91-92 White Face Guage Download Files ANYONE HAVE THESE?
Old Oct 5, 2003 | 03:36 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Hey all,
I was wondering if anyone has the zip file or image files for the DIY White Face Guages, more specifically for the 91-92 cars (I think they're all the same, but it's for a 92 RS V8). I've searched everywhere and no luck. DIY used to be hosted on Mike Key's site which has now turned to...well, I'll let you see, I'm not quite sure what to make of it , and the poor man's only has old V6 guages. Any help would be greatly appreciated!
Tony
Old Oct 5, 2003 | 05:29 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
i got em just email me
Old Oct 8, 2003 | 01:36 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Old Oct 8, 2003 | 01:39 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
maybe a mod could make this a sticky because i get about 15 emails a week for these and i forget to send them sometimes
Old Oct 12, 2003 | 10:58 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Well, I got em, printed em, and put em on. A few points to watch:
1) Scaling: Everyone says just print them out, they're to scale...The ones I had were like 12" * 10"...not gonna fit. I scaled them down using photoshop using a scale of 36% *THIS IS NOT AN ACCEPTED MEASUREMENT BY ANY MEANS, USE THIS AT YOUR OWN RISK, DO NOT B!TCH AT ME IF IT DOESN'T WORK** That being said, it worked great for me
Edit: These images are really goofy. Let me elaborate, when I opened the tach up in paint, it comes in as 12.5 x 10.94 at a resolution of 96x96 per inch. This requires a rescaling of 48%. When I open it in photoshop, it comes in as 16.667 x 14.583 with a resolution of 72 pixels per inch. The image size is SUPPOSED to be 6" by 5.25" which in photoshop requires a rescaling of 36%. If you don't want to rescale it (which I recommend) change the resolution to 72*(1/.36) = 200 pixels per inch. This should preserve the original quality and print better as well. I've added the re-resolutioned pictures to the zip file, these ones should just print off correctly without any resizing.
2) For the 91-92 Gauges, Make sure to cut out the center part of the Volt/Oil/Batt/Fuel because the blinkers and high beams go there, I'm not sure if they'll shine through whatever paper you use.
3) Before you even take the gauge cluster out of it's spot in the dash, make a mental note of where the needles are, they move really really easily, so write that down and do the instructions in the DIY Article
That should cover it, enjoy!
Old Dec 1, 2004 | 01:53 PM
twolfe's Avatar
Car: 91z28
Engine: 5.7 l98
Transmission: AT :(
hey can you send me that zip file if you still have it? its twolfe98@yahoo.com that link you listed is no longer active but thats a year ago...
thanks
-Tony
Old Dec 1, 2004 | 02:30 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Old Dec 2, 2004 | 04:22 PM
camaro of solar's Avatar
yea i would like a copy of that zip file as well if somone would be so kinda s to send it my way.... solarofthesix@hotmail.com thanks all
Old Dec 2, 2004 | 06:21 PM
USA_Rally's Avatar
Car: 92 Rally
I would also like this.. Bailey1s2000@yahoo.com
Old Dec 2, 2004 | 06:26 PM
THEGENERAL's Avatar
guys do as i did and click on this
http://www.geocities.com/machowalkclub/Gauges
its the same link but without the .zip on the end and it works then
Old Dec 3, 2004 | 03:52 PM
USA_Rally's Avatar
Car: 92 Rally
Thanks General!! your the man!! :hail:
Old Dec 3, 2004 | 03:58 PM
THEGENERAL's Avatar
Old Dec 7, 2004 | 01:57 PM
USA_Rally's Avatar
Car: 92 Rally
General, I can't get this link opened.. when i try it tells me page cannot be dispalyed
Old Dec 7, 2004 | 02:05 PM
THEGENERAL's Avatar
hmmm worked fine for me ??????
does it give you an option what to open it with ??
Old Dec 7, 2004 | 06:27 PM
USA_Rally's Avatar
Car: 92 Rally
when i pull it up it says it has to go on-line to find the proper system to open the program with, i hit ok, and then it comes up with page cannot be displayed. It may have just been an issue with my intrernet at that particular moment. I'll try again when I get off work this evening.
Old Jul 3, 2012 | 06:09 PM
cz28coptzer327's Avatar
Car: 84 camaro Z28
Transmission: borg warner T5
Re: 91-92 White Face Guage Download Files ANYONE HAVE THESE?
could someone please send me a link or the image file.. none of these links work.. cz28coptzer327@yahoo.com need it really bad.. cant find it anywhere
Old Jul 3, 2012 | 06:16 PM
Car: 84 camaro Z28
btw its for an 84 camaro z28 5 spd..
Old Jul 5, 2012 | 07:43 PM
1986IROCZ355's Avatar
Car: 1986 IROCZ, '00 Grand Prix GTP
Engine: 355, supercharged 3.8
Transmission: 5 speed manual, auto
i too would love to have this file. my problem is, the link you have on here to click on brings me to yahoo geosites which says is no longer available. my email is brandonb0013@gmail.com thanks guys!
Old Jul 7, 2012 | 11:43 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Maybe because they are almost 10 yrs old.This is the 4th of these thread types requesting links....too funny!Must be a conspiracy going on.
sheachopper
Jul 31, 2019 11:27 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
