metric to standard
Old Jan 4, 2004 | 08:17 PM
stupid4901's Avatar
metric to standard
Does anyone know a good place to get metric to standard brake line adapters?
Old Jan 4, 2004 | 08:26 PM
Brett H. - 89GTA's Avatar
Car: 1989 GTA
Engine: 5.7L
Axle/Gears: 3.27 BW 9-bolt
I looked awhile back and couldn't find what I needed. I found some adapter unions for the 3/16" front lines, but couldn't find any for the 1/4" rear line. I'm just going to reflare the stock lines and use regular SAE unions.
Old Jan 4, 2004 | 08:38 PM
stupid4901's Avatar
My problem is that the flaring tool that i bought through summit will not work on my lines. The 1\4 is too big and the 3\16 is too small so no flaring goes on. What could i do about that?
Old Jan 5, 2004 | 04:31 AM
ede's Avatar
ede
not hard to find, at least where i live. weatherhead i know makes them.
Old Jan 5, 2004 | 08:08 AM
stupid4901's Avatar
I'm in the middle of installing the Wilwood proportioning valve. Has anyone else run into this problem using the article in the tech section? Will standard nuts work on metric line?
Old Jan 5, 2004 | 08:12 AM
ede's Avatar
ede
never tried it but i'd think an american nut on metric line would work just fine. the seal is more in the flare, as long as you have a good flare, and the correct flare, i doubt if the nuts would matter.
Old Jan 5, 2004 | 03:35 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
As long as you have the right flare, and the size of the nut is close, you shouldn't have any problems.
The American (SAE) type of nuts and fittings are to be used with the double flared line, and the metric (ISO) nuts and fittings are for the bubble flared line. The SAE fittings won't accept the bubble flare, and vice-versa.
gixxer92
May 18, 2017 11:20 AM
Fronzizzle
Feb 9, 2017 09:31 AM
Gunner242
Dec 25, 2015 04:49 PM
1992Z28!
Nov 19, 2015 07:33 AM
Bigold4x4
Sep 28, 2015 05:21 PM
