Compressor maps
Old Nov 20, 2003 | 02:10 AM
Verviticas's Avatar
Engine: L98 5.7
Compressor maps
Does anyone have compressor (sp?) maps for common junkyard turbo's? I rather try a single turbo setup but duel turbo set ups are cool too.
Thanks, Verv
Old Nov 20, 2003 | 10:58 AM
ATOMonkey's Avatar
Garrett charges on turbo coupes and PSDs can be found at egarrett.com or something similar. As far as the Holset, IHI, etc. turbos I'm not sure.
Old Nov 20, 2003 | 01:01 PM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
There are quite a few listed at www.turbonetics.com...
Old Nov 21, 2003 | 04:24 AM
83 Crossfire TA's Avatar
With the exception of the T3’s, and some of the Holsets you won’t find a turbo in the junkyard that will be clearly labeled in a way that you can relate to the compressor maps. A T04e 50 trim won’t have T04e 50 trim written anywhere on it. The holsets will have the model on there tags, but that isn’t that helpful, since there are quite a few of each one (ex, there are 9 different sizes H1E that I know of, and 6 HX50’s, there are 2 HX55’s that are smaller then most of the HX50’s, most of the H1D’s are smaller then the H1C’s even though the H1D is a “larger frame” turbo).
Old Nov 21, 2003 | 07:59 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
dont forget the Warner/IHI turbos like the GM-5 and GM-8
Old Nov 21, 2003 | 11:15 AM
What about them? As far as I can tell, the GM 6.5L diesel turbos are all roughly the same size even though they have different designations. They’re also fairly small acting compared to a relatively large physical size
Old Nov 21, 2003 | 12:09 PM
Doward's Avatar
I found my mitsu flow maps here -
http://www.stealth316.com/2-3s-compflowmaps.htm#fm
Old Nov 21, 2003 | 02:36 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont know about all that stuff although when I look at the hulk of a GM-5 I have you can tell its huge size belies a small intent by the size of the tiny ports on it.
I also know that when 6.5 owners ditch the GM-3 for a GM-5 or GM-5 for a GM-8 the get a huge improvemnt in power.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
anesthes
Sep 30, 2015 07:48 AM
