Dual exhaust you can buy !!!!! Look
Old May 23, 2003 | 11:51 AM
nolanr0413's Avatar
Car: Trans am
Look at this , their is finally a dual exhaust you can buy for a third gen trans am or camaro , 82-92. The price you ask only 350 bucks.
Old May 23, 2003 | 11:53 AM
nolanr0413's Avatar
Car: Trans am
pic
Old May 23, 2003 | 11:54 AM
nolanr0413's Avatar
Car: Trans am
Old May 23, 2003 | 11:55 AM
nolanr0413's Avatar
Car: Trans am
Old May 23, 2003 | 11:57 AM
nolanr0413's Avatar
Car: Trans am
Old May 23, 2003 | 11:58 AM
nolanr0413's Avatar
Car: Trans am
Old May 23, 2003 | 11:59 AM
nolanr0413's Avatar
Car: Trans am
heres some info
No compromise exhaust for your F-body. Before there was no simple dual exhaust solution that had excellent ground clearance. Now you can have the sound and power of a true dual exhaust system. Our setup passes under our custom transmission cross member (for extra clearance) and is routed down the driveshaft tunnel and over the rear axle on the passenger side. For increased top-end power and a more exotic sound we use the x-pipe crossover, which is designed to work with exhaust pressure waves to improve cylinder scavenging. Catalytic converters can be used with stock manifolds or shorty headers but not with long tube headers.
2.5" mandrel bent tubing, 3" under development
Coated with silver high temp paint
Good ground clearance on lowered cars
Crossmember included (Stock transmission or T56 version)
Catalytic converters and cat-forward pipe not included
Mufflers and tips not included
Old May 23, 2003 | 12:00 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Transmission: broken
That is maniac motors right? I am pretty sure that is the exhaust that I am going to be buying.
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
cool. got any sound clips?
Old May 23, 2003 | 12:01 PM
nolanr0413's Avatar
Car: Trans am
http://www.maniacmotor.com/fbody/3gfbody.html
no i have no sound clips sorry .
Old May 23, 2003 | 03:00 PM
88Spinner's Avatar
Car: 88camaro
Transmission: th350
In pic number 4 is the tranny xmember even on?
Old May 23, 2003 | 03:08 PM
scuzzy's Avatar
Yeah it's a modified crossmember, you can spot it if
you look at the top of the picture, the exhaust pipes go underneeth
the crossmember.
Old May 23, 2003 | 09:24 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
thats sweet, i bet that x pipe makes it sounds amazing.
Old May 23, 2003 | 10:14 PM
25THRSS's Avatar
I don't see any mufflers?
Old May 23, 2003 | 11:19 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Mufflers and tips not included <--- <--- <-----
Old May 23, 2003 | 11:29 PM
25THRSS's Avatar
Doesn't even look there is is room for mufflers on that setup. Got any more pics that show how much room there is?
Old May 24, 2003 | 12:06 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
There is room but not much. I am going to copy willie and use 2 stainless works 69 camaro style chambered mufflers. They fit just perfectly. Do a dual exhaust search and look at willie's exhaust it is pretty cool.
Old May 24, 2003 | 01:33 AM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
How much does this kit cost? It may look cool, but i bet the price isn't too cool lol
Old May 24, 2003 | 09:02 AM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Dont mean to be a a$$ but i thought were not aloud to advertise on this forum.
Old May 24, 2003 | 10:09 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
First, 2 Dope the price is only $350, that includes a custom crossmember. You have to supply your own headers, cats, mufflers and tips.
Second, tbfirebird if he was selling the exhaust and was on here telling people to come buy my exhaust...blah....blah...blah...that would be a different story. But, chance is that not everyone here has heard of it and he is just letting people know that they have another option when it comes to exhaust. There is always someone wondering if someone makes dual exhaust for our cars and here is the answer to ALOT of people questions.
Old May 24, 2003 | 11:44 AM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Any chance that the included crossmember can be modded to use a Spohn Torque Arm?
Old May 24, 2003 | 11:51 AM
trans_am_ta_84's Avatar
Car: 89 trans am
i think i'll be buying that bad boy. what kind of headers is good to use with that? just to ask this question, which i'm sure it would but would headers and 2.5 pipe put out more power then a 3" cat back?
also where would you put 2 mufflers
Old May 24, 2003 | 01:24 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
The tourque arm question is a good one, you would probably have to ask them about that. As for the mufflers, they would be located where the stock muffler would be.
Muffler pics:
As far as power goes he has a supercharged 305 that has run a 12 flat in the quarter. Not too bad if you ask me!
P.S.
These are pics of ******* AMAZING exhaust!!!
Old May 24, 2003 | 04:11 PM
zNucleaRz's Avatar
Car: 84 Z28
Engine: GMPP 350 HO
Transmission: 700R4 + Shift Kit
Axle/Gears: Auburn Posi; Richmond 3:73 Gears
What type of X-Crossover?
who makes the X-Pipe used in above pics? thanks....
Old May 24, 2003 | 06:34 PM
Car: 89 trans am
what kind of mufflers are they?
Old May 24, 2003 | 06:38 PM
Car: 89 trans am
also, to me, this pipes looks bent. and if it is then i heard bent pipe is no good. so if it's bent and you will hurt hp or whatever, why bother?
Old May 24, 2003 | 09:10 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Those mufflers are made by stainlessworks exhaust they do not come with the kit. They are like $120/muffler, $140/muffler if they are polished like willie's are. It is expensive, but to me it is worth it.
That pipe does look a little bent, but it could just be the light. That is where they have the x-pipe located so it could also be discoloring making it look bent. Either way yes a bent peice of exhaust tubing would not be good for flow.
Oh and nuclearz the exhaust is made my maniac motors.
Old May 28, 2003 | 01:07 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Axle/Gears: 3.23 Posi
anymore pics, info? This is kinda interesting to me.
Old May 28, 2003 | 02:00 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
would you have to use long tube headers with this exhaust .i have a set of dynomax headers that are about even to the bottom of my oil pan with the collectors. i could probably moify my y pipe to make it work. keep the info coming.
Old May 28, 2003 | 03:45 PM
Marc 85Z28's Avatar
The price has gone up to $400 due to the US/Canadian exchange.
I am talking to them right now, getting ready to place the order.
The trans crossmember now comes powdercoated!
They are also going to attempt custom fitting the pipes to my SLP headers.
I bought 2 stainless chambered mufflers from www.sweet-thunder.com and plan to route them the same way Willie did. Sweet Thunder's muffler cost half of what others want...
Old May 28, 2003 | 05:52 PM
2 dope's Avatar
Engine: 305 LG4
does that sytem exit on both sides or just on the passenger side?
Old May 28, 2003 | 06:31 PM
CGCBandit's Avatar
That looks really cool. Does it come as a "catback" or do you have to weld all the pipes together?:hail:
Old May 28, 2003 | 11:36 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
It is cat-back as long as you use shortie headers with the cats. You cannot run cats with longtubes.
Old May 29, 2003 | 12:26 AM
2 dope's Avatar
Engine: 305 LG4
if its a true dual exhaust then how could it be a cat back system ? True duals to me means either no cats and 2 mufflers or 2 cats and 2 mufflers, i may be wrong i dunno
Old May 29, 2003 | 04:25 PM
stroken_camaro9's Avatar
Car: 92 camaro rs
Transmission: th350
exhaust
are u positive that there is no ground clearence problems? would that exhaust work with hooker comp headers?
Old May 29, 2003 | 04:36 PM
Scott_92RS's Avatar
Car: 1992 RS
Re: exhaust
Sure looks like Super Comps in the pics....
Old May 29, 2003 | 09:21 PM
Car: 92 camaro rs
Transmission: th350
does it matter? aren't they basically the same thing
Old May 30, 2003 | 12:31 AM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
I'm not trying to ruin this for everyone but that looks like a very low quality set up.
If they were to do it right then it wouldn't be soo many pieces all patched together it would be no more than 2 lenths of pipe with mandrel bends instead of pieces welded together.
good luck to those that are going with this
Old May 30, 2003 | 01:31 AM
matts90firebird's Avatar
can someone help me out here i cant seem to get a contact # or email or anything from that web site....maybe its 3 in the morning and im not my brightest but can someone give me the email for them
im definatly buying this asap
thanks
LCpl Kurapka
Old May 30, 2003 | 11:56 AM
Marc 85Z28's Avatar
Open mouth - shove foot in.
Have you ever made an exhaust system... Thought not. I have. They do the same thing everyone else does. They buy prebent mandrel pipes and cut and weld them to fit. This a small performance shop, not a multi-million dollar company.
Matts90firebird - the email address is right on the site. For some reason the order form won't work.
Old May 30, 2003 | 09:43 PM
2 dope's Avatar
Engine: 305 LG4
Willie, on your setup, the mufflers are parallel, do the i pipes run on the stock side and the one pipe make a crossover to the left along the diff and then exit on the right side? If you could possibly show a drawing or somethin to show the set up from an undercar view?
Old May 30, 2003 | 11:25 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Go to his site and click exhaust. There are tons of pics there.
Here is the site--
l
l
l
V
http://members.optushome.com.au/iroc.../willie_irocz/
Old May 31, 2003 | 12:50 AM
i know other people can see the contact address but for some reason i cannot please someone type out email address i need this exhaust asap
its the final straw b4 i cry and go with single exhaust
i cannot see the contact info on that site please someone help me thanks guys
Matt
Old May 31, 2003 | 01:25 AM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
Here ya go!!
smplgrn@sbcglobal.net
Old May 31, 2003 | 01:42 AM
2 dope's Avatar
Engine: 305 LG4
cool, thanx amish that was what i figured the j-bend.
Old May 31, 2003 | 09:07 AM
thanks for the email addy
and does anyone here besides wille have this exhaust ?
if so how do you all like it? any problems i should keep my eyes open for
and could i use twin 40 flowmasters
Old May 31, 2003 | 12:55 PM
amish_Z28's Avatar
Car: 1990 RS
Engine: too small
First, willie does not have this exhaust, his exhaust is completely custom fabricated. Although they are very, VERY similar. As far as problems, you might have to be a little more careful with speedbumps and whatnot, but the clearance seems to be pretty good. Flowmasters 40 will be a very tight fit, I don't know if they would fit.
Old May 31, 2003 | 06:01 PM
2 dope's Avatar
Engine: 305 LG4
ya i think you would need to use the chambered mufflers or glass packs.
Old Jun 1, 2003 | 08:14 AM
AbsoluteZero's Avatar
mufflers...
I'm really looking in to getting this setup and I was wondering would 2 4" mufflers fit? I've been looking for some round mufflers and most that I've found have 2½" inlets and outlets but they have 4" casings. Because you said its very tight for space and you only showed a pic of a similar system for the mufflers which looks like it has absolutely no space for bigger mufflers.
Old Jun 1, 2003 | 11:41 AM
Car: 89 trans am
for like the 2nd time now 2 flowmaster mufflers wont work there is not enough room under the car. that is one of the reason nobody can make a dual exhaust. read the above post thats probably the only mufflers that will work unless you can get the 2 pipes into 1 pipe and add 1 muffler and the 2 out's for your pipe but that would be incredibly dumb. i was thinking about getting this but i don't like the looks of it myself.
Hodge
agreed
