought that a liquid pipe sealant might be good, but I guess you're not supposed to use anything... here's a tech tip from the Aeroquip web site:
http://www.aeroquip.com/media/techtips/TipAdapters.pdf
Old Mar 17, 2004 | 08:30 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
TPl383,
Where did you get that pre fabed fuel line?
Old Mar 17, 2004 | 08:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Not pre fab. I make it myslef.
Old Mar 20, 2004 | 06:27 PM
stevedave454's Avatar
Car: 91 S10
i have a question that has something to do with this... in the not too distant future i'll be installing an FMU... i was reading bout the vortec SFMU, and they said you didn't need the stock reg. at all, so first whats the proper way to get rid of it and adapt the SFMU? secondly once i do this it would be very easy to put a fitting for the elec FP gauge in the lines for the SFMU right?
sheachopper
Jul 31, 2019 11:27 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
