Almost ready, what HP gains?
Old Feb 1, 2004 | 02:12 PM
Wishmaster's87IROC's Avatar
Engine: 385 HSR.....LS1
Well Im almost ready to turn the key and see what happens....Whatcha guys think my gains will be? I know some of you dont like the cam but with that and all the other stuff ...I hope to see atleast a somewhat good increase....I guess..I hope...
heres what I have added to go with the stuff in my sig.
LT1 cam
roller timing chain
1.6 rollers
SLP Tri-y's 1.5/8 coated
underdrive pullies 3 set
MSD everything
160* Fan switch
smog removed
EGR removed
A/C not hooked back up yet
....and of course some apperance stuff
I gone from 4 belts down to 2....Im also gonna get a custom chip made for it since the EGR was removed....
so whatcha think?
Old Feb 1, 2004 | 02:14 PM
its been sitting like this since May...damn I hope it cranks!...LOL
Old Feb 2, 2004 | 09:51 AM
any ideas? or should this be in the TPI forum?
Old Feb 2, 2004 | 03:45 PM
2laneblacktop's Avatar
Who makes that pulley and bracket set up. I like the looks of that, and it gets rid of that serpantine belt set up.
Old Feb 2, 2004 | 05:39 PM
manchesterbeast's Avatar
Car: 1985 pontiac trans am
Engine: 350 with carb and headers
Transmission: borg warner 5speed
that looks sweet. i like it. that engine looks like its gonna kick ***!
edit:: also your shop in the second pic looks really nice. its even got a white board to write notes! heh. wish i had that, workin on the car outside sux!
Old Feb 2, 2004 | 05:47 PM
LOL...it is an outside garage...not heated so when its cold outside its cold in there...thats what sux....some days I couldnt even work on it..it was to freakin cold!.....LOL
Old Feb 2, 2004 | 05:52 PM
ha! coldness didn't stop me. i was wrenching with num fingers. but snow and rain? thats another thing.
heh, but then again, i was under alot of pressure to get mine back together quick, its a long story...
Old Feb 2, 2004 | 06:00 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I also like the belt setup. It looks good.
Is that the stock brackets, just modified? Everything looks clean and neat. Good job
BTW, that's not a stock serp. belt water pump, right?
Old Feb 2, 2004 | 06:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Stock runners are going to hold you back.
Belt/pulley setup looks like gussied-up version of my '86 LG4 & '87 LB9 w/o AC. Alt. belt is flat multigrooved like serpentine, but doesn't "snake" around anything.
Old Feb 3, 2004 | 09:07 AM
The belt system is the same, what came with my car stock...not the serpentine system. THe pullies are BBK's for 85-87 camaros, I got them cheap so couldsnt pass it up.. those years have a diffenent belt setup. I just cleaned everything up and made it look alot nicer. I like my braided fuel lines too. THe guy used my stock connectors, cut them off and added braided lines...a whole lot cleaner. My A/C brakets are there I just dont have the compressor hooked up yet...gonna leave that off for a while.
any idea on the HP gains?
antman89iroc
DIY PROM
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
DIY PROM
Sep 17, 2015 07:48 AM
