Bolt mains?
Old May 19, 2003 | 11:23 PM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Bolt mains?
Ok Ok.. gimme all the flak you want for this. But I have been reading about engines, and 4 bolt main keeps appearing as part of the car vernacular.
What exactly is a 4 bolt main.. 6 bolt main.. etc?
I probably should know, but I dont
Old May 20, 2003 | 12:09 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Ok this is a pretty simple one to answer. when you hear 2 bolt or 4 bolt main, that refers to the number of bolts that hold the main bearing caps for the crankshaft. 2 bolt main = 2 bolts per cap. 4 bolt main = 4 bolts per cap. All thirdgen V8's have the 2 bolt main setup. That doesn't mean they are bad engines. The 4 bolts are a bit of a stronger block, but you can make a 2 bolt into a 4 bolt.
Old May 20, 2003 | 01:13 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
2 bolt main caps...
BTW, pardon the rust, please.
Old May 20, 2003 | 01:15 AM
AJ_92RS's Avatar
4 bolt main caps...
No rust
Old May 20, 2003 | 11:14 AM
There you have it. A pic is worth a thousand words
Old May 20, 2003 | 12:17 PM
StealthElephant's Avatar
Car: 87' Iroc
thats a nice looking crank in the 2nd pic
Old May 20, 2003 | 01:02 PM
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Thanks for the explanation. And the pics
-Eric
Old May 20, 2003 | 01:43 PM
AJ_92RS's Avatar
So you like my crank, huh?
It's just a stock cast crank ground down .010" on both the main and rod journals.
As you can see, the machine shop here is pretty good. That shine you see on the 2nd and 3rd rod journals is from the SMOOOOTH radii and the micro-polished finish.
It only cost me $380 to get the block crank done.
I like living in a small town.
Old May 21, 2003 | 01:58 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
here's a six bolt block. this was an LS1 on display at the detroit auto show this year
Old May 21, 2003 | 04:25 PM
AJ_92RS's Avatar
Cool... Thanks.
Right Click, Save Picture As....
Old May 21, 2003 | 06:47 PM
bredfearn's Avatar
Car: 1994 Nissan Pathfinder
Engine: 3.0L V-6
dude, that pic helped a lot. know i EXACTLY know what you're talking about. the 6-bolt was a little hard to visualize though. not the most all-encompassing pic. shoot, were there even 6 bolts in that pic?
Old May 21, 2003 | 06:52 PM
Car: '87 Camaro LT
Engine: 355 L98
you can only see half the main there, therefore you can only see three bolts (look close), two point downward and the third actually goes in through the outside of the block into the main.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
billybob6110
Sep 23, 2015 01:30 PM
fasteddi
Sep 10, 2015 09:32 AM
angel2794
Sep 8, 2015 06:22 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
