Back from the dyno after header install
Old Jul 27, 2003 | 09:39 AM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
First graph shows tpi with stock exhaust vs slp 1 3/4 headers and open cutout. 27rwhp and 21rwtq
Both of these are on stock tbi heads and cam
This one shows the differance between the cutout being opened and closed. Even with stock heads and tbi cam cutout gives more power.
Old Jul 27, 2003 | 10:14 AM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Glad to see your cutout gained you some extra HP. Where's yours located?
Old Jul 27, 2003 | 10:23 AM
91RS5speed's Avatar
Car: 91 RS
It is welded to the end of the y-pipe then the cat and bolted to that.
Old Jul 27, 2003 | 08:07 PM
25THRSS's Avatar
Awesome, awesome, awesome! Very nice gains!
Old Jul 28, 2003 | 12:16 PM
grumpyvette's Avatar
keep in mind that those results while very impressive would be far more impressive with a good flowing intake and matching cam filling those cylinders that allowed the exhaust to build even better flow inertia thru the cylinders, if that exact same data was taken from a 11:1 compression 383, with a stealthram and cam designed to maximize the exhaust flow like most nitrous cams the hp/tq spread would be much larger in favor of the headers
cams like Im currently running in my corvette (example)
http://dab7.cranecams.com/SpecCard/D...1=Display+Card
easily gain 40hp at the peak of the curve with good headers
Old Aug 1, 2003 | 12:21 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Transmission: 5-Speed
91RS5Speed, If you don't mind my asking, what kind of gains did you get when you switched over to TPI? Do you have any dyno charts with TBI then TPI?
Old Aug 1, 2003 | 07:32 AM
25THRSS's Avatar
Just go to his site in his sig. He gained A LOT more with headers than he did with TPI, if anything.
Old Aug 1, 2003 | 12:33 PM
BronYrAur's Avatar
Ah yes I didn't even see that site, thanks for pointing it out.
Old Aug 1, 2003 | 02:09 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
TPI change
I gained 17rwhp & 70rwtq when I switched to TPI from TBI. w/stock manifolds.
Old Aug 1, 2003 | 09:16 PM
Dan88IrocZ's Avatar
70rwtq!!! Holy crap! :hail: :hail:
1992rs/ss
Jan 31, 2025 05:10 PM
1984HO
Mar 19, 2021 11:59 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
