LCA relocation bracket's
Old Jul 25, 2003 | 09:25 AM
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Do the Spohn relocation brackets come with instructions(stupid question)? They look straight forward, but is there anything special I should know before I install them??
Old Jul 25, 2003 | 09:32 AM
Dewey316's Avatar
Car: 1990 Camaro RS
yes they come with instructions, and yes they are very straight forward.
Old Jul 25, 2003 | 09:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Do a search. Somebody posted some absolutely beautiful pics of them, you can see very clearly what's involved. Which is not a whole lot actually, it's a real simple thing.
Old Jul 25, 2003 | 09:59 AM
Dewey316's Avatar
Car: 1990 Camaro RS
here you go...
these are the pics my good friend mike (Schultzy89GTA) posted....
Old Jul 25, 2003 | 11:18 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Rex x's Can you provide a link?
Old Jul 25, 2003 | 11:29 AM
Dewey316's Avatar
Car: 1990 Camaro RS
http://home.attbi.com/~mschultz111/lcaon2.jpg
http://home.attbi.com/~mschultz111/lcaon3.jpg
Old Jul 25, 2003 | 12:09 PM
Car: 91Z
That's perfect, thank's guy's!!:hail:
Old Jul 27, 2003 | 09:06 PM
wm_sorg's Avatar
Dewey316,
Are those LS1 brakes? Please post some pictures of the cable setup. I can not figure out how to deal with them.
Old Jul 27, 2003 | 09:22 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: LCA relocation bracket's
Actually there is, he makes no provision for locking them on the axle housing, so it is imparitive that you measure from some point on the body to the lower mounting hole so that both sides are located the same to prevent the cocking of the housing and causing the car to dog leg down the highway. Once you mount them on the housing you will see what I mean, they will swivel back and forth.
So...you will need a measurement to get them in the proper position before welding.
BTW: To mount the LS1 E-brake cables to the body I fabricated a cable mounting bracket (see pic) below.
Old Jul 27, 2003 | 09:29 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Originally posted by wm_sorg
Dewey316,
no they are thirdgen PBR's
Old Jul 27, 2003 | 09:31 PM
Dyno Don's Avatar
LS1 E-brake cable bracket:
Old Jul 28, 2003 | 09:04 AM
wm_sorg's Avatar
Don,
Can you show me a picture of what it looks like installed?
Old Jul 28, 2003 | 07:00 PM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
nice to see good quality welds there
Old Jul 31, 2003 | 04:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It looks like these take a lot out of ground clearance- anyone notice a problem? Or are they close enough to the tire so it doesn't matter?
Old Jul 31, 2003 | 04:25 PM
SteveSpohn's Avatar
Originally posted by TomP
It looks like these take a lot out of ground clearance- anyone notice a problem, say, over speed bumps? Or are they close enough to the tire so it doesn't matter?
The bottom of the bracket is just about even with the bottom of the shock mount.
Old Aug 1, 2003 | 10:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Steve, thanks! From the pictures (and the angle they were taken from) it looked like they hung lower.
Is it okay to lay such a large continuous bead as a weld? Any danger of warping the original frame area? The brackets look thick enough that they probably wouldn't warp, just wondering about the car. Or would it be better for me to do a bunch of tack welds (like welding in a body panel)?
Old Aug 6, 2003 | 01:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Back up to the top; I'm going to assume that the axle won't warp, unless someone tells me otherwise. And why is a bolt going through the original hole? Just to locate the bracket?
Old Aug 6, 2003 | 04:07 PM
SteveSpohn's Avatar
You're not welding directly on the axle tube, just to the OEM LCA mounting bracket.
The bolt through the OEM hole goes through a supplied spacer sleeve to keep the top of the bracket from squeezing in when you tighten the LCA at the lower mounting points.
Old Aug 6, 2003 | 08:02 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
ohhhhhhh...
Steve is on the verge of 1k posts!
hehe
:lala:
-Schultzy
Old Aug 7, 2003 | 12:02 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
That's what I get for trying to make a short message! That was what I meant; the OEM bracket on the axle, not the axle itself! But thanks for the info! (On warping and the bolt/spacer) It'll be fun to lay a continuous bead instead of doing a bunch of spot welds. Last time I dragged a weld, it was when I was building a tubing-bender frame, and that was, oh, I guess 2000?
Old Aug 7, 2003 | 10:31 PM
ebmiller88's Avatar
It's only about 2-3 inches at the most so one long bead won't hurt that. Plus, those LCA mounts and brackets are fairly thick and should take it.
Here's my question: Do the brackets interfere with the PBR calipers being able to rotate down when changing brake pads? This was brought up in anothe thread concerning BMR brackets but I wonder if the same holds true with Steve's pieces. In the above pic, it looks like the e-brake lever comes awful close... If anyone knows, I'd appreciate some input here.
Ed
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
