LT1 ready to run...sorta. please help
Old Aug 23, 2003 | 12:05 AM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
here is a previous post for reference:
https://www.thirdgen.org/techbb2/sho...5&goto=newpost
now its all put together. it has spark but wont run.
the fuel pump has 43psi
the motor will run if you spray carb cleaner in the throttlebody but wont run without it. the noid light is bright when car turns over, but dim on carb cleaner, and goes out when running gas from fuel pump.
any ideas?
this car is driving me nuts, and any help will be appriciated
oh, yeah, its a 95 LT1 in a 92 'maro
Old Aug 23, 2003 | 08:25 AM
Guest
Guest
Posts: n/a
Re: LT1 ready to run...sorta. please help
do you have the right wires on the injetors?
Old Aug 23, 2003 | 11:57 AM
sinner's Avatar
as far as i know. i had a guy i met on this forum do the work. he came highly recomended and has had sucess with his third gens.
any ideas?
Old Aug 23, 2003 | 12:10 PM
sinner's Avatar
https://www.thirdgen.org/techbb2/sho...ight=optispark
according to what i can understand from the post above, its the opti. is this right?
Old Aug 23, 2003 | 04:25 PM
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
How about an ignition fuse? I had one blow out on the highway in my 96 WS6. I would just crank and nothing. Popped in a fuse and ran like it always did
Just a thought.
Old Aug 23, 2003 | 04:27 PM
sinner's Avatar
ill look, but i think if that was it it wouldnt run on carb cleaner
also, a mechanic that was "helping" me had run the opti thru a parts washer that used zep, and the opti smells like ammonia. does that help anyone help me with ideas?
Old Aug 23, 2003 | 05:34 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I'd think he killed your opti, they dont take a liking to much of anything going inside them. Im hoping he didnt, but if i had to put my money on something....
Old Aug 23, 2003 | 05:39 PM
sinner's Avatar
i agree, i got one on ebay for 275 = s/h. i also payed paypal to let me get a refund if its junk. the guy had good reviews, and he said it was brand new, it looked new, but ya never know.
itll be here in a few days, so ill post then, but if anyone has any other things i should test, please tell me i am willing and ready!
oh, and ur right, edelcrap headers DO suck!
Old Aug 23, 2003 | 05:43 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Yeah I have had the misfortune of recently having to work on 2 cars with them, eternally po'd at edelbrock.
Old Aug 23, 2003 | 05:59 PM
sinner's Avatar
not to get too far off topic cause i really need help. my thirdgen is now my only car and it doesnt run.
i ordered em for this LT1 swap in the beginning, and they were junk. i couldnt beleive how crappy they were. so i got slp coated headers. nuff said!
Old Aug 23, 2003 | 08:45 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Ok , without rereading the entire old post what are doing to bypass the VATS??
Old Aug 23, 2003 | 08:51 PM
sinner's Avatar
i bought a bypass module from painless and installed it
Old Aug 23, 2003 | 10:05 PM
TexasLT1's Avatar
Car: '92 RS
The problem you are having is EXACTLY what mine did when the VATS wasn't working. The only way I could keep it running was starting fluid. Make sure any and everything involving the VATs is working right, and make sure the module is installed right. I dont know what that involves, so can't help you there. VATS is the only explanation for what you are going through.
Also, as far as the opti. If its running with carb cleaner, the opti isnt the problem because its getting spark.
*sorry, didnt read your other post first. If you were getting spark, then this would be your problem. Since you're not, check the coil first. If not that, then check the opti.
Old Aug 23, 2003 | 10:39 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Go ahead and get your PCM programmed because you will really need to anyway for the things that arent going to be hooked up. While they are at it have them disable VATS. Then you will be SURE its not the problem you are having.
Old Aug 24, 2003 | 12:05 PM
sinner's Avatar
i am getting spark, so i am worried now. i ordered an opti, because another post came to these symptoms being the opti, but thats alot of money for nothing if that isnt it.
SHOOT!!! this stuff drives me nuts!
Old Aug 24, 2003 | 12:06 PM
sinner's Avatar
where can i get the PCM reprogrammed? what will this cost?
Old Aug 24, 2003 | 04:25 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
Sinner, YGM.
Old Aug 24, 2003 | 04:48 PM
sinner's Avatar
whats YGM?
Old Aug 24, 2003 | 05:34 PM
TexasLT1's Avatar
Car: '92 RS
or contact Bryan at pcmforless.com. He did my PCM and I was pretty impressed with it. I opted to buy the cables and load the program myself, but if you have the time, you can send your PCM to him, he'll load it, and send it back. Prices are really good too, might want to check into it.
If you are getting spark then it definitely sounds like a VATS problem to me.
Old Aug 24, 2003 | 05:43 PM
cd90rs's Avatar
Car: 1990 Camaro RS
Engine: 96 LT1
YGM= You got mail. I sent an email to your yahoo account.
Old Aug 24, 2003 | 06:27 PM
sinner's Avatar
oh, er, umm....ok.. gosh i feel stupid
Old Aug 24, 2003 | 08:45 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
It still makes sense to replace your opti. Especially now that it has been washed in ZEP cleaning fluid.
If your engine runs when you are spraying it then you should check to see if your injectors are firing. I am also inclined to believe that you are having VATS related issues as well.
Old Aug 25, 2003 | 12:01 AM
sinner's Avatar
the injectors fire bright with a noid light when turning over, but go real dim with key in on position
Old Aug 25, 2003 | 09:53 AM
wm_sorg's Avatar
Sounds like you may need to get an OHM meter and start measuring amperage and voltage readings. Two years ago I had an issue with a bad fuel pump relay. Though the realy was functioning, it was not allowing enough amperage to power the fuel pump. I could not have solved this problem without the OHM meter.
Also, you need to make sure all your grounds and connectors are good. I have seen a lot of strange things happen traceable to bad grounds.
Old Aug 25, 2003 | 10:58 AM
mat89RS's Avatar
Sinner, how about C100 connector (underhood fusebox) injectors fuses, maybe you have a short or damage cable in there.
this is not related to the ECM because you would not be able to run with carb cleaner.
How about clogged fuel rails ? maybe your lt1 comes from a theif recovery or some shiat like that and there has been sugar in the fuel lines and it could have jammed the injectors ???
Old Aug 25, 2003 | 11:09 AM
mat89RS's Avatar
did you bypass the starter enable relay ?
if so, have you tried to run it in it's normal configuration ?
Old Aug 25, 2003 | 11:18 AM
mat89RS's Avatar
Maybe this would help
Old Aug 25, 2003 | 06:44 PM
sinner's Avatar
the motor was outta a wreck, so i know it wasnt stolen. the starter bypass should be fine, but ill look over all the fuses too.
Old Aug 25, 2003 | 06:56 PM
wm_sorg's Avatar
Thought you would like this. I filled my tank and went to the body shop after writing your response. Turned the car off. Guy said he will call me with the numbers. Go to star the car and it imeadiately dies. Sounds like it's run out of gas. Thought it was vapor lock so I let it sit. Sure enough no start after an hour. Pulled out the IAT and sprayed carb cleaner and it runs until the spray runs out.
Fuel pump realy clicking, but fuel pump not priming. Fuel pump shot. Walbro on its way. Now I have to ruin/redo months of work and a new exhaust to get this dame thing in. The pump is probably cool right now and I bet it will start right up.
Old Aug 25, 2003 | 07:09 PM
sinner's Avatar
well i dont like it cause i feel bad 4 u, but my pump works so i know at least thats not a problem
Old Aug 25, 2003 | 07:31 PM
wm_sorg's Avatar
Thanks. I hope you get your issue resolved soon.
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
