Cluster Swap....
Old Nov 15, 2003 | 01:09 AM
SweetRide45's Avatar
Cluster Swap....
I have a '90 V6 (currently) w/ a 120mph Cluster. If I swap this out for a '90+ Trans Am/GTA 140mpg Cluster, would everything work properly? Would I need to re-calibrate anything? I am later on swapping in a 350, so, I would have the Tach issue out of the way. But, I'm just wondering if it would function properly w/ the current setup. I have a 730 ECM.
Old Nov 15, 2003 | 02:21 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The only problem would be the tach reading lower than actual untill the v8 goes in.
Old Nov 15, 2003 | 04:55 PM
Thanks for the help!
Elephantismo
Feb 13, 2019 12:51 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
James Sutton
Sep 23, 2015 02:18 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
