touch up paint code??
Old May 28, 2003 | 02:11 AM
Kaps's Avatar
Hey, Its an 88 GTA with the red metallic stock color. Anyone know the codes and brands for touch up paint that will match the best? Thanks
Old May 28, 2003 | 06:16 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I find DupliColor matches very well. You can get your paint color WA number off your RPO sticker and usually there is a booklet where you buy the paint to look up the correct color.
Old May 28, 2003 | 10:44 AM
Kaps's Avatar
Anyone know the RPO code for my paint? The second time I need rpo's, and they are not on the car
Old May 28, 2003 | 11:48 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Is the WA number by any chance on the door sticker?
Old May 28, 2003 | 12:27 PM
Kaps's Avatar
Have 2 door stickers, one is for tire pressure and the other is something about meeting all weight theft ext. requirements. A few numbers, but none have WA above below or on the numbers...
Old May 28, 2003 | 01:25 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
Depending on the year of the car, the RPO sheet can be in the center console, or in the rear locking compartment on the drivers side of the hatch area. The paint codes will appear near the bottom of the sticker.
Old May 28, 2003 | 01:39 PM
Kaps's Avatar
Yeah, someone took the the RPO codes off the car, Can see where they used to be in the console, nothing in the trunk glove box, anyone have the same color car?
Old May 28, 2003 | 01:45 PM
Scott_92RS's Avatar
Car: 1992 RS
Try going to www.paintscratch.com, and choose 1988 Pontiac, then All Models. There are 52 colors available, a few are red. You may be able to tell by looking at the color, if not, I'd wait for a more specific answer.
Old May 28, 2003 | 02:20 PM
Kaps's Avatar
Any on know which one goes for a 88 GTA? same color name, 2 diff numbers?
Flame Red Metallic Clearcoat 74/WA8748 Flame Red Metallic Clearcoat 74/WA9535
or the actual paint RPO code?
Thanks for the site
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
kah992
Aug 19, 2015 02:55 PM
Armored91Camaro
DIY PROM
Aug 12, 2015 09:41 AM
