Torque Arms
Torque Arms
Is there anything to be gained in switching from the stock stamped steel Torque Arm that mounts to the tranny tail shaft, to an after market one that is shorter than the stock arm and is made from 1.25" x .095" 4130 chrome moly tubing and mounts to a cross member thats welded between the sub frame conecters.
The car dead hooks with zero tire spin.
Car: 1990 Camaro RS
well the gains would be in the shortening of the torque arm, but you are cutting 1.3 60's might allow you to launch from a little higher RPM. the shorter torque arm should be better for weight transfer to the rear.
i assume you are talking about one of the BMR torque arms?
Car: 92 Camaro RS
Engine: 350 Crate Motor
Transmission: Tremec TKO
Axle/Gears: 10 Bolt 3.73
Also it's nice (with aftermarket torque arm) to be able to adjust your pinion angle.
-Rich-
-Rich-
Sorry for all the questions, Im just trying to figure out why I need to spend anywhere between $250 and $675 for one of these arms?
Car: 1990 Camaro RS
if you are happy with your car now, don't upgrade.
with 1.3x 60's, you are doing something right as it is. like i said, more weight transfer usualy = more traction, if you are launching at 2200rpm, maybe you could instead launch at 2600, that might make your car, that much faster in the 1/4.
i am not exactly sure what kind of answer you are looking for?
Every time I tell someone im useing the stock torque arm, they tell me I need to upgrade to an aftermarket one. Im just trying to find out why it is I need to do this? What will I gain from this other than a lighter wallet?
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
If you are hooking, which is pretty obvious by your short time, just leave it alone. Some people may be thinking you NEED an aftermarket torque arm because it would be stronger than the flimsy stamped steel piece. But you seem to be doing just fine. If it were me, I wouldn't touch it...
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
J E G S their torque arm is more like a ladder bar very solid and it made my original t/a 5.7 5spd hook on goodyear gscs and we all know these tires suck for drag racing,psi@20....
i really like the idea of this bar cause it does not hook up to the tranny,man that has got to distort the tailshaft on hard launches crappy idea gm had but it worked,now the TTA set up was much better,try finding that though
Car: Guess
Engine: Crazy 8
The Spohn Torq arm works in a similar way. They mount it to the crossmember where it should have been in the first place.
But, as the guy said above, he is confused as to what good it will do him since he is already hooking very well...
OK, Ill let you guys off the hook. The reason I started this topic was to show you that 95% of the peeps on this board do not need to fix something thats not broke. The stock flimsy stamped steel piece works and it works very well as has been proved with testing it for over 7 years without breaking one. Spend your money else where. Tires, Springs, Shocks.
Car: Guess
Engine: Crazy 8
Well, I can see getting an adjustable Torq arm if you are hunting for better traction, or if you, like me, changed to a transmission that was not ever offered in a 3rd Gen. I bought the Spohn Torq arm and crossmember. It is better to secure it to the frame rather than the tail housing of a transmission...
But I agree completely with you, if there is no problem with the part and, in your case, you are getting great traction, don't beat a dead horse...
man I was starting to wonder, I mean
you didnt want to waste 250-600 for a TA, but you have10- 20k plus in mods to get it in the 10s. Personally if I had your car running 10s the LAST thing I would have is a stock TA
quite playing with us
Oh nice vids
cars are kinda of cool too.
Oh nice vids
cars are kinda of cool too. The point is : The torque Arm is not the fix all for the traction problems that most of the peeps think it is.
Maybe 10k total including paint and wheels
Car: 91 Red Sled
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
