My ram-air pics!
Old Jun 9, 2003 | 06:03 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
My ram-air pics!
Old Jun 9, 2003 | 06:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Old Jun 9, 2003 | 06:05 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Old Jun 9, 2003 | 06:41 PM
25THRSS's Avatar
Cool
Old Jun 9, 2003 | 06:43 PM
quick 'lil TBI's Avatar
frickin' sweeeeeeeeet!!!
Old Jun 9, 2003 | 06:44 PM
arrowcamaro's Avatar
Car: '88 GTA
Engine: L-98
truly a nice set up.....i have 2 questions for ya:
1- do you have any overheating issues?(i know most cooling air comes from air deflector underneath)
2- do you plan on putting some mesh in front of the openings or maybe spray paint the ducts black or maybe both? really though nice set up i might have to copy that possibly if ya dont mind
Old Jun 9, 2003 | 06:57 PM
BTS88IROC's Avatar
What did you make that out of?
Old Jun 9, 2003 | 07:12 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Looks like galvanized heater ducting.
Great job man!
Old Jun 9, 2003 | 08:19 PM
MdFormula350's Avatar
nice job :hail:
Old Jun 9, 2003 | 09:32 PM
theSteve's Avatar
Car: 1985 Trans Am
Engine: upgrading...
Transmission: upgrading...
wow. that's damn sweet.
nice nice nice setup, i'm jealous.
Old Jun 9, 2003 | 09:56 PM
82firebird's Avatar
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
Thats awesome. How much of a difference can you tell in power, sound, etc. ?
Old Jun 9, 2003 | 10:19 PM
FLYNLOW92rs's Avatar
Lookin Good....:hail: :hail:
I would suggest some gutter guard and paint it black....
Old Jun 10, 2003 | 12:28 AM
Mathius's Avatar
You can buy those for $45.00 each on Ebay, there's a guy in Arizona selling them. Or you can pay $120 I think and get them from thirdgen resources.
Mathius
Old Jun 10, 2003 | 09:46 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The car still runs 170*-180* with the boxes in and thats ragging on the car in 90* weather. However, a long time ago, I wired my two fans in parallel which are controlled by the Jet cool fan switch. I also have a 180 thermostat.
I had the boxes made at a local metal fabricating shop. They were designed on the computer and then the machines laser cut the patterns out of a sheet of galvanized sheet metal. Then one of the techs welded them together and siliconed the joints.
I'm not going to paint them black. Black retains heat and the galvanized sheet metal actual stays pretty cool! I dont want to coat them with any paint and lose the cooling properties of that metal. The boxes are really light. They only weigh maybe a pound a piece.
You really start to feel the difference from 55 on upto as fast as it will go. Plus not only is it getting "Rammed air", the motor is also getting cooler air then the stock setup pulls.
I am looking for something cool to use for grill screens. I was thinking about using the same screen material that Z06's use, if I can find it!
Any suggestions on screen material?
Mike (1bad91Z)
Old Jun 10, 2003 | 10:38 AM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
looks really good!
Old Jun 10, 2003 | 10:40 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Originally posted by 1bad91Z
[B] Plus not only is it getting "Rammed air]
Care to prove that one?
Old Jun 10, 2003 | 10:56 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
The fact that it's pulling cooler air from the outside, rather than warmed "engine" air (air that the radiator etc... has warmed up) should be proof enough.
Just think of the same principal of a cold air kit. What does that do? It pulls cooler air from outside of the motor compartment.
If you want to go one further, send me an air temp gauge and I'll be glad to hook it upto my lid. Then I'll record temps with the stock setup and the ram air both at idle and both while driving.
Or, you could just take my word for it. Your call!
Mike (1bad91Z)
Old Jun 10, 2003 | 12:28 PM
deadtrend1's Avatar
Ram Air is positive manifold pressure. Pulling a coller charge of air into your manifold is Cold Air Induction. Lot of people claim CAI as RAM AIR.
I like your setup though. But I always felt z-28 grilles look empty without fog lights.
Old Jun 10, 2003 | 02:48 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
This setup can be considered both CAI and Ram-air. It effectively does both! It's drawing cooler air from outside the engine bay and it's ramming it in the intake the faster you accelerate. It definitely pulls harder in the upper RPM's and in the higher speeds. It's a great mod!
Old Jun 10, 2003 | 03:14 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Does anyone have any ideas on some grill screens? What material would you recommend?
Old Jun 10, 2003 | 05:09 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Ram Air has been proven time and time again, to be mere myth on cars. The mere effect of ram air woul necesitate you going 300+mph, then having a scoop that would in effect trade off dynamic engery for static energy, (ie moving to compressed) then it would need a straight shot into the motor, any bends in the tract will decrease the pressure.
Thiers not a single intake on the market that can give you Ram air, thier all cai's.
And the reason it pulls harder at upper rpm, is the need for more air is now fullfilled, not because its getting extra air rammed in ala forced induction.
Dont get me wrong, its a great cai, i have the same setup (well close..... ) on my 90, but in no way is it ever ramming air into the cylinders, hell ponitac admits they only used it as a gimmick word for thier cai back in the day........
Either way, nice setup!
Old Jun 10, 2003 | 05:12 PM
SLP IROC-Z's Avatar
Car: 1999 Z28
Axle/Gears: 3.23 10 Bolt
werd to that!
Old Jun 10, 2003 | 05:28 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Well anyways, still need some suggestion for grill screens. Anyone?
Old Jun 10, 2003 | 05:33 PM
83TransAm's Avatar
Car: 1983 Trans Am
Engine: 355 SBC
Transmission: 700R-4
That is extremely bad a$$. I wish I could do the same thing on my bird but haven't quite figured out a good way yet. Rock on man, great setup!
Steve
Old Jun 10, 2003 | 05:46 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thanks! It turned out pretty nice.
I was thinking about using Z06 screen for the grill screen inserts(the same stuff that's used in the Z06 vents).
I figured you guys would know of some stuff that would look nice for the grill screens (besides a billet grill). I just want to screen each opening so that it doesn't suck in a plastic bag, or a bird, or mustangs, whatever.......
Anyone?
Old Jun 10, 2003 | 05:54 PM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
could put the fog lights back.
Old Jun 10, 2003 | 06:04 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
My factory fog lights are trashed, so I didn't reuse them. Also, a fog light wouldn't stop all that much from being sucked in and block air filters.
Hence, the need for grill screens...........
Old Jun 10, 2003 | 06:51 PM
JimmyG-91Z's Avatar
There are some pics floating arund of people with screens in the grill, I'll try to find them
Edit: There a a couple in here https://www.thirdgen.org/techbb2/sho...ighlight=grill
More Here (fixed it) https://www.thirdgen.org/techbb2/sho...ighlight=Grill
Old Jun 10, 2003 | 11:26 PM
1989 Iroc-Z28's Avatar
Car: 1989 IROC-Z
Hi, I wouldn't mind doing that cept for one thing, what happens if you drive around in the rain? Since I have a MAF would water get up there?
Old Jun 10, 2003 | 11:41 PM
Gutter Guard from Home Depot
$3.89 for a 20 ft roll....
Get it painted black...
It's the same stuff i used in my fender vents shown below.....
Old Jun 11, 2003 | 09:31 AM
CustomX's Avatar
Car: 90 irocz
Engine: 350tip
Most non paper filters will work just fine.
Old Jun 11, 2003 | 10:13 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I dont drive may car in the rain. Hell, I barely get a chance to drive it on sunny weekends! However, back before the new motor and new paint job, when I first put the ram-air boxes in, I did drive it once in the rain. The bottom of the boxes were damp, but the water cant sit there the way it's angled, so it drains well. The air filters were dry, but the bottoms of the boxes will get damp! Hope that helps!
Thanks for the grill ideas, keep 'em coming!
Mike
Old Jun 11, 2003 | 10:41 AM
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I know exactly what you can use for your screens on your Ram Air Boxes. Use "Expanded Aluminum" I have a black 91 Z28 exactly like yours....with some mods of coarse. I bought my boxes off of ebay....and I noticed a pretty big difference....along with all of my other mods. I noticed a more crisp throttle response....specially on crisp cold nights. I've only floored my car once from a dead stop on a cold night....and it hit all 3 gears...and kept going...so I let off. My transmission has been built though.....before I bought it so that's probably why....anyhow....you can get expanded aluminum at "Low's" or "Home Depot" I also painted my ram air boxes....looks really good
Old Jun 11, 2003 | 11:14 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Well cool! Where's some pics?
Old Jun 11, 2003 | 12:54 PM
Engine: 5.7
Sorry man, I don't have any pictures of the installation or anything...Here is a picture of the front nose....I still have my foglights mounted though. You see the grill on my SS hood? That's what expanded aluminum is.....you could paint it...or keep the aluminum finish....
Old Jun 11, 2003 | 12:56 PM
Engine: 5.7
closer pic of the grill....in this picture..I was just test fitting the grill....it looked a little messed up....I've recently re-done it...and it looks 10 times better....but that is what expanded aluminum looks like...and I think that would be your best bet. Good Luck Dude
Old Jun 11, 2003 | 03:13 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
What kind of rubber guard did you put arround the screen?
Old Jun 11, 2003 | 05:46 PM
hawksthirdgen's Avatar
Premium Sponsor
Hey guys we sell a Ram Air kit almost just like that for 149.95 if anyof you guys are interested.
Thanks,Bruce
www.hawksthirdgenparts.com
Old Jun 11, 2003 | 10:43 PM
Engine: 5.7
On my SS hood? It came with a black grill...and I just installed the expanded aluminum over it.
Old Jun 12, 2003 | 02:15 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Ok, I plan on using the expanded aluminum for the grills. So, what would you guys recommend to use for the guards arround the grills (like custom84 has arround the grill in his hood).????
Old Jun 12, 2003 | 02:59 PM
05kcilS's Avatar
Car: 1991 Z28
Engine: 350 L98
Thanks,Bruce
yeah
your ****ing ripping people off. there's a guy who sells them on Ebay. for 50 bux!
and he spray paints them black for you!
find him on ebay. once i see him selling them again, i'll post a link for everyone.
Old Jun 12, 2003 | 03:23 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Looks really good.
I didn't read the whole post, feel any improvement?
Old Jun 12, 2003 | 05:55 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I had it on the car when I had the stock motor and it made a nice improvement.
Now with the new motor, it made a really nice improvement on the butt dyno! It pulls even harder from ~ 55mph or so all the way upto you get scared and slow it down!
I would recommend this mod to anyone, provided they can keep the water temp as cool as mine runs.
Old Jun 13, 2003 | 12:19 AM
Engine: 5.7
it made a really nice improvement on the butt dyno! It pulls even harder from ~ 55mph or so all the way upt o you get scared and slow it down!
I agree.....seems like my car wants to go a lil faster...and a lil faster....I recommend them...I was quoted from 5-10 extra horse....not to sure though
Old Jun 13, 2003 | 12:32 AM
devianb's Avatar
Nice work
Old Jun 13, 2003 | 10:49 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
Thank you!
I may be making up a few sets identicle to mine, but I was thinking of making them out of black ABS plastic. Anyone interested?
Mike (1bad91Z)
Old Jun 13, 2003 | 10:53 AM
ctandc's Avatar
Got a price estimate on 'em if you do crank a few xtra sets out?
Let me know
Old Jun 13, 2003 | 10:59 AM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
They would probably sell for $50 - $70 or so. The ABS plastic isn't all that cheap. It's some durable stuff!! And it weighs nothing! The plastic welder isn't cheap either. I'm not out to rape people. The price would be my cost plus $10 or so for my time. Once I have a figure, I'll let you guys know.
Mike (1bad91Z)
Old Jun 13, 2003 | 04:24 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Looks great...Those are so easy to make. I worked as a sheetmetal mech for 6 yrs. I could make those buy hand in 20 minutues. I just dont have the shop tools to make it quick and easy now.
You can get the expanded screen from the shop that made those for you.
Old Jun 13, 2003 | 04:29 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I ended up finding the screen that I'm going to use at Lowe's. But, thanks!
I think the ABS plastic boxes will be better than the metal. My car will be the "test lab rat" first though!
Mike
