code 33 is back
Old Oct 25, 2000 | 08:14 PM
88tabird's Avatar
code 33 is back
Hey,
When I drive for 45 min + my service eng. light comes on and the car has no power. The idle is fine (does not miss or anything) but when I take off I have to give it gas slowly(cant go over 1500- 2000 rpms) or it starts to cut out and has no *****, but will get up to speed slowly. When I put the jumper wire in 33 comes up. It has new maf & relay. The fule pump is making a hummmming noise could this have anything to do with this. It's
kinda like it's starving for gas but I don't know???????????????????
88 ta 305 auto
Old Oct 25, 2000 | 09:18 PM
rondubbs's Avatar
check your tps voltage.
should be .54 vdc.
if it is high it can give a code 33.
what relay did you change, there are 2 maf relay,, maf power and maf burnoff.
Old Oct 26, 2000 | 12:23 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Like Ron said , check the TPS.
Have you gutted the MAF? I got a code 33 after gutting my MAF, tried to reset the ECM but it didnt disapear until I put the first screen back in.....
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
lee01
Apr 9, 2016 01:56 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
