New hood design finished
Old Sep 3, 2003 | 05:46 PM
jmiller's Avatar
Car: 87 IROC - 67 Camaro
Engine: 383 TPI - ZZ4 TPI
Transmission: 700R4 in both cars
Axle/Gears: 3.27 - 3.36 posi in both cars
Finished painting my fiberglass hood. This is my design hood with 2" cowl induction following the lines of the z-28/iroc inserts. Hood is made with 2 pieces (inner/outer), carbon fiber inside scoop, and embedded machined aluminum for standard hinge, latch and spring mounting. Also made more clearence for the air box. Air box can be expanded an 1 1/2" taller which will allow double the air flow. Next thing I am tooling is the insert nose piece (IROC/fog lamps removed) with air channels directly into the air filter box.
I've posted some pics.
Old Sep 3, 2003 | 05:47 PM
jmiller's Avatar
Inside shot
Old Sep 3, 2003 | 05:48 PM
jmiller's Avatar
closeup
Old Sep 3, 2003 | 05:50 PM
jmiller's Avatar
sorry, closeup
Old Sep 3, 2003 | 06:18 PM
91zconvt's Avatar
Car: 87 Iroc
That hood looks amazing. Did you make it yourself? Any chance you'll make me one?
Old Sep 3, 2003 | 06:43 PM
FLYNLOW92rs's Avatar
Indeed it does....
That stripe idea is interesting, any pics of the back of the car?
Old Sep 3, 2003 | 07:23 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
That's great workmanship. You should consider mass producing them. I think they look great. Although I have a Trans-AM and it would be out of place on my car, I am glad to see another alternative to regular cowl hoods. Which I am not fond of. I like the Jongbloed hood, the SS hood and the one you've got alot better.
Nicely done.
Old Sep 4, 2003 | 03:04 AM
logikal6785's Avatar
way to go man !!! that's really nice, keep us posted on the airbox flow routing
double post
Old Sep 4, 2003 | 07:47 AM
Freeze's Avatar
Car: 1992 Firebird
Engine: 3.1 V6
Very nice!
Old Sep 4, 2003 | 08:07 AM
MaineIrocer's Avatar
Car: 1986 Iroc-Z
Transmission: Automatic
That hood looks sweet.......... Very nice job......Did u ever consider painting the ground effect the same red as the red on the hood??? I think that would make it standout a little more.......But again awesome job on the hood.......I like the idea of mass producing it hahaha
Old Sep 4, 2003 | 12:15 PM
jmiller's Avatar
I really appreciate all your comments, it makes me feel like I didn't waste hundreds of hours of my time working on this.
Yes, I can build more. I am trying to get a patent before I let any of them
go, probably impossible. I don't want to mass produce; the hood is hand
laminated with a laminated foam core between the outer and inner part. This is not a sweat shop chopper gun build. It takes an experienced fiberglass person to construct it properly. The hood only weighs 45 lbs. and is as strong as the steel hood but 20 lbs. lighter. On the inside of the hood where the scoop is, there is a carbon fiber laminate with a clear finish.
My plan is to have two versions, the one you see here which opens like a stock hood, and another that opens reverse like a Corvette. I am working on that version now which requires custom hinges, latching, and a new inside piece to handle the different mounting locations needed.
I do plan on adding burgandy/red trim down the side of the car about where the IROC decal was. Or, more like 3-4 colors of neon tubes starting behind the front wheels and twisting up and over the rear wheels. I had a 67' Camaro back in the late 80's I did that to, it was completely original looking.
I'll keep posting as I go and again thanks to all of you!
Old Sep 4, 2003 | 03:09 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Man that looks awesome. Thats a great idea, its pretty cool that you followed through with it.
That hood looks great and I would not be ashamed to put that on my car anyday!
:hail:
Old Sep 4, 2003 | 09:01 PM
bigals87z28's Avatar
Car: Check The Sig
very sweet!! I saw the hood scoop in superchevy about 2 mins ago and thought about welding the first gen z28 hood on... and the stripes look soooooo 80's!!!
Old Sep 4, 2003 | 10:29 PM
25THRSS's Avatar
I like it, but it would look 100 times better with heritage stripes.
Old Sep 4, 2003 | 10:32 PM
BORLAZ06's Avatar
looks awesome
Old Sep 4, 2003 | 10:36 PM
chris400's Avatar
gotta give you ALOT of credit on your labor of love.
Hood is BadAss !!!!
you should be proud not only of the end result, but also of the fact that 99.9% of the people who see it can't bring that type of idea to completion.
GOOD JOB!
Chris400
Old Sep 5, 2003 | 01:00 AM
Midnight Sun's Avatar
Car: 1983 Trans Am
Engine: N/A
Transmission: N/A
Awesome stripe idea.
Give your car a sweet *** retro look. Damn. Nice.
Old Sep 5, 2003 | 05:41 AM
stevver84Z's Avatar
Car: 1990 Iroc Hardtop
Whoa!! thats awesome, its really 80s lookin, thats really cool, nice job!!!!
Old Sep 9, 2003 | 08:59 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
PM me when your ready to make them for members...
Old Sep 10, 2003 | 02:49 AM
305 91camaroRS's Avatar
:yourock: when u wanna start sellin' them pm me to or email me brett_U@msn.com
Old Nov 3, 2003 | 01:05 PM
jmiller's Avatar
Finally had time to paint the rest of my IROC. Decided to paint stripes on the rear deck lid like some of you suggested.
I've attached some more pics. Molds for hood are done as well.
I would like to ask if you think I should make a 4" cowl also. Seems like a lot of people are interested in taller scoops.
Old Nov 3, 2003 | 01:06 PM
jmiller's Avatar
Another shot
Old Nov 3, 2003 | 01:07 PM
jmiller's Avatar
Last shot
Old Nov 3, 2003 | 01:10 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
instead of custom hinges, ever consider the reverse style hinges like some buicks had?
Old Nov 3, 2003 | 01:30 PM
jmiller's Avatar
MrDude_1
You are correct about not having to make custom hinges. I found very easy to use hinges on a Jag late model XJ6 that will work well. But I don't know how many can be found in junk yards, or how expensive new ones cost from a Jag dealer.
Buick? OK, what year and model has reverse open hoods? Let me know and I'll take a look at them.
Old Nov 3, 2003 | 02:08 PM
FyreLance's Avatar
Car: 00 TA, 91 Formula, 89 RS
Wow, looks amazing.
Old Nov 3, 2003 | 08:51 PM
tamatt27's Avatar
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Dude, not only the hood, the car looks bad ***!!! I love that hood idea! Any chance ya wanna make it for F-Birds??:hail:
Old Nov 3, 2003 | 09:01 PM
Adam Jones's Avatar
Stunning :hail:
-AJ
Old Nov 4, 2003 | 07:28 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I believe the 80's LeSabre had them.
Old Nov 4, 2003 | 07:50 AM
KCobain147's Avatar
Car: 91 Camaro RS
Engine: 305 TBI LO3
I can tell you for a fact that the 80's lesabre up to atleast 85 didnt, because i currently own an 85, and have previously owned an 83....maybe one in late 80's or early 90's?
Old Nov 4, 2003 | 07:57 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
MrDude_1
late 80s early 90s.... the ones that look like the pic below..
im not a buick expert, so i donno any exact years... i only know about the hood from working on them....
Old Nov 4, 2003 | 10:13 AM
jmiller's Avatar
Thanks for posting the picture of a buick.
From the picture, it looks like the hinges won't work on a 3rd gen. When open the hood moves down too far and would hit the nose of a third gen. I'm still going to research it though.
thanks again guy's, I'll keep you posted as I go along.
Old Nov 4, 2003 | 10:15 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i think if the hinge was closer to the front of the car, you wouldnt have that problem.... well with a camaro... if its for a bird, thats not going to work.
Old Nov 11, 2003 | 03:11 AM
camaro86zdude's Avatar
Car: 1986 Z28
thats awesome!!! love the 80's looking stripes how they seem to blend together! beautiful :hail:
Old Nov 11, 2003 | 04:17 AM
Car: Check The Sig
Not to impose on you, but you do have plans to make this right? The hood looks great and Id love to have one! Looks really good on your car. I wish I had the resourses to make my own. Very good!
Old Nov 11, 2003 | 06:23 AM
AFor89mula's Avatar
Hood looks great. Maybe you could use hinges from the Nissan Z cars? I had an 82 280ZX that opened reverse like that. Just something to look at.
Hotrodboba400
Dec 10, 2019 07:07 PM
ericjon262
Sep 11, 2015 06:07 PM
dimented24x7
Sep 6, 2015 03:51 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
