will Auto Meter gauges work w/ stock sending units
Old Nov 15, 2003 | 07:22 PM
BOTTLEDZ28's Avatar
Transmission: A4
Will the auto meter coolant temp gauge work correct of I hook it up to the stock wires in the dash? Whats up with the fuel level gauge? I hope I dont need to buy something that goes in the tank.
Old Nov 16, 2003 | 05:35 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
No. I tried this when I installed my temp gauge. I used the autometer unit and when I hooked up the stock gauge wire, it went haywire. If you can somehow get it to work though, definatly tell how you did it.
Old Nov 17, 2003 | 12:37 PM
johnsjj2's Avatar
Car: 1991 Z-28
If you buy the electric gauges, they come with their own sending units. Both my H2O temp, and oil press. came with senders.
Old Nov 17, 2003 | 04:14 PM
CraZ-28's Avatar
Car: 1991 Z-28
Forgot what I was going to say.
Old Nov 17, 2003 | 04:50 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Stick with the electric guages and you should be fine. Like mentioned above, they come with new sending units which sould be replaced anyway. The fuel level should work with your stock one. I believe it says that in their description of the guage. good luck
Old Nov 19, 2003 | 09:45 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
The Autometer Pro Comp Electric Oil Pressure gauge works with the stock sender. I tried it out since I bought the gauge used without a sender.
Also, the Autometer and GM oil pressure senders look identical, big round bell looking thing.
Autometer Fuel Level uses the stock sender. We have it on my friends 82 T/A.
Here's a pic of when I was wiring up all the gauges,
Old Nov 19, 2003 | 09:47 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
oil and gas gauges will work.... coolent temp needs a diff sender.
Old Nov 19, 2003 | 04:29 PM
BOTTLEDZ28's Avatar
Transmission: A4
ok sounds good, now since I have an electric speedo and I pan on getting a new Auto MEter electric speedo, will I be albe to just plug the speedo into the plug on my T56 and adjust the speedo. I have the SGI 5 box and it sucks *** for me
Old Nov 19, 2003 | 07:41 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
how can you afford all those guages?? thats like $1000 worth of gauges!
Old Nov 19, 2003 | 08:00 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Axle/Gears: 10 bolt 3.23
Darn you, Zepher I wanted to be the first one to custom install autometers into a firebird. Now you've taken my dream away how dare you!! Looks awesome!! :hail:
I'm sure I'll be chewing your ear off in the future once I get enough money for all phantoms, right now I only got trans and a/f on my a pillar.
Old Nov 19, 2003 | 10:20 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Another member, Karp's T/A has already done it as well. It looks awesome too
Old Nov 19, 2003 | 11:09 PM
Zepher's Avatar
That's my friends car that I was helping to build.
He had a large budget to work with.
We used Karps T/A as a template as well as a couple of other members cars that are on this site.
Old Jun 10, 2011 | 06:01 AM
vassara2002's Avatar
Re: will Auto Meter gauges work w/ stock sending units
I have the same gauges in my 84. Which is the wire in the stock harness i connect ? Where is that located? Does it come from the top of tank
Old Jun 10, 2011 | 06:03 AM
can you help? I have the same gauges in my 84. Which is the wire in the stock harness i connect ? Where is that located? Does it come from the top of tank
Bubbajones_ya
Jul 6, 2024 08:32 PM
PurelyPMD
May 5, 2016 04:57 PM
R13_Braz
Sep 18, 2015 05:00 PM
BAMiller
Sep 14, 2015 06:38 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
