? for those using the Zexel-Torsen diff. unit
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
When I install it should I use the limited slip additive?Someone at another board told me NOT to use it cause it caused there's to slip & act like a one-legger.Anyone use or not use?Thanks
BD3
BD3
Car: 92 Camaro RS
Transmission: T5 manual
A Torsen is not a locker, it's uses worm gears to transfer torque from the slipping side to the other. A standard Torsen can peg-leg like an open diff if the slipping side loses all traction (like on ice or if the tire is lifted off the ground).
You don't need to use limited slip additive with a trosen, but GM does to prevent gear noise.
Originally posted by Marc 85Z28
Ditto? Ever read the Service Manual? I have and it clearly states to use the additive.
Originally posted by Gunny Highway
So what's the final verdict??? My posi goes in on Tuesday.
So...if you're reading anything other than a manual for SLP-modified 4th gens this doesn't apply.
Marc 85Z28, you taking shots at GMTech is like a Poodle barking at a Rottweiler.
Originally posted by kevinc
Just to close this one out, if you're referencing any factory service manuals and applying this to a Torsen you're wrong. The Torsen was installed after assembly in SLP-modified 4th gens.
ALL LS1's received the Torsen, stock, from the factory. The Auburn unit was the only optional diff from SLP.
Car: 91 RS
Engine: 350 TBI
Well let's put it this way. . . if I did throw in a bottle of Posi additive, WOULD IT HURT ANYTHING???
And secondly, how many bottles of 85W-90 should I give the guys at the shop? Basically I'm supplying all the parts and they're just doing the labor.
Thanks guys,
-The Gunny
Thanks guys,
-The Gunny
First things first. The Service Manual calls for 75W-90 synthetic, not 85W-90. You will need 2 bottles. AND it also calls for the limited slip additive. You can go by what a few uninformed people here suggest, or what GM recommends.
Car: 04 GTO
Transmission: M12 T56
gmtech may or may not be a certified GM mechanic.
If the manual calls for additive in the late 4th gens with a torsen, i would chalk it up to holdover language from the old documentation and / or to cover the possibility that there was a clutch type posi installed for whatever reason (SLP, leftover parts, etc)
Posi additive is a friction modifier to help clutches slip against each other more smoothly. Ever leave additive out of a clutch type posit rear? Notice how it tends to bind more.
Now as stated, a torsen DOES NOT have a single clutch in it. So why it would require a friction modifier is beyond me. It won't hurt it, but it sure doesn't do anything either.
So, if the question is, what do i believe, a gm service manual, or simple logic, well logic rules the day for me. GM service manuals also recommend 100k mile plug change intervals and the smallest oil filters made for applications. They are not gospel.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Since some of the cars (i.e. SLP cars) had the auburn, I'm sure it was easier for the manual to just keep it simple and say to add it to all of them. It's not going to hurt anything in the Zexel, and GM gets to make a few more bucks on unecessary parts.
Holy Cr@p! What a bunch of whiners. Damn, Auburn does not have a single clutch in it but still recommends using a friction modifier. The friction level in the differential determines the torque bias between the gear assemblies. I.E. changing lubes will change the holding power of your limited slip differential. Too high a friction level will cause a popping, yes even with non-clutch type differentials. By modifying the friction properties of standard differential lube with an additive, the wear properties and torque bias of a differential can be maintained at the MANUFACTURERS recommended levels. I mean how would an arrogant company like GM know what to use? GM just speced out the differential, lube requirements, and had someone make it to fit their cars. (sarcasm) After all "common sense rules".
Check this link to Torsens' own website and you will see that even Torsen recommends a lube additive!
http://www.torsen.com/general/genera...rential%20work
Car: 89 IROC
Engine: 350 HSR
This why I added it btw-->GM issued a technical bulletin adding modifier to the rear axle oil. This was done to quiet what we call a "Rusty Screw" noise that we heard in a very small percentage of vehicles. This does not happen in all cases, however to address owner's concerns we asked that the modifier be used in all instances to insure that the driver would not get this noise. When replacing the fluid it is at the owner's discretion whether or not to add the modifier. Elimination of the modifier does not affect durability of the differential.
BD3
BD3
Car: 04 GTO
Originally posted by IROCZ4BD3
...When replacing the fluid it is at the owner's discretion whether or not to add the modifier. Elimination of the modifier does not affect durability of the differential.
Right, like i said, it doesn't *need* the additive as they clearly state right here. Thanks for the reference to back up what i was saying.
Car: `86 SS / `87 SS
If you don't know what you are talking about, please don't prove your ignorance.
1998 LS1 f-bodies received the Auburn type posi stock, from the factory. The upgrade was the Torsen.
1999 - 2002 LS1 f-bodies received the Torsen T-2, and the upgrade was the Auburn.
You've some Ritalin to take.
I do not consider the metal-to-metal interface of an Auburn to be a clutch, more of an interference fit. By clutches I mean renewable friction materials. The Auburn is not renewable!
BTW, "need" oh you don't need to take the advice of GM just understand that they have alot more experience with these differentials than any of will have in a lifetime! If GM recommends using a lube additive then it would be essential to me. I.E. (I suppose you don't need to run premium fuel in a high performance engine but why would you kick yourself in the nads.) Not running a lube additive would just be sacrificing a possible benefit!
Originally posted by jmd
[B
don't capitalize ALL.
[/B]
[B
[/B]
I know the 98SS brochure that I have states the Auburn Pro as an option over the Torsen for $699.99
ALL LS1's got the Torsen standard. Don't believe me?
Once again, don't capitalize ALL.
Goto www.ls1.com Or do you want me to scan in the 98SS brochure I have that clearly states the $699.99 Auburn option over the standard Torsen...
I post a little bit on LS1.com
edit: Nice edit of your post.
Car: 87 Formula
Engine: 327
CamaroMike I do not consider the metal-to-metal interface of an Auburn to be a clutch, more of an interference fit. By clutches I mean renewable friction materials. The Auburn is not renewable!
