Has anyone tried the plastic 99-02 fbody gas tank in a 3rd gen yet?
Old Jun 25, 2003 | 11:07 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
I know it was discussed several months back. Just wondering if anyone had any results yet.
Old Jun 26, 2003 | 02:46 AM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
Im going to do the swap whenver I can, but first I need the tank...
99-02 the only years for plastic tanks?
Old Jul 1, 2003 | 07:14 PM
chooch-88formula's Avatar
I am working on this now... so far I have the tank but had to order another sending unit because the one I have is broken. But, I have checked the resistance on the level sensor and It has different readings. My old sensor readings were 11.4ohms = empty and 101ohms = full. The 2000 gas tank is 40ohms = empty and ~240ohms = full. So when I hook up the tank to my car 1/2 tank reading on the guage is actually an empty tank. You might have to go with an aftermarket guage... I'm not sure yet I just got done doing the readings.
Old Jul 1, 2003 | 07:48 PM
I did find a few guages avalible at summit ... only one company makes them as far as I can see, Autometer.
The look kind of ugly but I gues They would Do the job
http://store.summitracing.com/partde...t=4731&from=MG
Old Jul 1, 2003 | 07:55 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
what is the benift of running a plastic tank?
Old Jul 1, 2003 | 07:59 PM
It only cost me $85 for a complete tank that won't rust.... In NY this is a good thing.
Old Jul 1, 2003 | 08:33 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
85$ new? Or used from a bone yard?
Is it a direct fit?
Old Jul 1, 2003 | 08:58 PM
It was used from ebay...
I'll find out later if it's a direct replacement... but it looks promising.
Old Jul 3, 2003 | 11:08 AM
I took some measurements last night and found the the band strap locations are the same. I have heard the the filler neck might be longer but it doesn't matter because most of the filler neck on the plastic tank is mostely rubber hose. So you can make it any size you want.. I took some pics and I'll post them later because right now I'm at work.
More Later....
Old Jul 3, 2003 | 11:48 AM
Morley's Avatar
Those empty/full readings sound like what Ford uses/used.
Old Jul 3, 2003 | 03:09 PM
Yup they are empty/full readings... I think GM switched over with these new plastic tanks.
http://chooch.dydns.com/Plastictank/290small.JPG
http://chooch.dydns.com/Plastictank/291small.JPG
http://chooch.dydns.com/Plastictank/292small.JPG
http://chooch.dydns.com/Plastictank/295small.JPG
Old Jul 3, 2003 | 04:05 PM
Z_Ghost's Avatar
Never mind that was the wrong idea.
Old Jul 3, 2003 | 04:10 PM
I tried that ... If you tried to get the empty line correct... (which would = 11.4 ohms) then when the tank is full, the resistance is 15ohms ( about an 1/8 of a tank)
I think I have another way to do it..... I'll let you know more later... It's just a theory for now...
:lala:
Old Jul 9, 2003 | 06:17 PM
As you can see in the pic my gas line and return lines are cut.... Does anyone know how they connect these hard plastic lines to the metal ones? How long are the lines? and do you have any pics?
Attached Thumbnails Has anyone tried the plastic 99-02 fbody gas tank in a 3rd gen yet?-picture-321.jpg
Old Jul 9, 2003 | 09:07 PM
Rage13's Avatar
Car: 89 Firebird
do those tanks hold the same ammount? in the pics the plastic one looks smaller to me..
Old Jul 10, 2003 | 03:17 PM
The plastic is rated for 16.5 and the metal one is rated for 15.5.... the plastic is taller...
Old Jul 10, 2003 | 03:24 PM
I went to a gm dealer today to find out more about the fuel lines and it seems they are a little bit differeent than the ones on our 3rd gens. I'm still unclear about the connectors that are on the ends of them. I was going to order them but they want $20 a pices for these short lines... I'm gonna try and get them from a Yard.
From what I could see on the computer screen at the dealer is they have a quick connector on the ends in stead of a 6-an fitting or so. When I get them I'll take pics and should you what they look like.
I hope this is worth it in the end....
:lala: :lala:
Old Jul 10, 2003 | 03:26 PM
Briansz28's Avatar
I think you can use a piece of rubber hose and hose clamps to join the plastic to the steel lines. At least w/ carbed engines- don't know about FI...
Old Jul 10, 2003 | 03:34 PM
These plastic lines are a bit to britle to put a hose clamp on... It might work but there will be about 50psi at this connection and a gas leak would be bad M-kay
Old Jul 10, 2003 | 09:08 PM
88 350 tpi formula's Avatar
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
I think you could use the rubber fuel rail lines found on ford and some of the early 3.1 and 3.3-3.8 gm cars they are quick disconnect but are rubber lines in stead of plastic
Old Nov 28, 2003 | 10:40 AM
drain89's Avatar
Did you ever get this finished? How'd it turn out?
Old Dec 4, 2003 | 02:15 PM
It was actually a pretty straight forward installation. Napa has some adaptors to go from the treaded adaptors to the quick click style. The biggest problem i had was the return line.... The return line hooks up to the pickup assembly and goes thru some kind of plug.... for some reason the gas would not gothru it so i had to gut it out so the gas would flow....
The other problem is the level sensor is different... but you can buy an aftermarket level guage to work with it.
our cars guage works with 0-90 ohm sensor ... the new tanks are 40-240 ohms.... so if you hook it up to your guage ...when the tank is empty your guage will read about half or so.
you check out some pics on my ftp site.
ftp://ftp.chooch.dydns.com/Plastictank/
Old Mar 24, 2004 | 10:08 PM
drain89's Avatar
bringing this back from the dead for everyone to compliment the other post on this.
Old Mar 24, 2004 | 11:36 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i just picked up a tank today.... the sending units LOOK the same to me..... imma do this down the road. no reason to drop my tank at the moment.
Old Mar 24, 2004 | 11:37 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
what i should have said is imma try to put a stock 3rd gen sender into the plastic tank. should fit like a glove. and keep the stock fuel gauge
Old Mar 25, 2004 | 02:16 AM
drain89's Avatar
Everything I've ever heard from people who are familiar with both 3rd and 4th gen sending units say their not interchangeable. However Magnus put his old sender from his 97 sending unit into his 99 model sending unit.
Old Mar 25, 2004 | 09:42 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
Street and performance sells adapter fittings to that work on the LS1 fuel rails, I believe they are the same fittings on the LS1 fuel tank:
http://www.hotrodlane.cc/onlinecatal...logpage63.html
As you can see in the top left of this ad you can get the fitting to use AN lines. Then you can just buy the SN fitting that converts your stock hard-line to a AN fitting and you should be able to run a short about foot length of stainless braided hose from the tank to the fuel lines.
Old Mar 25, 2004 | 10:49 AM
drain89's Avatar
That'll work, I wonder if those are available anywhere else, since they're so high.
Old Mar 25, 2004 | 04:35 PM
Napa had all the fittings I needed... I have been running this setup since last year with no problems... I can'tt say that it is a better setup but I needed to change out the tank anyways and this was a good match for me..
Just to update my setup:
I currently have a 350 TBI with a zz4 cam and 305 heads and flat top pistons with about 10:1 compression.
I dynoed it at 300hp and 400 ft/lbs torque
I what to put the lt1 intake on it so that's why I also wanted the higher pressure fuel pump. I'm also running an aftermarket fuel regulator ... it works great but man is it working overtime tring to get the stock fuel pressure down to 15 psi hehe
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
